Old 06-10-2016, 06:41 AM   #253
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by VitViper View Post
You can... the logic is similar to the torque graphing "eDYno" software I wrote (much better than Virtual Dyno as I don't use their graph smoothing algorithm lol)... the limitation with the software dynos is they go off acceleration measured off driven wheel speeds (engine rpm)... which is susceptible to a lot of fluctuation with wheel slip (once you make enough power) and I've found the "faster" your car is the harder it is to get a clean graph (IE, 700whp+ cars accelerate so fast the sample rate of most datalogers suck and driven speed usually has a lot of slip).
Currently I have the ECU sampling and calculating at 50hz, which should be more than plenty... but if not I can certainly run it faster
Obviously you can skew the results if you want to though.. grab some gears down a big down hill grade... lol
I can already see the 1200 hp FA20's being built.....Some with stock rods.....lol
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
DustinS (06-24-2016)
Old 06-10-2016, 12:02 PM   #254
johan
Drives: '14 981CS, '99 NB1
Vit wrote a software dyno 7 years ago when we were both in the 8thgen Civic Si scene - trust me, we had some _high_ hp NA Civics come out of the wood work back then
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
CSG Mike (06-10-2016), FRS Justin (06-10-2016)
Old 06-10-2016, 12:29 PM   #255
beat1
beat1's Avatar
Drives: 2022 BRZ
ha! Good times. None of them could back up their numbers at the track while I was trapping 102mph with *only* 202whp e-tuned by Vit.
beat1 is offline   Reply With Quote
The Following User Says Thank You to beat1 For This Useful Post:
Old 06-10-2016, 12:29 PM   #256
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You can always add vehicle inclination to the dyno calcs.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 06-10-2016, 12:32 PM   #257
johan
Yup, and then I was the guy with a car that had never seen a dyno and was doing 11's @ 117 with the stock clutch / header / exhaust
The Following User Says Thank You to johan For This Useful Post:
Old 06-10-2016, 12:42 PM   #258
FRS Justin
Ya we have a few of those guys floating around here too.
(put a fart can on a stock civic and gained 1.5 seconds in the 1/4 smh)
710whp
Old 06-10-2016, 01:03 PM   #259
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Where is @Drift-Office in all this. BOB chime in! I want to hear your opinion.
slyphen is offline   Reply With Quote
Old 06-10-2016, 01:38 PM   #260
VitViper
Drives: '15 FRS
Indeed you can -- especially since I run an IMU. Just need to figure out the math for this. Regardless it won't stop people from skewing the results if they want to (zero the IMU wrongn... unplug it...)
Hm, I want to hear @sachu 's opinion, it's just as relevant.
VitViper is offline   Reply With Quote
Old 06-10-2016, 01:53 PM   #261
slyphen
Drives: Man
As far as i know. Bob has been dailying his FRS at 450whp for over a year. As for if hes running E85(likely) or built engine, that im not sure.
Old 06-10-2016, 05:49 PM   #262
EAGLE5
Dismember
EAGLE5's Avatar
With some work, you might not even need to dyno on the same stretch of road. Working in a slip factor might help there, too. As for fakers, who cares?
Old 06-10-2016, 06:36 PM   #263
VitViper
Drives: '15 FRS
You can monitor the wheel slip difference in the ecu too, of course lol
Old 06-10-2016, 09:34 PM   #264
EAGLE5
Dismember
EAGLE5's Avatar
Yeah, I know. I'm just saying that you can make the dyno more sophistimicated.
Old 06-12-2016, 04:21 PM   #265
VitViper
Drives: '15 FRS
Well if anyone was wondering, the trans is definitely weaker than the motor. 3rd & 4th collar are probably scarred from all my power shifting. Takes considerable force to get in and out of those gears now. hahaha
Old 06-12-2016, 04:41 PM   #266
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The price of awesomeness. I have yet to see specifically how anyone has addressed the rocker arm quality control. Is that still hit or miss?
2013 White Turbo FR-S (450whp) (Update) (For Sale Again) Synack Cars for Sale/Trade 40 02-27-2016 12:55 AM
2006 STi 450whp $25000 JoeShmoe Cars for Sale/Trade 0 08-28-2014 04:46 PM
450whp Turbo FRS - TR3 Performance JPxM0Dz FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-19-2014 12:40 PM
Auto-Craft Japan Turbo FT86 BPAuto Forced Induction 5 05-21-2013 10:57 AM
ft86 turbo RWD or AWD? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 31 01-18-2010 04:11 AM
