Old 06-01-2016, 07:43 PM   #435
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Another confirmed fitment of my new wheels for stage 1 and 2
Enkei RS05RR 18x9.5 +43
Also want to add that I ordered PolyMatrix A pads from a local shop... Waiting for my friend with stage 2 to "naturally" wear them down to .65 so I can use them, the info looks very promising on them though!
Canehda is offline
The Following User Says Thank You to Canehda For This Useful Post:
8R6 (06-02-2016)
Old 06-02-2016, 12:13 PM   #436
8R6
8R6's Avatar
Drives: FRS
^ the more i see those wheels, the more i like them. setup looks good with the brakes!
8R6 is offline
Old 06-03-2016, 06:43 AM   #437
Canehda
Canehda's Avatar
Sadly they dont clear my PSS10 coils like they do with other coils they are being returned today...
Canehda is offline
8R6 (06-03-2016)
Old 06-03-2016, 07:08 AM   #438
ajc209
Drives: GT86 Cosworth
I've been running the Sport Performance rear for a few months now and had the car on track once.
I get really loud medium (or harder) brake pressure squeal.
I assume copper grease between the pad and shims and chamfering the leading edge of the pads is a good idea.
ajc209 is offline
Old 06-03-2016, 12:44 PM   #439
Irace86
Drives: BRZ + Ducati M796
So performance is 4pot, stage 1 is narrow 6pot, stage 2 is wide 6pot, stage 3 is narrow 6pot but with two piece rotors, stage 4 is wide 6pot but with two piece rotors. 1 and 2 are the same price, 3 and 4 are the same price. There are more color options with 2 and 4 and the pads are bigger, so is the reason some go with the narrow is for max weight or clearance, or cheaper pads. Am I missing something?
Also will red pop too much on D4S or will black just look too murdered out? Pics anyone?
Irace86 is offline
Old 06-03-2016, 02:33 PM   #440
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
People generally only go for the stage 1/3 kits because they need the clearance for their wheels. There is slight weight savings there too but having the extra pad material and heat sink from larger calliper I think would outweigh that benefit.
I can't weigh in on the color, I think that's too much a matter of taste. If my car was black, I'd probably go with red but I think that a well done murdered out car looks awesome too.
Lynxis is offline
The Following User Says Thank You to Lynxis For This Useful Post:
Irace86 (06-03-2016)
Old 06-03-2016, 03:24 PM   #441
Irace86
Thats what i figured. Im running XXR 530's with a 18" +33 and +38 staggered offset, so I should be fine, right?.
I think the anodized calipers looks cleaner than the laquer finishes so I'll probably just go black, especially if red would be too much color. I even considered silver for the oem look but the anodized black will probably be the choice. Whatcha think?
Irace86 is offline
Old 06-03-2016, 03:29 PM   #442
Lynxis
Lynxis's Avatar
I think black would look good. In general, I think black looks good behind bright wheels which is why I went that route for my own car.
Lynxis is offline
Old 06-03-2016, 03:52 PM   #443
ryoma
ryoma's Avatar
DL the brake templates from their website to make sure what you can fit. I would suggest getting both stage 1 and 2 templates and see if stage 2 fits. they're the same price and IMO, the stage 2 would be better if it fits.
as for colors, the black anodized looks really nice and I personally think the Wilwood logo looks better than the RR racing logo lol. black anodized is the only way to get the Wilwood logo I believe, and all the other colors have the RR logo
ryoma is offline
The Following User Says Thank You to ryoma For This Useful Post:
Old 06-03-2016, 07:02 PM   #444
Irace86
I looked a little bit, and I have like over an inch of clearance to the side and the wheel diameter is more than enough at 18" so I think I am good for the big boys.
I actually like the RR logo over the Wilwood, but only on the anodized ones. The Corvette "Racing looking font is ehh though. Wilwood font is kinda bubbly and childish. Same with AP Racing logo. Am I crazy? I might go Wilwood. Still have to let it roll around in my mind.
Thanks for the opinions guys.
Irace86 is offline
Old 06-03-2016, 07:37 PM   #445
Irace86
Can anyone comment on the knockback springs?
Irace86 is offline
Old 06-04-2016, 05:24 PM   #446
Lynxis
Lynxis's Avatar
I don't have the springs and so far, I haven't had any issues with knock back yet. That said, I'm not really a candidate for having issues with it because it would only be noticeable on worn brake pads and I've only tracked on new ones so far. My next trip to the track will be a better indicator but that could be a while away.
Besides this, from what I'm reading, knock back generally only becomes an issue when you are pulling really high g's through corners. It's certainly not something that you'll ever experience on the street and would only happen to you if you're running r-comps or the new high end street tires like re71r, Rival s, etc.
If you're going to track your car on good tires, then consider getting the springs but there is no need if you're just going to drive on the street.
Lynxis is offline
Irace86 (06-04-2016)
Old 06-04-2016, 10:01 PM   #447
OkieSnuffBox
Drives: '23 BRZ Limited
I never had issues with knockback in my Miata, running RComps and Wilwoods at all four corners.
OkieSnuffBox is offline
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 06-04-2016, 10:12 PM   #448
Irace86
From what I read, it was only in extreme lateral g's, but I just thought I would check, so this is good to hear. Thanks.
Irace86 is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
