#71 |
Drives: '13 BRZ
http://www.subaru.com/2017-brz-series-yellow
![]() ![]() ![]() ![]() June 12, 2016 SUBARU ANNOUNCES 2017 BRZ SERIES.YELLOW SPECIAL EDITION Limited production of 500 units –Available 2017 Exclusive yellow exterior color Unique yellow interior accents Brembo performance brake system SACHS performance shocks Cherry Hill, N.J. - Subaru of America, Inc. today announced the 2017 BRZ Series.Yellow, the most exciting BRZ to date with its striking color and performance upgrades. The special edition, limited to only 500 cars, will debut today at Wicked Big Meet in Stafford Springs, CT. The Series.Yellow is immediately recognizable by its brilliant yellow exterior, unique black alloy wheels, black BRZ and SUBARU badging, and black foldable exterior mirrors. Based on the 2017 Limited model equipped with the new Performance Package, the Series.Yellow enhances a driver’s experience with superior stopping power and control. The brake system has been upgraded to Brembo® four-piston calipers and rotors on the front and dual-piston calipers and rotors on the rear. This advanced system gives the yellow sports coupe a significant boost in stopping power, fade resistance, and pedal feel. SACHS® Performance shock absorbers have been added to all four wheels for advanced handling and steering stability. Also the special edition comes equipped with 17-in x 7.5-in black aluminum alloy wheels. The Series.Yellow offers black leather and Alcantara upholstery with contrasting yellow stitching throughout the interior including seats, door and dash panels, steering wheel, knee pads and shifter boot. The front seatbacks are also embroidered with a yellow BRZ logo. The final touch for this model is the carpeted floor mats with yellow stitching and a silver embroidered BRZ logo. Performance The BRZ, known for its ultra-low center of gravity and precision handling, offers several updates for 2017 to increase performance on the track and open roads. For improved responsiveness, BRZ receives updated coil springs and a larger rear stabilizer bar and the Series.Yellow gains the additional upgrade of SACHS Performance shock absorbers. Reinforcements to the chassis were added to the strut tower braces, transmission cross-member plate and the rear wheel housings to increase rigidity. The stability control system has been updated to allow the driver to experience more of BRZ’s handling prowess. The results are dramatic enough for Subaru to change the name of “Sport” mode to “Track”. The BRZ Series.Yellow comes standard with the 2.0-liter SUBARU BOXER engine and 6-speed manual transmission. Enhanced for 2017, BRZ’s horizontally-opposed engine receives several internal updates for friction reduction as well as a new aluminum intake manifold and redesigned exhaust manifold. These combined improvements boost the engine output to 205-hp and 156 lb-ft of torque. Also, a lower final drive ratio from 4.1 to 4.3:1, paired with the standard Torsen® limited-slip differential, improves acceleration. Exterior Updates For 2017, the BRZ front bumper cover has been redesigned for a widened appearance and positioned lower for improved aerodynamics, control, and stability. The sport coupe’s headlights are upgraded to “kono-ji” style LED with Daytime Running Lights (DRL). The turn signal and position light have been integrated into the new headlight for a clean design that completes the refined front fascia. New LED fog lights allow greater nighttime visibility and are standard on the Series.Yellow. The updated fender garnish matches the body color but with a black insert that accentuates it in profile. All 2017 BRZ models receive a pedestal-style aluminum rear spoiler in matching body color and black finish. The new design improves the vehicle’s downforce, which in turn improves stability and control. As with the headlights, the rear combination lights have been updated to full-LED for better visibility and energy efficiency. Interior Updates Standard for the special edition is a 4.2-in LCD multifunction display positioned to the right of the prominent tachometer. This driver information readout provides access to vehicle performance including lateral Gs, accelerator pedal position, braking force, steering angle, oil and water temperature, and battery voltage as well as an integrated stop watch for recording lap times. The redesigned leather-wrapped steering wheel has a firmer, sportier feel along with new audio controls and multifunction display switches for greater control and convenience while driving. All 2017 BRZ models come standard with the SUBARU STARLINK™ 6.2” Multimedia System that includes a comprehensive list of features: 6.2-in. high resolution multi-function touch screen display AM/FM stereo and HD Radio® Single-disc in-dash CD player with 8 speakers Subaru STARLINK smartphone integration with Pandora® and Aha® Subaru STARLINK apps including iHeart® Radio and Stitcher™ Bluetooth® hands-free phone connectivity and audio streaming SiriusXM® Satellite Radio Rear vision camera Also standard on this model is a dual-zone automatic climate control, Keyless Access with Push-Button Start, dual illuminated visor vanity mirrors, and front door courtesy lights. The BRZ Series.Yellow makes its first public appearance at one of the country’s largest Subaru enthusiast festivals, Wicked Big Meet, which is held at Stafford Motor Speedway in Stafford Springs, CT on June 12th. The Series.Yellow will arrive at retailers in 2017. |
| The Following 5 Users Say Thank You to Axel For This Useful Post: | Elleteeh (06-12-2016), Extreme86 (07-02-2016), Hyper4mance2k (06-13-2016), NemesisPrime909 (06-12-2016), raven1231 (06-12-2016) |
#72 |
Drive From Home
Drives: BRZ STI Performance
| The Following 2 Users Say Thank You to krayzie For This Useful Post: | Hyper4mance2k (06-13-2016), raven1231 (06-12-2016) |
#73 |
Drives: Da-Big Banana
The color is the only thing that makes it "Limited" the parts are available for all of the other brz models.
#74 |
-Proud of Brzerhood-
Drives: '17 BRZ CWP LMT.
[ame="https://www.youtube.com/watch?v=MYKXWgHgqUQ"]FT86Club 2017 Series. Yellow BRZ - YouTube[/ame]
We had a malfunction with the camera, we will have a higher quality posted later. Photo can be found here: 86EXPO Facebook page
"The BRZ Section's fine wine" -Zgrinch Last edited by Zaku; 06-12-2016 at 04:17 PM. |
| The Following 7 Users Say Thank You to Zaku For This Useful Post: | Axel (06-12-2016), Elleteeh (06-12-2016), Hyper4mance2k (06-13-2016), krayzie (06-12-2016), M.I.A (06-14-2016), NemesisPrime909 (06-12-2016), Reign (06-12-2016) |
#75 |
"The BRZ Section's fine wine" -Zgrinch |
| The Following 4 Users Say Thank You to Zaku For This Useful Post: | Elleteeh (06-12-2016), Hyper4mance2k (06-13-2016), NemesisPrime909 (06-12-2016), raven1231 (06-12-2016) |
#76 |
Sarcastic SOB
Love the new wing! Not a yellow car fan but this might have just changed it for me. I prefer this versus the RS1.
#77 |
Site Moderator
Drives: ichi 86 Project
Our 86EXPO crew will go on live at WBM in 10mins, stay tuned!
#78 |
Drives: TBD
I'm kind of happy that the S.Y is nothing but a Limited with Performance Pack in drag, makes it easier to pass up. If it offered any real upgrades it would make a choice difficult - the downside for me is that I don't find that shade of yellow very appealing.
The splash of lighter yellow in the interior is very well done though, just the right amount. Too bad they didn't use that lighter shade for the paint as well. |
| The Following User Says Thank You to Sport-Tech For This Useful Post: | Elleteeh (06-12-2016) |
#79 | |
Drives: '15 BRZ RA
| The Following User Says Thank You to nikitopo For This Useful Post: | why? (06-12-2016) |
#80 |
Drives: DGM BRZ
Codename 'booger' - thanks for the pics
#81 |
| The Following User Says Thank You to Kostamojen For This Useful Post: | ajaxthebetter (06-12-2016) |
#82 |
Site Moderator
Our 86EXPO crew are working hard taking photos...
[IMG]https://uploads.tapatalk-cdn.com/20160612/2f0f***7529a55187b2acc6f6a4eec92.jpg[/IMG] & like this ![]() Hm... we'll post more as we go through the day |
| The Following 3 Users Say Thank You to ichitaka05 For This Useful Post: |
#83 |
Drive From Home
Gotta milk your money with this special color offering first (car just got facelifted, don't pull out all the cards yet), save some bullets for the next year or two when they'll throw a few STI bits onto it.
If sales really tank near end of life they might bring out a BRZ STI to go out with a bang. Most car makers go with this same tactic. |
#84 | |
Drives: Wrb 2014 limited brZ
| Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks | Kyogre | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 05-12-2015 04:59 PM |
| WTB: Koni yellow struts and RCE yellow springs | nlowell | Brakes, Suspension, Chassis | 2 | 05-20-2014 03:10 PM |
| scion yellow release selease series | Mrqb22 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 05-15-2014 11:59 AM |
| -Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! | OrbitalEllipses | Mid-Atlantic | 21 | 06-14-2013 12:10 PM |
