Old 03-20-2015, 04:41 PM   #29
Ramster
Ramster's Avatar
Drives: Subaru BRZ Limited
Originally Posted by GotBRZ1691 View Post
Wait, so its the noise as your pushing the pedal in....
Balls, mine just started to do this. Dealership already has a new transmission waiting for me, might as well tell them to order a new clutch assembly while they are at it.
I was told that the clutch was covered under warranty when I purchased the car.
The whole clutch may not be necessary, just depends what they find when they take the transmission apart. Most likely your clutch and flywheel are perfectly fine.
Ramster is offline   Reply With Quote
Old 03-20-2015, 05:08 PM   #30
wheelhaus
wheelhaus's Avatar
Originally Posted by Ramster View Post
Here's the video of what mine sounds like. Finally got around to uploading it.
Like I mentioned though, it's gotten worse since then and it makes that noise through the entire motion of engaging and disengaging the clutch. Gets worse as the car warms up (barely noticeable at cold start).
If anyone wants, I can upload a more recent video with the worse sounds, just let me know.
Woah wait a minute... The car isn't running, so this is NOT a throwout bearing making noise. This sounds like the pedal assembly or possibly the release fork making some noise, but it's certainly NOT a throwout bearing.
A throwout bearing would be much harsher and louder, and would only happen when the engine is running, because the bearing needs to move to make noise.
edit- This noise is literally NOTHING to worry about, for all intents and purposes, it can even be called normal. Did you guys even read my post above?
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
btune (02-23-2017), Ramster (03-22-2015)
Old 03-20-2015, 05:20 PM   #31
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
At work so skim reading. Valid point about the car not running. Hopefully something just needs some lube but who knows.
My BRZ is my 3rd Subaru. Had different clutch issues with the past two. I have had the pivot point ball break through a fork before, had to replace a throw out bearing before, and now need a new transmission in the BRZ.
GotBRZ1691 is offline   Reply With Quote
Old 03-20-2015, 05:24 PM   #32
GotBRZ1691
GotBRZ1691's Avatar
But if i can get them to purchase me a new one, why wouldn't I. The dealership I go to is awesome and are easy to work with. I am sure there is some validity in the argument that the bad transmission has cause additional stress on the clutch assembly that is outside normal operating perimeters.
Old 03-20-2015, 05:32 PM   #33
wheelhaus
wheelhaus's Avatar
Here's a good video describing how the clutch works, the noise in the video Ramster posted is just things moving. Listening more closely, its probably a return spring or something creaking a bit. The throwout bearing highlighted in the video below needs to be spinning to make the noise that's a telltale sign of failure, or imminent failure.
[ame="https://www.youtube.com/watch?v=FfjGohWy-OU"]Learn How A Clutch Works In Less Than 5 Minutes - EricTheCarGuy - YouTube[/ame]
THIS video (also posted by Ramster on p1) is a completely failed throwout bearing, THIS noise is what you don't want to hear, but notice the noise isn't there until the car is running. The TOB in this video is completely siezed, and caused the car to move even when the clutch is depressed, because the clutch assembly is dragging on the TOB VERY badly as it spins. The bearing is squealing because it's now metal dragging on metal as it tries to spin.
[ame="https://www.youtube.com/watch?v=AOzIFnEm2-8"]Don't Ride the Clutch! Or THIS Happens featuring a Subaru Impreza - YouTube[/ame]
The Following 4 Users Say Thank You to wheelhaus For This Useful Post:
DAEMANO (03-20-2015), MINOCIN (03-21-2015), Ramster (03-22-2015), WRB5titch (03-21-2015)
Old 03-20-2015, 05:52 PM   #34
DAEMANO
Time Traveller
Second video @WRB5titch @danthedirt (whole vid is great, but get's juicy @ 5:30 mark)
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 06-08-2015, 12:31 PM   #35
Ramster
Ramster's Avatar
So I wanted to update this thread with my experience in case anyone for the future runs into the issue and searches this topic.
I changed out the clutch, flywheel, and the bearings (went with ACT lightweight kit) (awesome upgrade by the way). The stock parts (which I kept in case anyone would like pictures or videos) look still in good condition to me, but I have no experience with this so I can't say for sure.
The noises went away for a couple of months but have recently returned. There's no way any of my clutch parts are going bad since they're brand new with MAYBE 1500 miles on them. @wheelhaus was right. Probably just a lube issue which I'm not going to worry about anymore. Can't even hear the noise when the engine is off.
Hope this info helps.
Old 10-30-2015, 02:01 PM   #36
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by JB86'd View Post
For you guys that had your release bearing fail, stock clutch and flywheel? Any pedal height adjustments?
nope I have ACT clutch and flywheel plus am FI, but I'm only at 35k km so that is way early
anyone know if they make a more resistant one aftermarket (saw that ACT sells one but not sure if it is the same as oem or better quality)
fumanchu1 is offline   Reply With Quote
Old 04-25-2016, 10:01 AM   #37
Haulin
Haulin's Avatar
Drives: 2013 Toyota GT 86
Originally Posted by Teseo View Post
Seems op have resolved the failure, how was the trip to the bahamas?
It was awesome - hot & scenic.
Originally Posted by sirsol66 View Post
You might be the highest mileage FR-S I've heard of; may I ask what your ownership experience has been? If you could give us an overview, I'm sure many people would be interested. Thanks! (and good luck with the TOB)
The dealer sucks - period - as Toyota has always sucked (this is my 4th new Toyota). The vehicle itself has problems, but I still love it. The driving experience makes up for any flaws by far.
Haulin is offline   Reply With Quote
Old 05-29-2016, 06:35 PM   #38
HachiRo
Drives: 2013 White-Out FRS
Originally Posted by meeskee2 View Post
I just noticed a squeal/whining noise when I put my foot on the clutch. Started a few days ago and only occurs when the car is cold. Once it warms up, it seems to go away. I have about 75,000 miles on the car.
So has it been confirmed this whining noise is due to the Throwout Bearing?
Mine is making a high pitched whistling noise on cold start. Squeals as I'm accelerating off the clutch. If I'm clutched in, it makes a sputtering squeal.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 05:32 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
bearing clutch burnt out . clutch squeals aagun Issues | Warranty | Recalls / TSB 18 07-21-2014 11:40 AM
FS: NJ O.E.M. Clutch, flywheel, throw out bearing Michaeljp92 Transmission and Driveline 9 02-03-2014 11:42 PM
PTUNING-ACT Clutch Release Special-BRZ/FRS-Free shipping Mrc@ptuning Transmission and Driveline 1 11-14-2012 10:27 AM
