Old 06-06-2016, 05:30 PM   #1
phantasticity
Ricer
+10hp or -10 hp
My FRS is basically stock, all I have is an Exhaust, Intake, but sometimes I feels like my car has gained more than 10 hp, but sometimes I feel like I've lost 10 hp. Like it's different every other day. Would a tune help with this situation?
phantasticity is offline   Reply With Quote
Old 06-06-2016, 05:32 PM   #2
kev60625
Drives: 2013 WRB Subaru BRZ
Probably gained or lost 2hp, nowhere near 10 though..
You need a tune if you actually want to take advantage of mods.
kev60625 is offline   Reply With Quote
The Following 2 Users Say Thank You to kev60625 For This Useful Post:
Cole (06-08-2016), FRSBRZGT86FAN (06-07-2016)
Old 06-06-2016, 05:36 PM   #3
gramicci101
Off Topic
When you say exhaust, what do you mean? Cat-back? Header-back? Straight front pipe? If you have a header, what do you have? If you've swapped the OEM header for a catless header, you would greatly benefit from a tune.
If it's a cat-back that you threw on for a better sound, you will still benefit from a tune, just not as much.
The Following User Says Thank You to gramicci101 For This Useful Post:
Cole (06-08-2016)
Old 06-06-2016, 05:36 PM   #4
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
The almighty butt dyno is a tricky beast. For a catback exhaust you don't need a tune. If you have a full cold air intake you probably want to get a tune or at least scale your MAF sensor by editing your ECU yourself. Most places doing a tune would be able to account for that and if you tune it yourself there are lots of helpful tips in the software tuning section. Tuning/scaling your MAF opens a whole different can of worms so best to read up a lot before picking an option.
There are a lot of variables that will affect throttle response and other factors that can change on a daily basis making the car feel faster or slower: Intake air temps, Gas quality, warm/cold tires having/not having grip, engine up to operating temp.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following 3 Users Say Thank You to Tectoniic For This Useful Post:
Cole (06-08-2016), FRSBRZGT86FAN (06-07-2016), humfrz (06-07-2016)
Old 06-06-2016, 05:47 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sounds like you need more stickers.
But a tune is a great start:
http://www.modbargains.com/vishnu-op...subaru-brz.htm
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
Leonardo (06-10-2016), scary alien (06-07-2016), Shedd22 (06-08-2016)
Old 06-06-2016, 07:21 PM   #6
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
It will depends on how you drive too.
if you drive 30mph with 4th gear,,ofcus its not going faster.
OFT will help.
FR-Sky is offline   Reply With Quote
Old 06-06-2016, 07:48 PM   #7
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Why did you modify the intake and exhaust in the first place as the result may have shifted your powerband.
krayzie is offline   Reply With Quote
Old 06-06-2016, 07:52 PM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
My butt dyno tells me this car doesn't like hot humid days.
The Following 5 Users Say Thank You to new2subaru For This Useful Post:
chaoskaze (06-10-2016), Cole (06-08-2016), nikitopo (06-09-2016), SlammedSilly (06-07-2016), Tcoat (06-07-2016)
Old 06-06-2016, 10:28 PM   #9
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
  • That's probably to most realistic butt dyno result ever reported!
billwot is offline   Reply With Quote
The Following 4 Users Say Thank You to billwot For This Useful Post:
Cole (06-08-2016), new2subaru (06-07-2016), Shedd22 (06-08-2016), Tcoat (06-07-2016)
Old 06-07-2016, 06:08 PM   #10
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Shove all them air in those piping xD lol jk jk
Seriously, posts above pretty much covers it. Intake and "exhaust".. could of shifted your power band, tuning those mods would help response or use them to potential. Lower gear better torque, watch out when to shift too.. that torque dip is still there if you didn't swap headers or have force induction. Yes, temperature matters too, better in cold because more cold air concentration for your intake to.."TAKE IN/IN TAKE?" <-- see what I did there?
turtlefeeder is offline   Reply With Quote
Old 06-07-2016, 09:45 PM   #11
I reckon that is within standard deviation for the signal between your butt dyno and your brain ......
Cole (06-08-2016), Shedd22 (06-08-2016)
Old 06-07-2016, 09:56 PM   #12
I know for a fact that my car gains 10HP every time I wash it. The handling improves as well.
Cole (06-08-2016)
Old 06-07-2016, 10:21 PM   #13
Yep, I feel that too.
Mine picks up at least 30 HP, if mrs humfrz isn't riding with me, ...... even after I figure in the weight difference........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (06-08-2016), Shedd22 (06-08-2016), Tcoat (06-08-2016)
Old 06-08-2016, 12:21 AM   #14
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
+/- 10HP sounds like you're just feeling the torque dip.
I notice it if I'm full throttle as I pass the 3.5-4.5K RPM area (i.e. when traffic slows me down to 10mph in 2nd and then clears up). Otherwise, under partial throttle, I don't really notice it.
Maybe thats it?
Or has your weight been fluctuating? :P
The Following User Says Thank You to PandaSPUR For This Useful Post:
FRSBRZGT86FAN (06-08-2016)
