Old 06-02-2016, 08:54 PM   #225
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by spitfire481 View Post
666 at 28 psi. the turbo will probably start to run out of steam around 38ish from what he could see. new injectors are going in and hopefully he can swing by next week to finish up. the control and drive ability of m150 ecu is amazing. the fuel trim controls are so quick to respond the afr is dead on with commanded afr the whole time. the high pressure di pump started oscillating fuel pressure after 8k rpm from 600 psi to 2000psi until redline. im assuming with ecutek people just leave it be but with the m150 it corrected the duty cycle for the di's so fast the afr had zero deviations from commanded after 8k.
trans is fine. it is faceplated (basically dogbox) H pattern 5 speed. its rated for 600 continuous ft lbs in stock form from tremec. mine has heat treated gears so they have a tad more give from shock load. we might setup a strain gauge for clutchless shifting at the track seeing how the trans will take it with the control the m150 has over clutchless shifting loads.
Wow makes me want to go motec so bad. Do you know if theirs any other kits made for this car haltek or anything? Also who do you have tuning the car? How much did you guys spend on that trans been looking on which way I should go with trans. And what type of build are you going for with the car drag or track? Also what is it redlining at?
SoCal80six is offline   Reply With Quote
Old 06-02-2016, 10:29 PM   #226
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Your standalone options are motec m150 or hydra ems. The hydra ems isn't bad, it's just finding someone who knows how to use it. Nothing else has direct injection support. We deal with aem and haltech pretty close with our shop car. Neither has any interest in working with di yet.
The trans was a lot of trial and error, along with a bunch of custom stuff. Can't really put a price on it
It's a street car, that's built for drag racing. Not really setup for a road course or anything like that. Has everything it came with factory, minus windshield washer bottle
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-03-2016, 12:13 AM   #227
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Gotta keep us updated on how that trans is holding up!! Any ideas what it'll run?
Old 06-06-2016, 05:17 PM   #228
spitfire481
Drives: 2JZ FRS
motec SLM installed
ID2000's were installed saturday, just need to finish up the tune when my guy has time
only pull video i took, and it was an early one. we cut around 7k rpm and were only on wastegate spring pressure. around 500ish whp. this was before we started adding in timing as well. around 18 degrees in boost
MoTeC
Build Thread
@spitfire481
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
DustinS (06-06-2016), M1K3 (06-07-2016), Pure Automotive (06-06-2016), SoCal80six (06-07-2016)
Old 06-08-2016, 03:33 PM   #229
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
That things sounds effing angry! Holy crap
Sent from my SM-G935T using Tapatalk
MooKz is offline   Reply With Quote
Old 06-08-2016, 04:25 PM   #230
spitfire481
Drives: 2JZ FRS
going to sound even angrier at 38psi, 8700ish rpm and full timing lol
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
Kris86 (07-16-2016), MooKz (06-08-2016), SoCal80six (06-08-2016)
Old 06-08-2016, 04:55 PM   #231
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Cant wait to see that!
Cockatoo is offline   Reply With Quote
Old 06-10-2016, 12:20 AM   #232
VitViper
Drives: '15 FRS
Love what I see
Hydra EMS is complete shit, done them. Threw it out on one customer's car and put different ECU in that ran way better.
VitViper is offline   Reply With Quote
Old 06-10-2016, 04:25 AM   #233
quinceyc
[QUOTE=spitfire481;2672614]motec SLM installed
Can Motec SLM be installed with stock ECU??
quinceyc is offline   Reply With Quote
Old 06-10-2016, 09:57 AM   #234
spitfire481
Drives: 2JZ FRS
[quote=quinceyc;2676396]
motec SLM installed
No. It's controlled by a motec ecu, data logger or dash unit
MoTeC
Build Thread
@spitfire481
Old 06-28-2016, 11:02 AM   #235
spitfire481
Drives: 2JZ FRS
ID2000's are in, continuing tuning on thursday. ecu is mounted in the glove box, and i was playing with the launch limiter a little the other day. already makes a little boost with just the limiter. should do very well with the anti lag timing/fuel settings enabled.
[ame="https://www.youtube.com/watch?v=BkaIjoG1rvc"]FRS Motec m150 limiter test - YouTube[/ame]
MoTeC
Build Thread
@spitfire481
DustinS (06-28-2016), Kris86 (06-30-2016), Pure Automotive (06-28-2016)
Old 06-30-2016, 09:31 AM   #236
Kris86
Kris86's Avatar
Drives: RHD Gt86
I respect this build over the Green 2zj build by a million times.
amazing work man.. would really love for you to flood us with videos of her
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 06-30-2016, 09:46 PM   #237
spitfire481
Drives: 2JZ FRS
Had a fuel pump issue with the in tank pump. Surge tank ran out of fuel half way through the power pulls so we didn't add any more power. All of the anti lag is set, new injectors are scaled, and rolling launch works but he is still refining it further. Fuel pressure dropped to 20psi at 30psi of boost pressure during the pull, but the afr line stayed solid because it adjusted duty cycle so fast to make up the volume to hit the target. Basically it will save you a motor if shit hits the fan haha. Anti lag makes a targeted 18psi in just over 3 seconds of activation, 5000rpm
[ame="https://www.youtube.com/watch?v=qn4f4I5oClM&feature=share"]June 30, 2016 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=5PB7XdF0hTo&feature=share"]Error 502 (Server Error)!!1[/ame]
MoTeC
Build Thread
@spitfire481
The Following 5 Users Say Thank You to spitfire481 For This Useful Post:
civicdrivr (07-01-2016), Kris86 (07-19-2016), M1K3 (07-01-2016), MooKz (07-02-2016), Sportsguy83 (11-30-2016)
Old 07-12-2016, 04:55 PM   #238
spitfire481
Drives: 2JZ FRS
went to the track friday night. snapped the drivers inner shaft, as well as passenger outer joint. these are DSS 600hp axles. moving to the 1000hp setup with the larger hubs and running a 26x10x15 slick at the track to soak up some of the shock in attempt to keep this from happening again.
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
SoCal80six (07-12-2016)
God's Build GodSays Member's Car Journals 13 04-17-2013 02:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 06:52 PM
