Old 06-02-2016, 01:30 PM   #3907
Beechnut87
Drives: White 2015 Series Blue BRZ SC
Alright new mount is here and installed, WAY BETTER.
Beechnut87 is offline   Reply With Quote
Old 06-02-2016, 05:25 PM   #3908
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
That looks great
Freeman is offline   Reply With Quote
Old 06-03-2016, 11:13 AM   #3909
vgi
Drives: frs
@Sgtfluffy16 congrats
vgi is offline   Reply With Quote
Old 06-03-2016, 11:16 AM   #3910
vgi
Drives: frs
so, can we list all revisions to the KW kit so people would know what has been updated?
the only ones I'm aware of is:
1. smooth pulleys were replaced with cogged pulleys
2. crank and blower pulleys were replaced with bigger diameter ones and longer belt
3. rotrex oil reservoir mounting location changed - new mounts
4. a new wider pulleys/belt set coming???
Old 06-03-2016, 01:48 PM   #3911
vgi
Drives: frs
@DVO and other folks who don't run speed density tunes (@AZbrz89?) - in case you might have missed it, this is a good thread to read:
http://www.ft86club.com/forums/showthread.php?t=106496
Old 06-03-2016, 06:10 PM   #3912
Calbee
Drives: B8 A4
Hey guys,
I am purchasing a used KW supercharger soon with the C30 blower. I believe it is one of the earlier models.
I have been reading about the belt issue. Is there anything I can do to prevent it or minimize it from happening such as upgrading different parts? Or do just have to put a few extra belts in my car?
Calbee is offline   Reply With Quote
Old 06-03-2016, 06:11 PM   #3913
Jusjones
Drives: 2013 Subaru Brz Satin White Pearl
Get the new pulleys and belt, check your tension often, never had any issues with mine.
Sent from my SM-N920V using Tapatalk
Jusjones is offline   Reply With Quote
Old 06-03-2016, 06:41 PM   #3914
Freeman
Freeman's Avatar
Originally Posted by Calbee View Post
Hey guys,
Check the belt tension often and carry an extra just in case. Not much else you can do beyond that
Old 06-03-2016, 07:45 PM   #3915
vgi
Drives: frs
i can't recall any people running on new pulleys and properly set the belt tension to 60-65 who had issues. i think.
Old 06-08-2016, 10:20 PM   #3916
Beechnut87
So I have been having a loose belt problem I decided to address. I heard the belt and when I tried to break 90° I did so really and did more of a 135° so I went to adjust it, baked of the lock nut and tried to tighten and it was TIGHT. I thought it was odd and backed it off and the tensioner never let loose. I thought hmm what else holds this in place? I was at a loss and then I realized NOTHING! So what's holding the block in place? The block has a square end and a round end.... Mine was installed backwards! The pulley could never tension the belt because it's backwards! So very very upset �� with PRE for this install miss! Got to call them in the am and get this fixed!
Old 06-08-2016, 11:51 PM   #3917
vgi
Drives: frs
@Beechnut87 it looks fine. i can't even imagine how it can be installed backwards. did you unscrew the pulley's bolt?
Old 06-08-2016, 11:55 PM   #3918
Jusjones
missing lock nut, at least from pic.
Old 06-09-2016, 08:36 AM   #3919
Beechnut87
It's just backed that far off and the phones that close. I assure you it's there 😉
Old 06-09-2016, 10:21 PM   #3920
Trphotomediadotcom
Just purchased this kit from a member on the forums. Kraftwerks c30-94 Kit Wooo
Trphotomediadotcom is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
