Old 06-10-2016, 02:56 PM   #1
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
warning about Walnut Creek Toyota
I recently had my transmission replaced under warranty with these guys and when I got my car back they had cross threaded my shifter knob (minor obviously), they installed the shifter plate backwards so I needed to lift the shift lock collar to even get into 1st gear...then when I finally got it back there was a rattle sound coming from it. I told them to check it out but they denied it because they blamed the rattle on my after market exhaust. So I took my car to a local car shop that we deliver to (I work at a dealership also)for a second opinion, they discovered a sheared stud and a crack in my block due to improper installation. So needless to say I will be going back there and demanding they fix the car and if they try to deny my then I will be pressing charges.
Do not go to Walnut Creek Toyota in CA east bay. Crooks.
driftartist is offline   Reply With Quote
The Following 5 Users Say Thank You to driftartist For This Useful Post:
86kahl (06-10-2016), FirstWinter (06-11-2016), FX86 (06-10-2016), Guff (06-11-2016), Packofcrows (06-10-2016)
Old 06-10-2016, 05:05 PM   #2
ryoma
ryoma's Avatar
post this in your local section too if you haven't already
The Following User Says Thank You to ryoma For This Useful Post:
fumanchu1 (06-10-2016)
Old 06-10-2016, 08:54 PM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Yeah. I took my car in for the tob as it was closest dealer. They said all is well. Took it again. They were annoyed by it and had horrid customer service. I ignored my issue for a couple of weeks, then took to closer dealer where I live. They found bad tob and placed new one. WC Toyota is known for selling crashed vehicles as clean title and doing crook jobs as you put it. I reported their bad service and refusal service to Scion in LA. Dont know if anything will/did happen but I encourage you to do the same. Voice your issue.
Old 06-10-2016, 11:24 PM   #4
stevesnj
stevesnj's Avatar
Call SCION first. Explain what happened, they are very good and helpful usually and will start a case for you. Go up the chain of command.
http://toyota.custhelp.com/app/answe...ntact-scion%3F
My 2016 Build thread
Old 06-11-2016, 03:12 AM   #5
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
They usually let the 1st year guys do the warranty work.
Muaddib is offline   Reply With Quote
Old 06-11-2016, 04:46 AM   #6
Rest assured I Will NOT be using their services!!!!!!!!!
strat61caster (06-15-2016)
WARNING: Cambridge Toyota BRUTAL SERVICE tiz22 CANADA 54 10-30-2014 09:31 AM
Walnut Creek, CA Lounge Suggestions! 1SIKFRS Off-Topic Lounge [WARNING: NO POLITICS] 0 11-23-2013 08:21 PM
Stock Wheels and Tires (SoCal, Walnut) davidshu0327 Wheels and Tires 1 03-02-2013 07:13 AM
WARNING! TOYOTA (TMCA) is watching! Be careful what you post online! Psyco AUSTRALIA 127 10-24-2012 03:45 AM
Toyota 86 Subaru BRZ Hyper Magazine meet in Japan (warning pic heavy (56k beware)) tecnica tech FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 04-18-2012 02:01 PM
