Old 05-30-2016, 04:28 PM   #1247
bababooey
Drives: BRZ SWP Limited -6MT
thank you sir for looking that for me. I was satisfied with the previous OTS uel tune but thought to try this as it seemed others with non OFH were seeing good results. id rather be on the safe side.
bababooey is offline   Reply With Quote
Old 06-03-2016, 08:54 AM   #1248
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I am going to upload some logs later on tonight, if anyone can take a look i would appreciate it. I have been trying to get in touch with with my tuner so that I can verify my car is running properly. but has been a week with no answers.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 06-03-2016, 09:09 AM   #1249
nickmerronesucks
Ned flanders
http://datazap.me/u/nickmerrone/run-2?log=0&data=1-13
http://datazap.me/u/nickmerrone/52916?log=0&data=1-13
797Performance.com
Old 06-03-2016, 09:09 AM   #1250
nickmerronesucks
Ned flanders
DOUBLE POST
797Performance.com
Old 06-03-2016, 07:51 PM   #1251
nickmerronesucks
Ned flanders
anyone?
797Performance.com
Old 06-03-2016, 11:31 PM   #1252
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by nickmerronesucks View Post
anyone?
I'm no expert, especially on boost and what your AFR should be (11 at WOT would be rich for NA but seeing as you're boosted it's probably good and safe)
But as far as safety, no knock in that log and IAM is at 1 so that's good.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
nickmerronesucks (06-03-2016)
Old 06-12-2016, 08:10 AM   #1253
Silver86K
Drives: Silver 86
Here is a datalog of mine:
Any advice
http://www.datazap.me/u/86driver/sas...?log=0&data=20
Silver86K is offline   Reply With Quote
Old 06-12-2016, 09:20 AM   #1254
randomthoughts
Drives: 2014 White BRZ
OFT Data Logs
Here are two pulls running OFT Stage 1 91 tune with 91 Oct PetroCan fuel.
One if from 2nd gear and the other is 3rd gear.
I can attached a datazap link if that works better.
randomthoughts is offline   Reply With Quote
Old 06-12-2016, 04:10 PM   #1255
G-awesome
Drives: 2015 Firestorm Scion FRS
Talking
After two months of researching and testing, finally got my stage 2 custom tune dialed in with my JDL UEL catted header on Shell 91oct gas! (well 99%...still got a bit of consistent knock in a few areas but I can take a bit of timing out)
http://www.datazap.me/u/gawesome/201...576-669-91-165
I'm running a bit on the richer side during the WOT pulls in the 2000-5000rpm range. Should I adjust it so that it's closer to commanded AFR of 12ish:1 or just leave it as it?
Big thanks to wayno, steve99, kodename47, solidone (and anyone else I missed) that wrote the guides, provided the tools and helpful advice! The knock correction spreadsheet by kodename47 is a fantastic tool to sort out datalogs!
I'm excited to dial my tune in for Chevron 93 octane next!
G-awesome is offline   Reply With Quote
Old 06-12-2016, 06:57 PM   #1256
Randomfool
Drives: 2015 FR-S
http://www.datazap.me/u/randomfool/e...=0&data=1-7-13
Can someone let me know how my AFR look. They seem to me to be pretty rich compared to the command AFR. To adjust that would I scale the MAF? I took that log and put it in vgi's tool and it increased the values in closed loop but decreased in open loop. I would think if the AFR is rich in both closed and open loop they should be both changed in the same direction? But I may be confused about what effect scaling the MAF has.
Car is pretty much stock except K&N filter and I'm running E85.
Randomfool is offline   Reply With Quote
Old 06-12-2016, 07:42 PM   #1257
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You shouldn't need to scale the maf if you copy the scale from any of the "US.Lean" roms in the examples thread below.
Old 06-12-2016, 07:48 PM   #1258
Wayno
Wayno's Avatar
There's no point de-tuning timing until you fix the fuel.
The Following User Says Thank You to Wayno For This Useful Post:
G-awesome (06-12-2016)
Old 06-12-2016, 07:59 PM   #1259
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yes, it would be better.
Intent > Content
Old 06-12-2016, 08:08 PM   #1260
randomthoughts
datazap
http://www.datazap.me/u/randomthough...10-105-115-113
I post it on ECU logging as well.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
