Old 04-14-2014, 09:17 AM   #15
kevman_101
Drives: 2013 Scion FRS
Mine does it too. It's the inside wheel that tries to turn too quick and looses traction a bit. Turn on a dirty street and you will hear the rocks slide instead of having the tires grip and jump on clean pavement. Find a buddy that has a car or a truck with a welded rear end. That is to the extreme.
kevman_101 is offline   Reply With Quote
Old 06-17-2016, 10:20 PM   #16
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I just changed the fluid in my diff motul 300. Never noticed it before but I noticed it now. I know the fluid level is correct also. Does it when I'm stop and slightly turn as soon as the clutch full disengages it will give a noticeable rumble. Nothing crazy though. Idk I hope it's ok lol. @Tcoat
tofurun is offline   Reply With Quote
Old 06-17-2016, 10:32 PM   #17
As many others have said, works as designed. Should feel the clutch diff turning a corner in my brother's 911, total rumblefest. #becauseracecar
Old 06-17-2016, 10:42 PM   #18
I concur. I can pretty much make it happen on command. Odds are it has always done it but you were paying more attention after changing the oil so are just noticing it now. Don't sweat it all is good.
Old 06-17-2016, 10:45 PM   #19
It's fun when I goose it just enough to lock it and get the inside wheel to chirp a little.
...because I'm still 12 on the inside.
Old 06-17-2016, 10:54 PM   #20
The is a brief window in the spring where the roads are bare and dry yet still have the sand on them from the snow. Pretty much every turn can create that 'cuz I am also pretty much 12.
Old 06-17-2016, 10:59 PM   #21
Hee hee...
Old 06-18-2016, 12:43 PM   #22
gravitylover
Heh, I actually (finally) made it to 17 so I'm old enough to drive and chirp my rear tires.
Unfortunately I must be fooling myself though because I often forget to turn off the nannies and the wheels won't spin so it doesn't really make the noises that the OP was talking about.
Old 06-18-2016, 02:51 PM   #23
Nannies take longer than that to process all the inputs and react. I bet it's real. <--root beer for you.
Old 06-18-2016, 05:15 PM   #24
gravitylover
Ooh root beer... Yay! Mix it with a scoop of French vanilla ice cream and 2 shots of spiced rum and ya got a Big Boy Float
Pulley? Violently Shaking? 636 Issues | Warranty | Recalls / TSB 15 05-14-2018 11:54 PM
Doors shaking like a mother empower-auto Electronics | Audio | NAV | Infotainment 16 10-08-2013 11:30 AM
shaking of car Adam86 AFRICA 3 05-17-2013 08:42 AM
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 09:42 PM
CEL Blinking/Hard Shaking. _F-R-S_ Issues | Warranty | Recalls / TSB 4 09-16-2012 07:43 PM
