Old 06-28-2016, 02:09 PM   #13371
FX86
if you have a rear wheel drive car and you drive in reverse does that mean it technically turns into a front wheel drive car?
FX86 is offline
Old 06-28-2016, 02:12 PM   #13372
FWD rear steering.
Tcoat is offline
p1l0t (06-28-2016)
Old 06-28-2016, 02:20 PM   #13373
Ashikabi
Ashikabi's Avatar
Does cruise control work in reverse?
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
p1l0t (06-28-2016)
Old 06-28-2016, 02:27 PM   #13374
Originally Posted by Tectoniic View Post
You should do some testing and let us know
If they are then it is set higher than my comfort zone for backing speed. Ummmm... not that I tried it or anything.
It's limited by gearing, like all cars. (Don't know any that have a reverse "governor" but never really looked into it so, your results may vary)
Back in my ATV/Offroading days I had a Polaris Scrambler 400 (380cc, 2 stroke) with a variable transmission. It would do 68MPH forward (clocked on a paved mile). It also had a reverse. There was a button on the bar that overrode the reverse limiter so it would go as fast backwards as forwards.
I tried it once...still cleaning my pants and only got to about half throttle.
Dadhawk is offline
Tcoat (06-28-2016), Tectoniic (06-28-2016)
Old 06-28-2016, 02:30 PM   #13375
FX86
i would need a fast and furious runway to use as my testing ground for the most accurate results
FX86 is offline
The Following 2 Users Say Thank You to FX86 For This Useful Post:
p1l0t (06-28-2016), Tectoniic (06-28-2016)
Old 06-28-2016, 02:32 PM   #13376
FX86
were you facing forward or backwards when going in reverse?
FX86 is offline
Old 06-28-2016, 02:53 PM   #13377
Hey, where'd you get my picture!
I was facing forward, not smart enough to think of facing backwards, might have worked.
It did make for some fabulous reverse donuts at night though as I had added backup lights to it. I was told it was like a well-lit tornado.
Dadhawk is offline
Old 06-28-2016, 03:28 PM   #13378
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
No, cuz you need to be going minimum of 25mph
ichitaka05 is offline
MrFisty (06-28-2016)
Old 06-28-2016, 03:30 PM   #13379
Ashikabi
Ashikabi's Avatar
Mhm...?
Ashikabi is offline
Old 06-28-2016, 03:30 PM   #13380
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
Challenge Accepted! I can't make him go the other way though.
iamjacob is offline
The Following 2 Users Say Thank You to iamjacob For This Useful Post:
MrFisty (06-28-2016), Tectoniic (06-28-2016)
Old 06-28-2016, 03:31 PM   #13381
It's limited by gearing, like all cars. .
I'd say it's more "driver limited" .......
humfrz is offline
Old 06-28-2016, 03:33 PM   #13382
ichitaka05
Site Moderator
ichitaka05's Avatar
Mhm...?
CC read by speed sensor. If car isn't going 25mph, they won't turn on... aka reverse can't go that fast.
If you do it, make sure not to follow Mustang's path and hit everyone on the way.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
MrFisty (06-28-2016), p1l0t (06-28-2016)
Old 06-28-2016, 03:35 PM   #13383
Ashikabi
Ashikabi's Avatar
You said it wouldn't work because it is regulated by minimum speed. Why couldn't it work if you were doing 25 in reverse?
Ashikabi is offline
Old 06-28-2016, 03:36 PM   #13384
Because if in reverse you are going -25 Geeeeeez isn't that apparent?
Tcoat is offline
Dadhawk (06-28-2016), FX86 (06-28-2016), ichitaka05 (06-28-2016), MrFisty (06-28-2016), p1l0t (06-28-2016), Tectoniic (06-28-2016)
