Old 06-27-2016, 06:46 PM   #15
Skylinehi1
Drives: Black raven 2013 frs
Will this correct - camber? What's the max?
Skylinehi1 is offline   Reply With Quote
Old 06-28-2016, 08:30 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Whiteline claims +/- adjustment of .75 degrees (which is close to accurate in my case at least)
Old 07-02-2016, 11:14 AM   #17
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
Yes that's exactly correct.
I originally installed these with lowering springs. Most lowering springs will give you more Negative camber than you can correct for with the OEM bushings and arms etc.
My springs gave me about -1.5 and I used these to correct that back to -1. I was getting too much tire wear on the inside at 1.5. It's amazing how much that small of an adjustment can have on your tires and grip levels.
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
Dominant Engineering Custom Bc Coil Camber plates and rear Uca/Upper Control Arms thatcosta Canada Classifieds 2 04-23-2015 12:49 PM
FS: SOLD Whiteline rear upper control arm camber adjustable bushings. JRP Brakes, Suspension, Chassis 8 03-30-2014 01:28 AM
Upper control arms for bulk camber JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 06-18-2013 12:40 AM
