Old 06-27-2016, 03:47 PM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
squeaky clutch issue
Anyone had Clutch squeaky issue? (mostly throwout bearing issue) which a lot of 86 owner has. It makes sound from last 2 inches when It travel to the bottom.
It this will go away with just some of lub work?
This video is after driving about an hour.
when car is cold there's no squeaky or crunchy feeling
Thanks!
bhbnuckle is offline   Reply With Quote
Old 06-27-2016, 04:45 PM   #2
Oh, my ....... ANOTHER clutch making noise ........
Someone should make a "diagnostic tree" for this aberration.
@bhbnuckle ..... in your case, I would suspect:
* maybe the return spring could use a shot of lub
* maybe a part of the linkage/pedal under the dash needs a lub
* maybe the clutch fork is dry
Old 06-27-2016, 04:53 PM   #3
bhbnuckle
bhbnuckle's Avatar
Thanks humfrz. and yes again!!
This need to be placed on TSB
I was thinking of take peddle spring out too, but afraid of warrany will be voided by doing that.
Actually one of my mechanic friend offered peddle spring will solve the issue (I didnt believe him lol)
Anyone here removed their spring and squeaky gone?
Old 06-27-2016, 04:58 PM   #4
Well, if it is the spring, you should be able to douse it with silicone spray and quiet it down. No need to remove it.
OBTW ....... one thread per problem is usually sufficient ......
How I fixed my squeaky clutch jacjac3 Issues | Warranty | Recalls / TSB 40 09-27-2017 11:35 PM
Squeaky Clutch when depressed! oppiee Issues | Warranty | Recalls / TSB 29 09-01-2016 08:01 PM
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 05:20 PM
