Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-21-2016, 07:06 AM | #15 |
Drives: 2014 WRB BRZ Limited
Return them if you can. If not, resell and give Bilstein B14s a shot. I've ridden in cars with BC's and they are always bouncy, as are most other budget coilovers, especially those that come with tophats and lots of adjustment. B14s are the only coils with decent dampers under $1500 that I have experience with. That being said, I've heard a lot of people really like the ST coils, and any of the RCE options are bound to be good, since they are the suspension experts for this platform.
06-21-2016, 09:36 AM | #16 |
Drives: 2013 Scion FRS
I have mine set at 8 clicks from soft in the front and 10 in the rear and they feel near stock, with the height no adjusted at all (preset height from the box), near as in still pretty damn stiff but comfortable enough for my girl and with the height no adjusted at all (preset height from the box). Need to re-adjust my endlinks.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
06-21-2016, 06:05 PM | #17 |
Drives: Velocity Orange 86 GT
In australia mca blues are 1500 so 1100usd? These usually beat out everything in Their market but shipping costs mean not to many people overseas can get them. Totally agree on palming the bcs off and getting something decent.
06-21-2016, 08:46 PM | #18 |
Drives: 2014 GT86
Shipping costs and no local serviceability/warranty. Hence world wide vendors with local dealerships may have extra edge for their offerings.
06-21-2016, 11:41 PM | #19 |
Yep. Here apart from the fact that any overseas offerings are no better thats why pretty much everyone runs mca's if they are serious.
08-18-2018, 03:04 PM | #20 |
Drives: 2017 Halo 86
I have this issue too, no matter what dampening setting I put, ride height nearly at max lowering. Even worse with someone else in the car. It's almost unbearable and gives me a headache, feeling my brain levitate inside my skull on EVERY SINGLE INDENTATION in the road. It's not like every 5 minutes or so, its literally every second of driving causes the bobble head effect. I'm going to be looking at better options around $2K range. I should have held off, but I really wanted the car lowered. Well, BC BR coilovers surely do their job at letting you lower your car, but goddamn it the tradeoff is not worth it to me. Have even contemplating going back to the stock struts... I have a friend who owns a 370Z that says to just get 12K or 14K springs, he has 14K, and it will fix the issue. But does it for my car?
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
08-18-2018, 04:13 PM | #21 |
LMGTFY
Drives: 13 FRS, 91 Miata
You want low with a nice ride, quit f@3$in around and do it right with bags.
08-18-2018, 05:29 PM | #22 |
The Fail Boat
Drives: CWP S.B.
There. It's a coilover with zero development for just lowing and look nice while parked. .....Don't know why you didnt get teins since they are on 3rd generation of coils for 86s. you paid 1000 for something that's should be around 600.
08-20-2018, 10:28 AM | #23 | |
This thread is a good example of what I talk about when I say that while some shocks are adjustable, there may not actually be 1 good setting in the 40 clicks they let you click. A lot more to it than "soft" and "stiff". - Andrew |
08-20-2018, 10:55 AM | #24 | |
Drives: 2014 Scion FR-S
The Following User Says Thank You to MCTeeJ For This Useful Post: | Lynxis (08-20-2018) |
08-20-2018, 11:32 AM | #25 | |
Drives: 2013 WRB BRZ 6MT
I recommend setting the shocks at the middle point of their adjustment range. Standard preload for most shocks is to have the car in full droop and fully loosen the spring collar so the spring is completely loose, then spin it up until the springs are snug, then do ~3 more full rotations of the collar and then lock it up and you can adjust preload from there to preference. Still too bouncy? Tighten it up a turn. Too stiff? Loosen it a turn. Once preload is where you want it, you can adjust ride height but do NOT adjust the spring collar for this on these coils. Instead loosen the lower collar on the shock and spin the entire shock in the shock body (I'm not certain this is the correct terminology so I hope what I'm saying makes sense) and you'll see the entire thing move up and down. Use this to set height as desired. Once set, get your alignment and you're done! If you try adjusting preload and can't find something that works, contact BC and see what they have to say. |
08-20-2018, 02:01 PM | #26 | |
08-20-2018, 04:27 PM | #27 | |
This setting feels exactly the same as both extremes, 2 front/0 rear, or 30 front/28 rear. Dampening does almost nothing for my car.
10-25-2018, 11:43 AM | #28 |
Holey shit. I come back to this thread years later only to find people discussing preload as a way to change performance in this application. Preload adjusts rideheight here. Thanks for the laugh
Similar Threads | ||||
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
Anyone else's Air Lift setup super bouncy?? | S1CNSTY_SUBIE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-12-2014 03:32 AM |
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * | Speed Element | Brakes, Suspension, Chassis | 21 | 03-03-2014 08:56 PM |
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers | ill roller | Brakes, Suspension, Chassis | 5 | 12-14-2013 03:02 PM |
Bouncy transmission. | empower-auto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-04-2013 02:05 PM |
