Old 05-27-2016, 04:10 PM   #1
Parmati
Parmati's Avatar
Drives: Subaru Brz Limited
Painted Stock Wheels - Graphite
Couldn't stand the stock wheels and didn't have enough money for new ones so i decided to paint them. After a long sanding process (took 2 1/2 to 3 hours), I used Rustoleum primer, VHT Graphite wheel paint and Dupli-color clear coat. Pretty happy with the results!
Also won't be washing them for at least a week so sorry if they're a bit dirty.
Parmati is offline   Reply With Quote
Old 05-28-2016, 01:26 AM   #2
Whooosah
Drives: FRS
That looks great! Would love to do the same to my wheels. What grit sand paper did you use and how many coats of paint?
Whooosah is offline   Reply With Quote
Old 05-28-2016, 02:18 AM   #3
Parmati
Parmati's Avatar
Thank you!! I used a cup brush (attaches to a driver), followed by 320 grit and then 1000 grit to smooth it out. 3 coats of primer, 2-3 coats of color, and 2-3 of clearcoat.
Old 05-28-2016, 02:22 AM   #4
Whooosah
Drives: FRS
Nice cup brush that's a good idea I'll keep that in mind.
Sent from my SM-G920V using Tapatalk
Old 05-28-2016, 03:41 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Great job! Looks a million times better than how the wheels look stock.
Originally Posted by humfrz
I'm old and lazy
Old 11-16-2017, 12:14 AM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
Would love an update on how the finish held up but OP hasn't been on in a while...
@Parmati
Old 11-16-2017, 08:58 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
This is the color they should've come in, I hate the two-tone stock ones.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-16-2017, 09:58 PM   #8
wparsons
wparsons's Avatar
You probably don't need to go any finer than 400 grit before primer, and 800 grit if you need to smooth out after primer.
flickr
Old 11-16-2017, 10:30 PM   #9
ermax
ermax's Avatar
I pained my IS300 rims with a very similar process. Took me a full weekend of basically working on it all day both days. Cleaning and sanding was the hardest part. I used Dupli-Color for the primer, base and clear on mine. Did 3 coats of each. My IS300 is black and I also went with graphite. It came out really nice and held up fine for the past year. The only problem I have with mine is at the lip of the rim. If you aren’t taking the tires off it’s hard to clean the lip and also hard to get a good coat on the lip. So my rims now have the original surface coming through just a tad. Not that noticeable unless you get close. But the main surfaces still look perfect. Nice gloss finish still.
To really do this job right I would say you need to do it with the tires off.
I like how the FRS rims look in graphite. I may have to do this on mine the next time I am due for tires.
fr-s & brz, graphite, paint, stock wheels, vht, wheels
Plastic dip painted wheels gmanvilla1@gmail.com Scion FR-S / Toyota 86 GT86 General Forum 16 05-18-2016 09:22 PM
Rays Gramlights 57Xtreme - 18x9.5 +40 - Matte Graphite - IN STOCK NO WAIT! No Limit Motorsport Wheels and Tires 48 04-08-2016 03:07 PM
New wheels finally on - TE37SL Pressed Graphite 18x9.5 brianlo622 Northern California 31 03-18-2014 02:17 PM
Anyone painted oem wheels white? dave77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-01-2013 12:03 AM
Painted my wheels and calipers WhiteFR-S BRZ Photos, Videos, Wallpapers, Gallery Forum 24 11-27-2012 12:07 PM
