Old 05-26-2016, 09:23 AM   #1
csmith171
Drives: 2013 FRS
Vortech V3 with 3.12 pulley, what supporting mods do I need?
I have a frs with a uel header and a full catless exhaust, I purchased a v3 kit second hand, and it comes with a 3.12 pulley. Do I need injectors and a pump upgrade? And if i do would 540cc injectors and a walbro 255 suffice?
csmith171 is offline   Reply With Quote
Old 05-26-2016, 01:30 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You need Jesus.
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
avishenoy1 (05-27-2016), continuecrushing (05-26-2016)
Old 05-26-2016, 01:45 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by SkAsphalt View Post
You need Jesus.
Amen
Old 05-26-2016, 10:41 PM   #4
stevo585
Drives: White 2014 BRZ
The usual clutch, oil cooler. Those are plenty on pump gas. e85 most likely be enough as well.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 05-27-2016, 12:09 AM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
My previous tuner suggested only a fuel pump upgrade when doing the 3.12" pulley, I opted for the fuel pump and 650?cc injectors for e85 in the future.
Stock clutch, no problems so far close to 30K miles
93oct pump gas, no issues with IAM dropping or knocking
I have no oil cooler and do not really notice temps above 235F, but that is street driving
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 05-27-2016, 12:19 AM   #6
stevo585
ok well 235 isnt crazy if your on a 5w30wt oil. On a 0w20 thats going to be sub optimal oil pressure.
The Following User Says Thank You to stevo585 For This Useful Post:
Old 05-27-2016, 10:52 PM   #7
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
and where do you have the proof for that statement? EDIT: sorry, I thought you mean 235whp or something, i noticed you meant temperature. I would stick with 0w20, as that is what most track drivers on this forum suggest, but also a cooler (duh)
I do not get hotter than 110C with my turbo...no cooler. But on a track I could see it getting hot for sure.
Old 05-28-2016, 08:04 AM   #8
AJPG
Drives: 22RE, FA20, 4G63
Hi,
My car have a sc plus oil cooler and temp with:
1. normal driving (more or less flat road and relative constant speed) oil temp keep around 185f and coolant 195f.
2. Traffic bumper to bumper at <10mph oil 195f coolant 195f (that's with the AC on) without the AC 212f both.
3. Spirit drives
A. The back road around the house 22.3 miles, elevation from sea level to 1,600 fts, total elevation 2,450 fts, time (less than 30 minutes) with the AC on oil around 200f as well as coolant, without the AC oil around 210f and coolant around 212f.
B. The back road trough the west of the island 67.8 miles, elevation fron sea level to almost 5,000 fts, the temps are lower than around the house due to increase risk.
C. Track... Things get hot. Without the AC water reach 225f and oil 235f; also and getting of topic the AT oil with the oem oil cooler and 10 lines oil to air gets to the 240f plus (thinking on using a fan if could get more track time), the sc oil 212f.
I would recommend the use of an oil cooler even for a stoke car use for DD, is like buying health. Could use any cooler (if found the space) and the only drawback that I could see is oil getting out but that is mechanic/part related.
AJPG is offline   Reply With Quote
Old 06-13-2016, 10:42 AM   #9
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
When I did mine, I went with the Perrin Oil Cooler, Radium Catch cans and a new Radiator.
Along with that, I've added an AFR and oil temp / pressure gauge.
The Radiator is not so important, stock one is good - but the catch cans important to keep blowby from coating the inside of the FMIC.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
What supporting Mods do you REALLY need? Adrian002 Forced Induction 27 05-09-2015 08:27 PM
Supporting mods for higher rev limit? radroach Engine, Exhaust, Transmission 6 12-01-2014 10:53 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 08:56 PM
Supporting Mods For F/I Applications Tansey86 Forced Induction 59 02-26-2013 01:42 AM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
