Old 06-03-2016, 10:56 PM   #1
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System
Taking our Flex Fuel kits to a whole new level of safety, our Dynamic Engine Safety System (DESS) upgrade, allows you to upgrade your existing Mk1 flex fuel kit with enhanced features. With these features, you can be rest assured that in the event of a fuel pressure loss, your engine will be protected, as our safety system will rapidly detune the engine to avoid damage brought on by a sudden lean condition, faster than the ECU can respond, thus protecting the engine from possible damage brought on by pre-ignition.
This upgrade effectively turns your old Flex Fuel Mk1 kit into the Mk1+. If you would like to understand what the differences are please check out our comparison chart for more information.
We have also created a quick video on how the system works and protects your engine from fuel starvation, lean conditions and potential engine failure.
[ame="https://www.youtube.com/watch?v=4vLtj3B2mZA"]Delicious Tuning Flex Fuel Kit Mark 1+ - YouTube[/ame]
Cheers,
William Knose
P.S. For those of you with Apple iPhone's we have no forgotten about you. Here is an article we have released about the hurdles of creating an electronics system the Apple compatible.
Old 06-03-2016, 11:13 PM   #2
enivid
enivid's Avatar
Drives: WRB JR BRZED
Works with any version of the flash and go tune? No update required?
enivid is offline   Reply With Quote
Old 06-03-2016, 11:24 PM   #3
enivid
enivid's Avatar
And where's the option to buy it with the race fuel lines?
Old 06-05-2016, 08:29 PM   #4
azynneo
what about those who bought the v1 flexfuel, do we just pay the difference?
azynneo is offline   Reply With Quote
Old 06-07-2016, 02:59 PM   #5
DeliciousTuning
Does not work with any version, you'll need to update to the latest version or we can tweak the current version you have.
The race line option has been added, it's a $20 addition, that comes with quick disconnect fitting.
We have an upgrade program, see this page for more information: https://www.delicioustuning.com/DESS_Mk1_Plus_Upgrade
Old 06-07-2016, 11:39 PM   #6
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Sorry , noob question, why flex fuel? What could it do? I've Google flexfuel here and there but doesn't seem to improve hp or performance? Could you please explain benefits? Very interested to learn
turtlefeeder is offline   Reply With Quote
Old 06-08-2016, 03:56 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Flex fuel means adding capability for multifuel, petrol & ethanol and any mix of them. With autodetecting mix ratio and changing ECU tunes timings as needed.
Old 06-08-2016, 06:41 AM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
E85 has an octane equivalent of roughly 108. Compared to the standard 91 or 93 octane of normal gas, that's a significant jump and can allow for a pretty large increase in horsepower if the tuner knows what they're doing.
Old 06-08-2016, 06:43 AM   #9
Calum
That Guy
Zach, will it be possible to use this sensor to input oil pressure info onto the canbus?
Old 06-08-2016, 12:14 PM   #10
DeliciousTuning
Not at the moment.
Sincerely,
Zach
Old 06-08-2016, 01:39 PM   #11
turtlefeeder
Drives: UltraMFrS
Oh that's great how does duel milage goes? Heard that will go down
Old 06-08-2016, 01:45 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sick! Gonna be ordering mine soon!
Old 06-08-2016, 02:32 PM   #13
Calum
That Guy
I don't have first hand experience, but my understanding is you'll use more fuel but the fuel is less expensive, then you have to consider the extra fuel you'll be using because you've got your foot on the fun end of the throttle travel more often...
Old 06-08-2016, 02:52 PM   #14
steve99
Drives: FT86
On E85 you fuel economy will be aprox 25% worse than on 91/93 petrol.
you don't actually need a flex fuel kit to run E85 you could run E85 by just flashing a dedicated E85 tune or using the map switch function of Ecutek to switch tunes. fine with NA cars, boosted different story unless you have controlled source of E85
Delicious tuning flex fuel kit DIM HAWAIICALIVEGAZ Engine, Exhaust, Transmission 0 05-16-2016 02:49 AM
FS: Delicious Tuning Flex Fuel kit (SoCal) J.C. Engine, Exhaust, Bolt-Ons 2 07-17-2015 08:27 PM
Delicious Tuning Flex fuel kit themooseisloose Engine, Exhaust, Bolt-Ons 26 05-01-2015 11:46 AM
Delicious tuning flex fuel brz23 Great Lakes 2 03-06-2015 07:53 PM
Delicious tuning flex fuel brz23 Software Tuning 4 03-05-2015 12:28 PM
