Drives: Toyota 86
OEM cam differences, modifying fuel pressure.
Hi All,
Yes I am new here (been lurking for a while) Its a great site! I have searched my ass off and cannot find any concrete data. My main question is does anybody know the differences in cams from the 2012, 2014, 2015 engine updates and part number changes?? ie lift/duration. Part numbers 2012 su0030018x 2014 su0030474x 2015 su0030623x the second part of my question relates to fuel pressure on the direct injection. Will raising the fuel pressure prior to it entering the direct injection pump raise the output pressure of the direct injectors? |
#2 | |
Drives: FT86
However the vvt cam tables in tunes for all the revisions are almost identical. If you alter the fuel pressure into the DI injectors then you will alter the fuel delivery. Some E85 tunes do that to increase they fuel delivery by 30% for e85 fuel tunes, the up the DI pressure multiplier in tune tables to up the DI fuel delivery. and the injector scalar for port injection is reduced by 30% to fool the ecu to deliver more fuel? |
#3 | |
Drives: Toyota 86
Yes i was aware of the valves and rockers and coil packs.. Someone on here was saying the cams had different amounts of lift, was hoping to get clarification on that. The other question was really just to satisfy curiosity about the di, If the engine driven di pump is supplied say 40psi as standard, and we upped the supply pressure to say 45psi, would we see a linear increase in the pressure to the di injectors on the other side of the di pump? I know these things can be controlled via ecu, just wondering about the mechanics of it all.
#4 |
Drives: WR Blue BRZ
This should help you out in terms of understanding the mechanics I don't know if it's our fuel pump but its probably pretty similar in terms of operation.
[ame="https://www.youtube.com/watch?v=0mjG7-Vc0Co"]Delphi GDi Fuel Pump - YouTube[/ame] As for increasing the inlet pressure, to increase the output. Nope. Due to the design the output is independent of inlet, you might get a little more but no linear trend upwards. |
#5 | |
TRACKBREAD
-Josh |
#6 | |
Drives: FT86
The OFT guys adjust the fueling for E85 in the manner above ie drop the port injector scale by 30% Increase the DI pressure multiplier tables by 30% no mechanical or hardware changes needed, i believe they have run a turbo car on about 10-12psi producing about 340hp on E85 with completely stock fuel system components doing that and i suspect altering the DI/PI ratio tables. http://www.ft86club.com/forums/showthread.php?t=100699 |
#7 |
Drives: 2JZ FRS
i run 50psi of base pressure, rising to 80-85psi at full boost. di pressure table wasn't touched in motec to compensate for the rising rate going into it. i also ran a rising rate setup on ecutek and we didn't have to alter the di pressure control valve either. after 8k rpm the high pressure did start to oscillate though.
#8 | |
Drives: Toyota 86
#9 | |
Drives: FT86
Some tune systems like brzedit or ecutek change this protocol so it effectivly locks the ecu to that system. Other systems like OFT or Tactrix ecuflash do not lock ecu or tunes so you still have open access The cheapest way to gain access and be able to tune car is with a Tactrix cable and ecuflah software all up about $170 usa, see coloured links below. for tune systems see here http://www.ft86club.com/forums/showthread.php?t=106068 what mods are you tuning for ? |
#10 |
Drives: UK GT86
What are you trying to achieve? Have you maxed out the available IPW? Why is the ECU "locked"?
.: Stealth 86 :.
#11 |
Drives: 2JZ FRS
I don't think the higher inlet pressure changes the di output pressure. Factory runs a mix of DI and port, or just di depending on conditions met. You are trying to add fuel without any tuning software?
#12 |
Drives: FT86
You might need to supply more info like
why is ecu locked if its running full di, why and if its running full di only its obviously been tuned by someone what mods ie turbo sc usually tuners increase pi injector size to increase fuel delivery and lean on the port injectors more. what fuel etc else were just having a stab in the dark :-) |
#13 |
Drives: Toyota 86
#14 | |
Drives: FT86
why do you need a motec for an NA car seems way overkill ? |
| P0087 Low Fuel rail pressure | GT86meMR2 | Issues | Warranty | Recalls / TSB | 17 | 05-15-2021 01:23 PM |
| Adding in line fuel pressure regulator | KGZ86 | Engine, Exhaust, Transmission | 13 | 07-07-2016 05:15 PM |
| Aftermarket Fuel pressure gauge | FutureFT86 | Engine, Exhaust, Transmission | 2 | 03-10-2016 10:22 PM |
| High Pressure Fuel Pump Thread | crazyfrenchbiker | Engine, Exhaust, Transmission | 10 | 09-09-2015 01:32 AM |
| frs low fuel rail pressure ? 15,000 miles | j0hnnybk01 | Issues | Warranty | Recalls / TSB | 10 | 03-04-2014 03:03 PM |
