Old 05-04-2013, 03:57 AM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Bouncy transmission.
I can't be alone here .. over bumps and when sliding on anything other than a perfect surface I can feel the tranny bouncing around. Bad news bears. What's the best cost-effective fix for this currently available?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 05-04-2013, 07:27 AM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
how do you know its the tranny and not the diff?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 05-04-2013, 08:10 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
^^that.
There's a couple of different answers to this: The STI mount, Whiteline and KartBoy inserts, Cusco ring, and Perrin bolt. After looking at the options I'm going with an insert. I like that it should stiffen things without eliminating movement which can cause a lot of stress in a very localized area. The STI wasn't available when I ordered and looks like a better part (to me anyway). But the price difference would have led me to the same decision.
There's a similar list of options for the diff. Have a look around the board and a few vendors sites. You'll get an idea of what your options are. Just make sure you look at things objectively and don't get hung up on branding.
Old 05-04-2013, 09:01 AM   #4
JerryMichaels7
Drives: Whiteout FRS
You mean wheel hop??
JerryMichaels7 is offline   Reply With Quote
Old 05-04-2013, 01:40 PM   #5
g0lden
Drives: 2013 Scion FR-S Argento
maybe the LSD making the tires scratch while turning?
g0lden is offline   Reply With Quote
Old 05-04-2013, 02:05 PM   #6
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The transmission brace uses a very soft rubber and allows a lot of movement. There are a few options stiffening this mount. The whiteline bushing insert is cheap and very effective.
http://ft86speedfactory.com/whitelin...t-kit-307.html
kask2_6.0 is offline   Reply With Quote
In need of a AT Transmission FRS !! Cowbun CANADA 3 07-27-2012 02:48 PM
What transmission? Ess Vee Engine, Exhaust, Transmission 9 06-25-2012 02:56 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
