Old 05-24-2016, 04:21 PM   #2381
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by DocWalt View Post
I'm still at -2.6/-2.0 camber front/rear. Rear tire wear is definitely biased a bit towards the outside on track, but no issues at autocross. I do get a bit higher outer shoulder temps, but not more than ~5 degrees F.
What hot pressure are you running?
I was running 34 front and 32 rear last event. I never hit the triangles, but when I took the wheel off the outside wear was pretty noticeable. Here's a pic of one of the rear tires. Both sides are basically the same.
smg1138 is offline   Reply With Quote
Old 05-24-2016, 04:25 PM   #2382
cjd
cjd's Avatar
Drives: 2017 BRZ
Such high pressures! I've never done over 30, as low as 26...
The Following 2 Users Say Thank You to cjd For This Useful Post:
drewbot (05-24-2016), e1_griego (05-24-2016)
Old 05-24-2016, 04:47 PM   #2383
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Triangles aren't the indicator of how far to roll the tire over. You should see a color change from tread rubber to sidewall rubber, aim there.
I'm running 28 hot in the rear, similar-ish wear. You'll wear the center rib at a taper when you really start using the tires
Old 05-25-2016, 05:20 AM   #2384
rx3
Originally Posted by renfield90
Looks pretty loose - is that a personal preference, or a consequence of damp/drying conditions?
No, that's what KW recommended. (It's actually pushy at corner entry, loose mid corner and stabilizes as soon as you hit the throttle.)
However, this was a practice run on road legal tires.
I told them that I'm running on slicks (I had to fill out a form where I needed to tell them the exact application) and on slicks it's not loose at all (exact same setting). I still think it's too stiff for an autocross application - they probably just sold me their 'Nordschleife-kit'.
But then again, it is fast (according to the clock).
rx3 is offline   Reply With Quote
The Following User Says Thank You to rx3 For This Useful Post:
renfield90 (05-25-2016)
Old 05-25-2016, 12:47 PM   #2385
renfield90
The Stig's German cousin
Yup.
Just in case this needs reiteration for people: triangles indicate there is a wear bar at that location on the tread.
Triangles don't mean anything about the end of the tread cap and the beginning of sidewall rubber. In fact, where it is in relation to the tread cap will change across different models of tire within the same manufacturer, let alone across different manufacturers.
A lot of people use the triangles on the RE-71R because by coincidence it gets you into the ballpark. But it's fundamentally not the right way to evaluate how far you're rolling over. Future production runs of the RE-71R could place the triangles in a different spot. Imagine yourself lowering pressure more and more to hit the new triangles spot, and thereby setting yourself up to chase your setup for months thinking "I got the tire pressures right, so what changed on the car?"
Interestingly enough the tread cap on the Rival S with those big massive shoulder blocks that *look* like they should tolerate plenty of rollover is pretty high up, such that a very large chunk of the shoulder blocks is actually not the rubber you're looking for.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
DocWalt (05-25-2016), smg1138 (05-25-2016)
Old 05-25-2016, 01:10 PM   #2386
smg1138
smg1138's Avatar
Thanks to everyone for the feedback. I guess I was misinformed about the triangles. I'm going to try a little more rear camber next time and see how that does. Really glad I got those adjustable lower control arms now.
Old 05-30-2016, 12:50 PM   #2387
AFRichZC6
AFRichZC6's Avatar
Does anyone here consider natural frequencies when choosing spring rates?
I'm considering joining STX next year.
AFRichZC6 is offline   Reply With Quote
Old 05-31-2016, 01:27 PM   #2388
smg1138
smg1138's Avatar
Anybody running the stock swaybars in STX with success? Right now I've got a Whiteline 20mm front bar and I can't get rid of the popping sounds. It performed great last time out, but the noises are driving me nuts. I already replaced the endlinks with shorter ones that I got from Feal, but the pops still persist. I'm wondering if maybe putting the stock bar back on and removing the rear bar might be the way to go? Either that or try the Strano bar maybe.
Old 05-31-2016, 01:41 PM   #2389
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
No issues with my Whiteline bar. That I'm aware of anyway, though I get popping from the right front I'm pretty sure it's spring bind on the perches as it makes a nice "boing" sound occasionally. I've been too lazy to take it apart and lube the tophat perch again. Have you tried just unbolting the end links and seeing if it's the coilovers?
FWIW I was tempted to try stock front swaybar and unhook the rear. As I've gotten faster I've found that I still have a good deal of roll in transition, even with the whiteline front bar so I'm not sure I'd want to try that now. I've not noticed having to wait for the car to settle, but if I'm literally toeing the line between waiting for roll and not waiting... That said, I am somewhat softly sprung, 60N/mm front & 70N/mm rear (343/400 lbs./in.) so take that with a grain of salt.
The Following User Says Thank You to DocWalt For This Useful Post:
smg1138 (05-31-2016)
Old 05-31-2016, 02:00 PM   #2390
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've won my class in both of the Chicago SCCA events so far on stock swaybars with my soft KW V3s (though STX in Chicago region doesn't seem terribly competitive at the moment), and I came second in the TSSCC event this weekend (0.7 seconds behind a FULLY prepped BRZ, whereas I have basically coilovers and tires.)
Having said that, I find the car rolls too much for my liking and would like at least one of my bars to be stiffer in the long run.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 05-31-2016, 02:01 PM   #2391
smg1138
smg1138's Avatar
I'm pretty sure it's not the coilovers that are causing the noise. I'm familiar with the spring binding "boing" noise, but this is totally different.
Before installing the Whiteline bar everything was dead quiet. It's only since I installed the bar the noises started. I thought the shorter endlinks would do the trick, but it seems to be something else.
Old 05-31-2016, 04:53 PM   #2392
cjd
cjd's Avatar
Drives: 2017 BRZ
Unless the rest of your setup is the same, it's going to be tough to have any other experience tell you that your car would be fine on stock sways...
I was stock but added a Strano front swaybar earlier this year and it's a huge help. 10k/12k f/r spring rates...
The Following User Says Thank You to cjd For This Useful Post:
DocWalt (05-31-2016)
Old 05-31-2016, 06:50 PM   #2393
Blue Gt
Blue Gt's Avatar
SMG I have the Strano bar on the front of my FR-S with Tein Coilovers and Whiteline end links. I had to flip the bottom stud around on the end link so it enters the sway bar eyelet from the inside to prevent clunking at full steering lock. Not sure if the clunking noise I had is the same as your popping noise? DP
Blue Gt is offline   Reply With Quote
The Following User Says Thank You to Blue Gt For This Useful Post:
Old 06-01-2016, 02:17 PM   #2394
smg1138
smg1138's Avatar
I forgot to mention the popping sounds only happen when I turn the wheel. I mostly notice it when pulling out of a parking spot or just turning the wheel when not moving. Put the car up on a lift last night to torque everything down and make sure the sway bar was centered. The noise went away for a while, but came back today after driving a bit. It's not a major deal, but pretty annoying since it's my daily driver.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
