Old 06-06-2016, 12:53 PM   #85
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Find a different vendor...
Originally Posted by JGalp View Post
Hey all,
Just wanted to preface this a bit, i have a 2015 brz. all i have are cosmetic upgrades and tein flex z, SPL LCA, and 17x9 rpf1. my next step was to go FI and i thought it came down to JRSC vs edelbrock. after reading many reviews i thought both kits were great, similar power numbers at CARB, similar in most aspects. was under the impression that JRSC was more track oriented and and edelbrock was better for someone just DD (like myself) i do not intend to track, or even auto x. just your occasional spirited driving and cruising through some canyons.
recently, i spoke with a local vendor (i will not name the vendor) who told me the following about why i should just JRSC over the edelbrock. He said that not only does the edelbrock make 50hp less than JRSC, but it is also less reliable, 5-6 less MPG and the intercooler system on the edelbrock isn't as good as the JRSC. Oh and yes the edelbrock isn't CARB legal yet.
Ive already read many threads on both kits and i was under the impression that both had similar MPG loss, similar power, and i thought the edelbrock was j just as reliable. can anyone chime in on this? thanks
John
That guy is a liar, find a different vendor...
Jaden
Jaden is offline   Reply With Quote
The Following 2 Users Say Thank You to Jaden For This Useful Post:
Ashikabi (06-06-2016), BigFatFlip (06-06-2016)
Old 06-06-2016, 01:13 PM   #86
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Fenix View Post
I am second guessing boosting my FA20 engine after reading this thread and elsewhere online. lol A NA swap might be in its future. :/
Why are you second guessing? Reliability? Performance? An NA engine swap will be inherently more complex and less reliable.
Old 06-06-2016, 01:33 PM   #87
OkieSnuffBox
Drives: '23 BRZ Limited
Inherently more complex.
But less reliable? I'd take the reliability of an LSx swap over a boosted, stock internal FA20 every day of the week.
Old 06-06-2016, 01:52 PM   #88
BigFatFlip
BigFatFlip's Avatar
I was making broad strokes, but agreed
The Following User Says Thank You to BigFatFlip For This Useful Post:
OkieSnuffBox (06-06-2016)
Old 06-06-2016, 03:04 PM   #89
CSG Mike
CSG Mike's Avatar
Well, if I had the budget for a trans, axles, diff, driveshaft, and ECU, I would too!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
BigFatFlip (06-06-2016), funwheeldrive (11-25-2016), OkieSnuffBox (06-06-2016)
Old 06-06-2016, 03:38 PM   #90
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
The engine may be reliable, but the rest of the car probably not so much, at least not until all the swap related bugs are worked out and after things that can't handle the power are upgraded appropriately ('cause many will be missed even if the project is planned properly).
To get reliability out of the box, it would be much better to just get a Camaro
Sleepless is offline   Reply With Quote
Old 06-06-2016, 03:42 PM   #91
OkieSnuffBox
Scratch Camaro and insert GT350 with the Track Package.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
CSG Mike (06-06-2016)
Old 06-06-2016, 03:54 PM   #92
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Camaro with the LE1 suspension package will likely keep up with or beat a GT350 with a track pack and cost thousands less (MSRP; but GT350s are $10-$20 over right now) and have low end torque when not driving it on the track.
I was thinking of getting a 350 but after reading reviews, seeing the power curves, and driving a Camaro, I'm convinced it is the better all around car and easily the equal of the 350.
Back on topic:
I like the JRSC but would have likely picked the Edlebrock if it had as much track testing by forum members when I pulled the trigger in October (the Edlebrock just became available).
The reason: same as why I'd pick the Camaro over the GT350; low end torque
Old 06-06-2016, 03:58 PM   #93
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Does anyone have a chart showing oil temps for a stock plus edelbrock...just to give me an idea of where they might max out? If you have ambient at the time, that would help. Alternatively, point me in the right direction
Thanks.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 06-06-2016, 04:25 PM   #94
BigFatFlip
BigFatFlip's Avatar
Thanks.
Check the owners thread, I vaguely recall some charts posted up.
Stock I've seen my temps reach 230 at around 75 ambient going up Mt Hamilton. On the track, I've maxed at 219 at about 80 ambient with a custom oil cooler.
paiceyfan (06-07-2016)
Old 06-06-2016, 04:36 PM   #95
CSG Mike
CSG Mike's Avatar
Back on topic:
Ace A/350 header + E85 = lots of low/mid range torque gains.
Jmonty (06-06-2016)
Old 06-06-2016, 05:22 PM   #96
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
E85 is not an option for me.
Header is an option if it gives noticeably more torque on 92.
Old 06-06-2016, 08:37 PM   #97
CSG Mike
CSG Mike's Avatar
You'll still have very noticeable low end gains. E85 primarily gives top end gains.
Old 06-10-2016, 02:14 PM   #98
JGalp
Drives: 2015 CWP BRZ Limited
Jaden
I would love to agree, but i have def experienced roughphy 5mpg loss, and this isn't getting on it every chance i get, its about a 50/50 mix of highway and city and me trying to drive conservatively, still getting about 21mpg which is me driving fairly conservatively. when i first got it i got lower MPG cuz well it was fun testing it out. I'm assuming this is about normal though. are most peoples MPG around 20-22 in 50/50 city/hwy driving conditions
JGalp is offline   Reply With Quote
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Jackson Racing Kit AT6 CladMonitor Forced Induction 26 06-27-2014 10:27 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
