#225 | |
Drives: Asphalt frs
#226 | |
Drives: 2JZ FRS
The trans was a lot of trial and error, along with a bunch of custom stuff. Can't really put a price on it It's a street car, that's built for drag racing. Not really setup for a road course or anything like that. Has everything it came with factory, minus windshield washer bottle
#227 | |
Drives: Asphalt frs
#228 |
Drives: 2JZ FRS
motec SLM installed
![]() ID2000's were installed saturday, just need to finish up the tune when my guy has time ![]() only pull video i took, and it was an early one. we cut around 7k rpm and were only on wastegate spring pressure. around 500ish whp. this was before we started adding in timing as well. around 18 degrees in boost
| The Following 4 Users Say Thank You to spitfire481 For This Useful Post: |
#229 |
Drives: 2013 Scion FR-S Firestorm Red
That things sounds effing angry! Holy crap
Sent from my SM-G935T using Tapatalk |
#230 |
Drives: 2JZ FRS
going to sound even angrier at 38psi, 8700ish rpm and full timing lol
| The Following 3 Users Say Thank You to spitfire481 For This Useful Post: |
#231 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
#232 | |
Drives: '15 FRS
Love what I see
#233 |
#234 |
Drives: 2JZ FRS
[quote=quinceyc;2676396]No. It's controlled by a motec ecu, data logger or dash unit
#235 |
Drives: 2JZ FRS
ID2000's are in, continuing tuning on thursday. ecu is mounted in the glove box, and i was playing with the launch limiter a little the other day. already makes a little boost with just the limiter. should do very well with the anti lag timing/fuel settings enabled.
![]() [ame="https://www.youtube.com/watch?v=BkaIjoG1rvc"]FRS Motec m150 limiter test - YouTube[/ame]
#236 |
Drives: RHD Gt86
I respect this build over the Green 2zj build by a million times.
![]() amazing work man.. would really love for you to flood us with videos of her
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#237 |
Drives: 2JZ FRS
Had a fuel pump issue with the in tank pump. Surge tank ran out of fuel half way through the power pulls so we didn't add any more power. All of the anti lag is set, new injectors are scaled, and rolling launch works but he is still refining it further. Fuel pressure dropped to 20psi at 30psi of boost pressure during the pull, but the afr line stayed solid because it adjusted duty cycle so fast to make up the volume to hit the target. Basically it will save you a motor if shit hits the fan haha. Anti lag makes a targeted 18psi in just over 3 seconds of activation, 5000rpm
[ame="https://www.youtube.com/watch?v=qn4f4I5oClM&feature=share"]June 30, 2016 - YouTube[/ame] [ame="https://www.youtube.com/watch?v=5PB7XdF0hTo&feature=share"]Error 502 (Server Error)!!1[/ame]
| The Following 5 Users Say Thank You to spitfire481 For This Useful Post: | civicdrivr (07-01-2016), Kris86 (07-19-2016), M1K3 (07-01-2016), MooKz (07-02-2016), Sportsguy83 (11-30-2016) |
#238 |
Drives: 2JZ FRS
went to the track friday night. snapped the drivers inner shaft, as well as passenger outer joint. these are DSS 600hp axles. moving to the 1000hp setup with the larger hubs and running a 26x10x15 slick at the track to soak up some of the shock in attempt to keep this from happening again.
| The Following User Says Thank You to spitfire481 For This Useful Post: | SoCal80six (07-12-2016) |
| God's Build | GodSays | Member's Car Journals | 13 | 04-17-2013 02:31 PM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 05:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 04:40 PM |
| My BRZ build | brztj | Mid-Atlantic | 3 | 09-08-2012 06:52 PM |
