#491 | |
Drives: Harrop TVS86 STi BRZ tS
Do you remember off the top of your head or where I might find the torque specs for the tS rear subframe bolts? I'm finally getting around to installing them with the collars. Thanks!
#492 |
We torqued them to around 107lb-ft, if I remember correctly. I don't recall if that is the stock spec, but I believe whiteline specified it.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#493 |
Many thanks!
#494 |
Drives: 1980 corvette, 2014 Subaru BRZ
Now for the question everyone wants to know...
How will you fit the new series yellow spoiler on the trunk too?
| The Following 2 Users Say Thank You to G-Man For This Useful Post: | chanomatik (06-13-2016), Hostile_Kittens (06-14-2016) |
#495 |
Drives: '24 GR86
You don't. You smash it with a hammer, Office Space style, throw it in the trash, and the nuke the zip code in which said trash can is located, because it's disgusting.
#496 | |
@dsomegax.cars
| The Following User Says Thank You to DSOmegaX For This Useful Post: | G-Man (06-14-2016) |
#497 | |
Snow Don't Hurt!
Sent from my SAMSUNG-SM-G925A using Tapatalk
#498 |
![]() Here comes show season!
@dsomegax.cars
#499 |
Drives: '15 BRZ RA
#500 |
The next project incoming! Stay tuned
@dsomegax.cars
| The Following User Says Thank You to DSOmegaX For This Useful Post: | Mr.Impreza (09-04-2016) |
#501 | |
#502 | |
The most important part that I remembered was adjusting the length of each one to 370mm before installing it. I believe it's shipped out to you set at 366. Otherwise, the install was straightforward. Torque to spec at the locations specified.
@dsomegax.cars
| The Following User Says Thank You to DSOmegaX For This Useful Post: | kuczynskika (07-06-2016) |
#503 |
Drives: '13 LAVA - lightly modded
Awesome build man.
Know you did the engine and transmission mounts along with some other things but would those two things still be liveable for a daily driver in traffic occasionally etc? Would you say they made a Noticeable difference in responsiveness? Sent from my iPhone using Tapatalk
You are going to be condemned to live out the consequences of your taste - TM
#504 | |
NVH is dependent upon which mounts you're using. STI uses harder durometer rubber, not polyurethane. Thus, its still comfortable. It made a difference in overall stiffness, but nothing that you can't live wit; honestly, it's still more comfortable than a stock WRX STi IMO. Going up to polyurethane would be a different story though.
@dsomegax.cars
| Completed build | JK21 | Member's Car Journals | 46 | 12-11-2014 09:48 AM |
| Completed!! FBM 700+HP Build Dyno graph & Vid inside | FullBlown | Forced Induction | 214 | 03-31-2014 01:56 PM |
| Vinyl wrap completed!! | laley81 | Southern California | 14 | 08-30-2013 11:10 PM |
| Nearly Completed my Firstorm Build - Lots of Pics | msile | Member's Car Journals | 52 | 03-10-2013 10:25 AM |
| Turbo FRS completed! | Philly | CANADA | 24 | 09-03-2012 09:18 AM |
