Old 06-10-2016, 02:24 PM   #99
Hicklinc
Drives: N/a
Originally Posted by JGalp View Post
I would love to agree, but i have def experienced roughphy 5mpg loss, and this isn't getting on it every chance i get, its about a 50/50 mix of highway and city and me trying to drive conservatively, still getting about 21mpg which is me driving fairly conservatively. when i first got it i got lower MPG cuz well it was fun testing it out. I'm assuming this is about normal though. are most peoples MPG around 20-22 in 50/50 city/hwy driving conditions
E85
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 06-10-2016, 09:17 PM   #100
JGalp
Drives: 2015 CWP BRZ Limited
Originally Posted by Hicklinc View Post
E85
JGalp is offline   Reply With Quote
Old 06-11-2016, 12:26 AM   #101
Hicklinc
Drives: N/a
Are you running e85
Old 06-11-2016, 07:46 PM   #102
JGalp
Are you running e85
No I'm just running the carb tune stock everything engine wise. Only recently added a cat back left all cats in place
Old 06-13-2016, 09:47 AM   #103
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Why are you second guessing? Reliability? Performance? An NA engine swap will be inherently more complex and less reliable.
I am still researching to be honest. I have been looking to see what tranny options are available here lately. My local shop is pushing me down the supercharged route.
Fenix is offline   Reply With Quote
Old 06-13-2016, 09:52 AM   #104
Ashikabi
Ashikabi's Avatar
I'm betting you can pick any transmission you want and just get a custom drive shaft made up by Drive Shaft Shop to mate to the differential
Old 11-23-2016, 10:35 AM   #105
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
This is a great thread with a lot of good information.
I had decided on JRSC as it seemed like the most reliable, well-engineered kit on market. When Edelbrock was released, it appeared to be similar quality. Seems you can't go wrong with either. However, I moved towards wanting the Edelbrock more, since it seemed have more potential for big numbers, especially going with a built motor, e85, high boost pulley, etc.
I think the release of the JR c38 kit changes that. In the above posts, are people comparing the JR c30 to the Edelbrock? Or the C38?
For me, it's coming down to the following questions... Looking for some feedback for the C38... That is the only version of the JR I am considering.
1. With more supporting mods (e85, hbp, fuel injectors, fuel pump, built motor, etc) how would the JR C38 compare to Edelbrock, in terms of numbers or drivability?
2. Ease of install: can we get more opinions on this? I want to do it myself. I have time (car is not my DD) and some basic experience with bolt on mods ( Exhaust, suspension). But I want to learn more, and the only way too do that is to jump in head first. That said, I want something that is Well thought out, easy enough to build and troubleshoot, for a first timer. It seems the JRSC is the winner here, but I want more opinions on that.
3. Use case: I want the car to be a fun street car, but i also autocross 6 to 8 times a year, and want to start doing track days. For this use case, which kit makes sense? My eventual goal will be a dedicated track / autocross car, shooting for 400+ hp, would love to someday hit 500.
4. Reliability. Haven't heard about many problems with JRSC, but some issues with Edelbrock were presented earlier in this thread. At the higher hp levels, would one kit outshine the other in terms of reliability? I know reliability will suffer with more power, but I'm thinking more along the lines of overall reliability, from initial install and onwards thoughout the entire build.
Thanks. I've been reading this forum for months and almost never post here... So am genuinely hoping for some good advice.
BR-ZED is offline   Reply With Quote
Old 11-23-2016, 11:48 AM   #106
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I just went FI and was deciding between the Edelbrock and JRSC kit.
As far as installation, the JRSC kit seems a lot less involved in comparison to the Edelbrock kit. However, the instruction manual for the Edelbrock kit shows every step with an accompanying picture while the JRSC manual has less pictures.
I installed the Edelbrock kit by myself over the course of 2 days with about 10 hours of work. I would not recommend doing the install solo.
I would estimate that I could install a JRSC kit within 5-6 hours.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
BR-ZED (11-24-2016)
Old 11-23-2016, 12:01 PM   #107
CSG Mike
CSG Mike's Avatar
1. Both kits tap out at approximately 550whp, with a full host of supporting mods. Driveability is not determined by the kit, but rather, the tune that ties all the parts together.
2. The JRSC is a shorter install; the Edelbrock kit ultimately breaks down into a lot of simple steps. The Edelbrock really requires 2 people to safely put the manifold on the engine (and only for this step).
3. The Edelbrock kit is superior for bursts of power and competitive Autox (water can absorb heat faster than air), but the JRSC is superior for long term sustained power on track (air holds less heat to be dissipated). If you're not looking for every last bit of power, than this is moot.
4. Again, your power level will dictate reliability, not the kit. Both kits are rock solid reliable.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
BR-ZED (11-24-2016), brzaapi (11-23-2016), mrg666 (11-23-2016), Toyota GT 86 (11-27-2016)
Old 11-24-2016, 09:35 PM   #108
BR-ZED
BR-ZED's Avatar
Thanks for replies... More food for thought.
It seemed earlier the thread that the Edelbrock kit might prone to install errors, and that the tune wasn't refined. Is this still an issue? If not, what was the resolution?
Old 11-24-2016, 09:52 PM   #109
menikmati
I did not have any installation errors, but most of the ones present in the Edelbrock owners thread involve vacuum leaks, especially the ones on the EVAP solenoid. I made sure that every hose had a clamp on it.
I ran the CARB tune for about 200 miles and experienced some of its quirks. The idle would hunt around between 500-1.1k RPM. At first I thought it was a vacuum leak or installation error but the idle hunting was solved by a different tune. The throttle response mapping wasn't as sensitive as I wanted it to be, making taking off smoothly in 1st gear difficult. I noticed that the power delivery when transitioning from 4k RPM and above was somewhat abrupt and the problem was resolved once again by getting a different tune.
The Following 2 Users Say Thank You to menikmati For This Useful Post:
BR-ZED (11-24-2016), paiceyfan (11-24-2016)
Old 11-24-2016, 11:06 PM   #110
BR-ZED
BR-ZED's Avatar
So were the new tunes provided by Edelbrock ( updated carb tunes), or were they tunes you had custom done by your tuner?
Old 11-24-2016, 11:29 PM   #111
menikmati
I'm currently running the Edelbrock tune from Delicious Tuning.
Old 11-25-2016, 02:10 AM   #112
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
*SNIP*
550WHP? Highest I've seen was around 400 WHP on both edelbrock & a C38 with HBP. How would 550WHP be achievable?
I'm guessing you're referring to the limit of the supercharger itself...
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Jackson Racing Kit AT6 CladMonitor Forced Induction 26 06-27-2014 10:27 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
