Old 10-02-2013, 12:11 AM   #43
Dezoris
Dezoris's Avatar
Originally Posted by Figo View Post
thank u man.
will it be dangerous if i do not do alignment and drive it for das?
I just dont want to pay alignment twice. lol.
Your alignment will be absolutely jacked up after the coils and control arms are installed.
Personally i would ask them at a minimum to just correct the toe before you drive out. Explain why. They should only charge you 60$ for that maybe even free because you are coming back for real deal.
Small price to pay to have it safe temporarily. Also the shop will appreciate you coming back and having it all done right first time. And not coming back twice for a second corner balance and alignment because heights changed after settling.
Old 10-02-2013, 05:59 AM   #44
ZDan
ZDan's Avatar
Drives: '23 BRZ
Putting stiffer springs up front seems like a really bad idea, unless you like understeer. The front springs aren't anything like as highly leveraged as the rears, so you need significantly stiffer rear springs for balanced handling.
KW V3s are 342 lb/in front, 399 lb/in rear, right? Front motion ratio is ~0.95, rear is ~0.75.
Front wheel rate ~342 * .95^2 = 309 lb/in
Rear wheel rate ~399 * .75^2 = 224 lb/in
Relative F/R stiffness is 58/42.
Even taking into account 54/46 front/rear weight distribution, the stock KWV3 spring rates have relatively more stiffness up front already.
Swapping springs front to rear will give you:
Front wheel rate ~399 * .95^2 = 360 lb/in
Rear wheel rate ~342 * .75^2 = 192 lb/in
Relative F/R stiffness is 65/35, quite an understeery setup for a 54/46 car...
Old 10-02-2013, 08:28 AM   #45
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Lol, that sounds like a good idea.
For the settle, will those 4 coils settle by the same rate?
For example, if I drop 1'' front & rear and it settle a little bit after days and I am happy with the extra drop, I dont hav to adjust it again right? They might not be 1.2 drop left and 1.3 drop right correct?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-02-2013, 11:20 AM   #46
Dezoris
Dezoris's Avatar
Its impossible to predict, typically the front settles more quickly do to weight distribution. As long as your toe is set safely drive it hard under braking and do plenty of loading and unloading of suspension to help make sure all corners compress and uncompress for a few days before setting your final heights.
Old 10-02-2013, 11:22 AM   #47
Figo
Figo's Avatar
I c. I will do it, hah.
Thanks man
Old 06-06-2016, 06:34 PM   #48
vuthatswho
Drives: 2016 Scion FR-S
Originally Posted by djdnz View Post
Yes everyone is very secretive here, probably because...
A) They don't know enough about what they are doing
B) They know what they are doing, but are being coy because they have an edge on the competition they are in and want to keep it that way
I'm sorry I can't add more than this, I don't have my KW's yet! My suggestion to you is start exactly how the manual states and make small tweaks from there to suit your driving preferences. I wouldn't touch the springs until you know more about the current handling.
Probably the best advice someone could give
vuthatswho is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 10:35 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
