Old 08-13-2015, 08:08 PM   #71
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
They replaced my steering wheel, and hosed up the clock spring in the process. At least they think the clock spring is the problem! We will see.
czechm8 is offline   Reply With Quote
Old 08-15-2015, 11:06 PM   #72
czechm8
520
czechm8's Avatar
So frustrated with my dealer! Had an appointment today for them to replace the clockspring. They called me an hour later to tell me they needed to order another part.
They seem to be complete idiots about clocksprings!
This will be the third time I've had to go back to the dealer to try and fix a problem they created!
Old 12-03-2015, 08:52 PM   #73
KayC
Drives: 2013 whiteout FRS 6mt
My abs and traction control light just came on too. It started about a week ago. When it first started , I pulled over and restarted the car and that was fine. Then it started to get more and more frequent. Till now it will come on every time I start my car. Also, brake light doesn't work so it's really dangerous to drive.
I have jdm toms and nsidius 3rd brake light mod installed over a year ago and everything worked till now.
Checked tailight fuse and everything is fine. It must be the brake switch. I'll report back if it is.
KayC is offline   Reply With Quote
Old 12-03-2015, 11:09 PM   #74
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Have you changed anything recently?
If so start there and reverse what you did.
Old 12-03-2015, 11:50 PM   #75
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I had my ABS and Traction Control light come on. It was my ABS Actuator.
N1rve
Old 12-04-2015, 02:29 AM   #76
KayC
Did not change anything for over a year. Everything just came all of a sudden. Going to switch my taillight a back to stock and pull the nsidius 4th brake light just in case they blame it on that
Old 03-24-2016, 10:11 AM   #77
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
I had a similar issue where my Traction control and ABS lights would come on randomly. The car would even cut my throttle every so often. When the dash lights were on, I noticed that all my brake lights (except my 4th) were on as if I was pressing the pedal, so I assumed the problem was the brake actuator switch thingy. I have Valenti Tail Lights and the Phasetek 4th kit (tapped into the brake wires), which i was going to disconnect/switch to stock before i took it in to service but i noticed that as I jiggled Phasetek 4th brake light taps, the brake lights function properly and the Traction Control and ABS lights went away. I guess the taps included with the kit are kind of loose and shitty which was causing my issues.
The dash lights had popped up randomly weeks/months after I had made any changes so I never assumed it was the 4th brake light. It would also go away randomly after I restarted the car, up until this week when it was just permanently on no matter how many times I restarted the car. I tightened up the taps and ran the ground wire from the lights to the grounding bolt in the trunk as someone else in a different post had mentioned and so far the issue has gone away.
Shinobu's Smile is offline   Reply With Quote
Old 04-26-2016, 08:54 PM   #78
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Well, I'm getting the ABS & TCS lights now. It first happened about a month ago ND went away when I restarted the car. I happened again a couple of weeks later, and is now coming on almost every time I drove the car.
I was dropping off my car to have the clutch replaced this morning. The lights came on as soon as I backed don't of the driveway, so I was able to have the mechanic diagnose he car without shutting it off. It came up as a faulty stoplamp switch. I haven't had a chance to mess with the switch but will soon.
kmbkk is offline   Reply With Quote
Old 04-27-2016, 07:44 AM   #79
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
One other thing I failed to mention was my left turn signal indicator illuminated steady as well.
They all came on again this morning. However, I was able to get the turn signal indicator to go out by mashing on the brake pedal a few times quickly.
Old 04-28-2016, 05:31 PM   #80
beloden
beloden's Avatar
Drives: 13 brz, F ranger
for me it was abs sensor connection got loose on the front passenger side under a fuse box, had to put a zip tie over it because it would not stay in on its own. problem fixed for me, but took a while to find it!
beloden is offline   Reply With Quote
The Following User Says Thank You to beloden For This Useful Post:
Moto-P (08-02-2022)
Old 05-16-2016, 11:52 AM   #81
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Are you talking about the fuse box under the hood? I changed the stoplamp switch with no luck, so I'll continue looking at other possibilities.
Old 05-25-2016, 09:49 PM   #82
brzmar
Drives: Subaru BRZ limited
Replace the " SWITCH-STOP LAMP" my car had similar symptoms. Smell your switch mine was burnt in one of the contacts inside the switch
Subaru Part# 83311FG000
brzmar is offline   Reply With Quote
Old 05-26-2016, 08:37 AM   #83
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yep, that's the one I changed. Mine didn't smell burned nor did the contacts look bad.
Old 06-18-2016, 04:23 AM   #84
tim35ct
Drives: 2013 Black Brz Premium 6sp
i just had mine fixed it turned out to be an adjustment with the brake pedal sensor or switch. there is a tsb on this issue according to what they wrote in the notes on the repair bill.
tim35ct is offline   Reply With Quote
Traction/VSC Setting Preference ashtray BRZ First-Gen (2012+) — General Topics 27 08-24-2018 03:39 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
