Old 06-21-2016, 04:45 PM   #43
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Tire pressure sensors? Cheap, known to break easily doing routine maintenance. It's really not even a necessary convenience.
OldSkoolToys is offline   Reply With Quote
Old 06-21-2016, 05:01 PM   #44
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by mazeroni View Post
Didn't realize there was a TPS monitor in the car already. Or is it just the BR-Z? I only ask because my tires have been down to 30 before and there was no indication.
The TREAD Act requires that all passenger vehicles sold in the United States after September 1, 2007 have a tire pressure monitoring system that alerts the driver to low pressure if the pressure in a tire drops below 75% of the pressure posted on the door placard. Some cars do have sensors that report the actual pressure for display on the dash. Our cars are not among them. Ours just tell the car when the tire drops below the statutory threshold.
Not necessary, but required by federal law.
Old 06-21-2016, 05:08 PM   #45
Dark
Elite Padawan
Dark's Avatar
Originally Posted by extrashaky View Post
You can have all that data. The computer already has it. Just run Torque on a tablet or Android head unit and access it via an OBDII bluetooth adapter. I'm already running a lot of that on my engine monitor.
Nope. The data isn't there. The TPMS units in our wheels are simple on/off pressure switches. They just tell the car to illuminate the idiot light when the pressure drops below the minimum pressure. They don't tell the car anything about the actual pressure until it drops to that level, and then it doesn't tell the car how low it actually is.
If the data were there, you could solve the problem by just reading it in Torque or DashCommand. I wish they could have just left that bullshit off there altogether, but the federal government says it has to be there. Thanks Obama.
So there must be a different kind of TPMS. Toyota Highlander has it, so it would be just another parts bin.
Are there different types of TPS? Is it possible that the sensor is designed to go off a X pressure and signal a warning, kind of like a value or something that closes when psi drops, but doesn't actually read anything? Thus making it cheaper.
What I will say about the Toyota - Subaru relationship in terms of the Twins is that Subaru got the short end of the stick. If I recall correctly, I could be wrong, Subaru was under the impression that they were going to get a AWD option but then Toyota put together a prototype and showed it off to journalists without any AWD capability in the design. At that point Toyota had a % ownership in Subaru and there really was no dropping out of the project.
When you think about marketing, the only thing Subaru about the BRZ is the engine. Everything else was basically dictated by Toyota as far as I can tell. If they could go back I guarantee they would have dropped out of the project.
It's good Subaru didn't drop out. They would have lived in stone age. They couldn't figure how to DI their boxer until Toyota slapped D4S in their FA. Subaru didn't have keyless entry either before 86, and KE they are using on everything in their lineup is Toyota's parts bin. They also change from window mounted side mirror to door mounted side mirror after collaboration. Subaru learned a lot of stuff from this project.
Dark
Dark is offline   Reply With Quote
Old 06-21-2016, 06:11 PM   #46
Originally Posted by Dark View Post
Shouldn't the twin already have TPMS on each corner? They just need to digitize and display the info on screen. Subaru also have that on the feature on their other cars. It's a matter of adding a few lines of code and testing it. R&D's job is to keep making improvement on the products. If it's a low volume product, have a small dedicated group works on it. Not like they create a new feature like Eyesight that would eat up a huge chunk of the resource. Guess Subaru just like to go cheap on everything.
If you read my post thoroughly, I mentioned that adding sensors will not jack up the price from 27K to 40K (13K difference for each car). I also mentioned the twin already have TPMS sensors.
I don't mind them charging a 300-500% profit margin on convenience feature. Toyota and Subaru should ask themselves what they do wrong, why is the car not as successful as muscle cars? Is it the power? Can they make up power number with something else? Is it design? Can they do better with the same money? Is it the standard features and options? Fuji/Subaru and Toyota are not small companies and they obviously can't make their car better overall than competitors.
I'm a Subie owner, and I think Subaru have done a phenomenal job overall, but they can do better on their performance side.
Just my .02
You fixed on the TPMS and missed my point. No matter how cheap or easy it is to do they had to stop adding things at some point. They decided to cut it off at what they had. I have no idea why they picked that point but they did.
If they did everything that each individual would like them to have done it would easily be a $40K car. I was not for one second saying that the sensors alone would cause that price (thought that was clear) but simply that if they did every "it could have had this" it would soon be very expensive.
Besides they need to leave something for the next kick at it so maybe they figured that a pressure gauge would be something for then.
Dark (06-21-2016)
Old 06-21-2016, 06:16 PM   #47
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Too bad Toyota still couldn't fix Subaru's ugly styling trend since about 2006.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Dark (06-21-2016)
Old 06-21-2016, 06:26 PM   #48
Dark
Elite Padawan
Dark's Avatar
I totally get what you were saying. I was just having fun playing devil's advocate.
Tire pressure gauge is a nice to have, not a must have. They should fix the cheap interior on the next gen. before anything else because most 86 out there are daily drivers. You will be surprised how nice the new Corolla interior is compares to 86.
Dark
The Following User Says Thank You to Dark For This Useful Post:
Tcoat (06-21-2016)
Old 06-21-2016, 06:34 PM   #49
Dark
Elite Padawan
Dark's Avatar
Oh god! BRZ is the only decent looking car in their lineup, and it's designed by Toyota.
Another decent looking car is Levorg, and it's not sold in the US because "performance cars are more defined in sedan segment."
Dark
Old 06-21-2016, 06:41 PM   #50
krayzie
Drive From Home
krayzie's Avatar
Humm I fail to see how the Corolla interior is nicer, unless you mean all the faux stitching and chrome rings.
Our cars have a non-reflective soft touch upper dash and Alcantara seating, to me that's much more impressive.
Like I've said before soft touch trims are not hard wearing and it'll look like shit after a few years. For a very focused sports car I quite like the current interior. Okay I admit I can use a nicer glove box for sure.
For example, look at what happened when Toyota went from the first gen IS to the 2nd gen, they completely lost the plot in terms of driving dynamics but they surely *fixed* the interior.
The Following 2 Users Say Thank You to krayzie For This Useful Post:
Mim (06-22-2016), Tcoat (06-21-2016)
Old 06-21-2016, 06:46 PM   #51
LOL Looks can not be debated. The latest gen WRX and STIs are the ONLY Subarus I have liked the looks of and to me the further back you go the uglier they got.
raven1231 (06-21-2016)
Old 06-21-2016, 06:53 PM   #52
Dark
Elite Padawan
Dark's Avatar
I'm talking about dash soft touch material in Corolla. Subaru tends to be more rugged on the dash. Their Legacy is pretty nice, Hope next twins will get similar Legacy interior quality.
I wouldn't say 2IS bad. Everyone said it was bad, but when the 3IS came out, journalists admitted that 2IS chassis was really good but suspension was tuned for comfort.
Dark
Old 06-21-2016, 07:14 PM   #53
extrashaky
... the further back you go the uglier they got.
This wasn't ugly:
But this was:
Old 06-21-2016, 07:25 PM   #54
This wasn't ugly:
I will give you the Brat! Wanted one of them so bad but was dirt poor broke. Turned out for the best since around here they rotted out up to the door handles in about4 years (I am not exaggerating they rusted fast).
Don't think they had the other one here.
Actually the SVX sounds like it was a decent car if you could get past that stupid glass set up. Never heard of it before.
I LOLed at this in the Wikipedia article though:
Old 06-21-2016, 09:07 PM   #55
krayzie
Drive From Home
krayzie's Avatar
Actually there are still a few SVX in mint condition running around in Scarborough. I think they only came with an Automatic gearbox.
I thought Subaru kind of remade the Brat some time ago called the Baja? I've seen a yellow one around here too.
These days a nice interior seems to be just lots of padded leather and faux stitching, or rubber soft touch surfaces. I just can't get by the fact that they are trying to hide the use of really thin cheap plastics underneath.
I much prefer thick textured plastics that don't creak and rattle, and of course authentic leather and thick carpeting, to me that's real quality.
Dam this means I need an old air cooled Porsche 911 Turbo.
Tcoat (06-21-2016)
Old 06-21-2016, 09:28 PM   #56
Never seen an SVX before in my life. I kind of like it except for the fish bowl glass and at 231HP stock in 1991 it was no slouch.
I loved this line though - "All early versions of the SVX sold were equipped with automatic transmissions, as a manual transmission capable of handling the horsepower and torque of the EG33 engine was not produced by Subaru at the time".
The Bajas incorporate every feature that I found ugly in Subaru. I know I will get hate mail but I can not stand those damned oversize fog lights they used for so long.
krayzie (06-21-2016)
2017 Alfa Romeo Giulia (pronounced "Julia") DAEMANO Other Vehicles & General Automotive Discussions 254 03-07-2020 02:49 AM
Tom's Racing Japan tail light information GuerillaRacing Exterior Parts - Lighting 199 06-13-2013 09:53 AM
HOW-TO: Disable "Caution" screen on the head unit? ZILLA Electronics | Audio | NAV | Infotainment 5 06-20-2012 04:49 PM
BRZ JAPAN Prices jazz350 BRZ First-Gen (2012+) — General Topics 0 04-06-2012 04:30 AM
Price information officially released in Japan A Gomez Scion FR-S / Toyota 86 GT86 General Forum 61 01-09-2012 04:11 PM
