Drives: SWP BRZ Limited Manual. 2014
Corrupt SD - blackvue dr650gw-2ch
So, my 64GB is showing 243GB filled. The "/record" folder is filled random corrupt files that can't be deleted.
I attempted to format multiple times using the Blackvue with no success. Anything I should do to prevent this from happening again? Some of the corrupt files. http://imgur.com/a/qVkSX
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#2 |
connect the card to your computer and format it to fat32. it is recommended to use FAT32 for 64GB+ cards in dashcams. you will need a program to format it though, I personally use GUIformat - http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
I believe the blackvue formats cards in exfat and although it works for cards 32GB and under, it doesn't work well with higher memory cards
#3 | |
But, what would cause this kind of corruption? Power discharge? Heat? Software?
#4 |
Contract? /人◕ ‿‿ ◕人\
Try taking off that read-only attribute on the root folder and see what happens.
Also, in your op, you mentioned its a 64 gig SD card, but has 243gigs worth of files??? Typo, I presume? Also, your SD card a SanDisk brand, by any chance? I used to browse the dashcam forum and almost with every dashcam out there, SanDisks don't work well. |
#5 | |
have you tried renaming the card through windows and personally deleting the files? I have never encountered a problem like yours though where the file size is larger than the actual card... worst case scenario is that the card is done for. EDIT: I forgot to mention if you had ran the formatter programs as admin or not.
#6 | ||
It's technically the BlackVue SD card that came w/ my camera. ![]() Quote:
#7 |
Oh, I even tried formatting from the dashcam (holding down the WiFi button) nothing happens. It gives me a verbal saying it's formatting, reboots, no change in data.
#8 |
I think what ryoma posted is the cause of your issues. Just for funsies, insert another SD card if you have one and see if it'll record footage like normal and not produce corrupted files. If that's the case, the SD card right now is simply toast.
| Ecutek Corrupt ECU, Bad Flash, Can i reset? | gdrider77 | Software Tuning | 48 | 07-04-2014 12:25 AM |
| WTB: Blackvue 500 with power magic pro | Simon99 | Audio/Visual, Electronics, Infotainment, NAV | 2 | 05-12-2014 04:07 AM |
| WTB: Blackvue dash camera | Muskokan | Want-To-Buy Requests | 0 | 01-09-2014 05:43 PM |
| Blackvue DR500GW-HD | Foobar | Electronics | Audio | NAV | Infotainment | 62 | 06-21-2013 03:24 PM |
| New Blackvue software for Mac | rbizzle004 | Electronics | Audio | NAV | Infotainment | 1 | 05-30-2013 01:03 PM |
