Old 06-24-2016, 06:06 PM   #1
86King
Drives: FR-S Monogram
Help! FR-S Exhuast
I found a TRD Dual Tip exhaust and a Catless T1R front pipe for a good price.
Was wondering if this is a good set up or if it's going to give me codes for not having a Cat? And if it drones?
Would I need to get a tune if I run the T1R Catless front pipe and TRD catback?
Also any performance gains?
Everything else is stock expect for a K&N drop in air filter
86King is offline   Reply With Quote
Old 06-24-2016, 06:34 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
TRD exhaust w/ TRD intake gains range 6-10hp. Toyota somewhere claimed 10-15hp. I felt no difference. Butt dyno.
You need a tune for best xp. If not, should be fine. Catless and codes? IDK.
Old 06-24-2016, 07:54 PM   #3
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
removing any cats would most likely throw code CEL, will need tune
turtlefeeder is offline   Reply With Quote
Old 06-24-2016, 08:25 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Catless front pipe will not give you any codes.
Catless front pipe without properly sized resonators WILL give you drone.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
86King (06-24-2016), gramicci101 (06-24-2016), Mr.Impreza (06-25-2016), wireman957 (06-24-2016)
Old 06-24-2016, 08:35 PM   #5
Cole
Not a troll
Cole's Avatar
And how would it do that when the secondary cat in the FP is well downstream of the second O2 sensor?
I'd suggest not giving advice if you don't know what you're talking about.
Cole is offline   Reply With Quote
Old 06-24-2016, 08:53 PM   #6
Dual tip TRD will not fit the stock bumper cut outs. You will either have to find a TRD bumper (good luck with that) or cut the stock openings. There are inserts you can buy if you go the surgical route.
Old 06-24-2016, 08:59 PM   #7
Teseo
Drives: frs
Or he can go to a muffler shop and redo the tailpipes
Old 06-24-2016, 09:07 PM   #8
Sort of defeats the purpos of buying dual tops in the first place though.
Old 06-24-2016, 09:09 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Custom T-tops or softop/hardtop combo?
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Cole (06-24-2016), Tcoat (06-24-2016)
Old 06-24-2016, 09:11 PM   #10
Tip not tops. Although you will never top my tip.
Old 06-24-2016, 09:23 PM   #11
finch1750
finch1750's Avatar
But can I tip your top?
cdrazic93 (06-25-2016)
Old 06-24-2016, 11:30 PM   #12
turtlefeeder
Drives: UltraMFrS
Whoooh @Cole you fed my turtles xD
Sent from my SM-P600 using Tapatalk
Old 06-25-2016, 05:52 AM   #13
86King
DUAL tip not QUAD TIP... I am referring to the tips that are half circle (like a triangle) the tips will fit the current exhaust cut out
Old 06-25-2016, 06:01 AM   #14
86King
Quad tips= 2 tips on each side
Dual tips = 1 tip on each side
Exhuast confusion xsnapshot Engine, Exhaust, Transmission 10 06-30-2015 02:21 PM
FS: TRD exhuast Obja Engine, Exhaust, Bolt-Ons 4 07-14-2014 11:14 AM
WTB Trd exhuast $500 davebrus Want-To-Buy Requests 1 03-19-2014 09:36 PM
WTB: TRD exhuast tips davebrus Want-To-Buy Requests 1 02-14-2014 01:49 AM
Exhuast Sizes kurbkilla Engine, Exhaust, Transmission 10 01-17-2014 02:55 PM
