Old 06-13-2016, 10:27 AM   #1
armstrom
Drives: none
Is there a Subaru TSB for the direct injector seals?
I've searched extensively but cannot find a Subaru TSB for the detonation issue at throttle tip-in that causes injector seal failure. Does such a thing exist? I've seen the Toyota TSB from South Africa that's floating around but somehow I doubt my local Subaru dealer will care about that one bit I'm having the detonation problem on my 2013 BRZ and am planning to take it in to the dealership this week so I would like to be prepared.
Thanks!
-Matt
armstrom is offline   Reply With Quote
Old 06-13-2016, 10:39 AM   #2
Thanks!
-Matt
http://www.ft86club.com/forums/attac...1&d=1375302652
http://www.ft86club.com/forums/showthread.php?t=21868
Old 06-13-2016, 11:26 AM   #3
armstrom
Drives: none
Thanks for the reply! I had actually found that one already but that's related to the cam shaft sensors. This issue is specifically related to the ECU mapping being incorrect at throttle tip-in during shifts and whatnot.
edit: Ugh.. apparently I can't link to another forum... This thread discusses the problem in detail and the youtube video linked there shows the toyota of south africa TSB at the beginning. http://www.ft86club.com/forums/showt...ica+detonation
-Matt
Old 06-13-2016, 11:48 AM   #4
-Matt
It is sort of buried in that one but this addresses the misfire issue that was taking out the injectors as well as several other items.
If you are talking just the ECU flash then there may be no TSB for it but the dealer shouldn't put up any fight in just giving you the latest version.
Old 06-13-2016, 02:31 PM   #5
armstrom
Drives: none
Yeah, I'm not worried about getting the flash.. I'm worried about getting them to inspect (and replace, if needed) the injector seals. Just getting to them to check if they're damaged is a pain. The fact that I get an occasional backfire and consistent detonation would indicate to me that the seals are damaged. I just need to convince the dealership of that as well.
-Matt
Old 06-13-2016, 02:37 PM   #6
-Matt
Which is exactly why I point you to the cam TSB that fixes the misfires. Even if the seals are blown you still need to tackle what may have caused it in the first place.
do the direct injector seals need to be replaced? Astroboy Engine, Exhaust, Transmission 17 04-15-2015 06:01 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
