Old 05-22-2016, 04:26 AM   #743
maca
Drives: brz
Originally Posted by xsnapshot View Post
Has anyone found a way to monitor knock or IAM via torque or any other OBDII reader app?
I have Ecutek, but it would be nice to just be able to plug up my phone and monitor that way.
It's the same for me!
Inviato dal mio HUAWEI GRA-L09 utilizzando Tapatalk
maca is offline   Reply With Quote
Old 05-25-2016, 06:21 PM   #744
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
In Torque Pro you can install the knock test. Although you can't monitor it. With EcuTek Racerom you will see the check engine light flash if you receive a knock.
https://play.google.com/store/apps/d...kills.kd&hl=en
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-27-2016, 02:21 PM   #745
maca
Drives: brz
I think knock test plugin doesn't work, I try it in my Mazda Miata NC and in my BRZ making a comparison in same test conditions where OFT first and EcuTek datalogging later read some
"knock corr." (OFT) and "knock correction ca" / "knock correction learn value ca" (EcuTek).
About check engine light flash:
I haven't tuned BRZ yet, are you sure? I asked about this feature 6 month ago directly to ecutek support and they reply me :
"Unfortunately the Custom Fuel Economy Gauge Display feature had to be removed as it was causing problems in other systems such as the ABS system (where the gauge took vehicle speed from the ABS sensors to make the economy calculation)
We tried very hard to make the feature work but the vehicle would just not allow it.
Old 05-31-2016, 04:49 PM   #746
cebul
Drives: Gt86 UKDM
Hi, just downloaded and installed Torque. I've communicated with the car but can not add that oil temp PID... anybody can help?
This aseptic screen shots from my settings page:
Sent from SG Smartphone.
cebul is offline   Reply With Quote
Old 05-31-2016, 04:51 PM   #747
Calum
That Guy
Drives: 2013 asphalt FRS MT
Check your Bluetooth connection again. If you're using one of the cheap elm327 dongles they're pretty notorious for losing connection.
Old 05-31-2016, 04:53 PM   #748
cebul
Drives: Gt86 UKDM
But I'm connected with the car with no problem, all.other parameters are fine example. Revs, coolant temp, exc.
Just can not get oil.temp Pid displayed on the real time data screen.
Old 06-06-2016, 11:15 AM   #749
cebul
Drives: Gt86 UKDM
All sorted now,,have had issue with my Torque
Old 07-30-2016, 03:32 PM   #750
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
So I read the entire thread and decided to get a Scantool.net OBDLink LX. Paired it with Torque Pro and it seems to work well.
A few things to mention:
1. There was a lot of confusion it seemed regarding oil temperature in the thread. I can confirm that I used the built in oil temperature sensor in Torque Pro and it worked. Didn't have to input any PIDs. I believe this is because the developer has added the PID to torque, so any new users don't need to worry about doing it. Just wanted to emphasize this.
2. Anyone using Throttle vs. PedalD vs. PedalE? I am interested in logging one of these for auto-cross to visualize my inputs to the car. However, I'm not sure which to use. Throttle was in the torque HUD by default; however it doesn't read the same as pedalD and pedalE. PedalD and PedalE seem to read approximately the same, but not quite.
3. Regarding the OBDLink LX: anyone else having a hard time getting it to go to sleep? I played with it 5-6 times (connecting w/ car on, then turning car off, then waiting 10-15 minutes). The only way I can get it to go to sleep is if I turn off bluetooth on my phone. Otherwise, my phone maintains a connection with the OBD reader, and won't let it sleep. If I turn off bluetooth, the OBD reader monitors the voltage, looking for a <0.1 Vpp ripple (as specified in the Torque settings). It seems to reliable turn off after ~10 minutes. However, it'd be nice for this to happen without turning bluetooth on my phone off. I am mostly paranoid I will forget to turn bluetooth off one day and then I could potentially drain my battery if I don't drive my car for a few days. Any input on this would be appreciated!
BR-ZED is offline   Reply With Quote
Old 07-30-2016, 04:31 PM   #751
Teseo
Drives: frs
Bough the app, where i can found the oil temp?
Old 07-30-2016, 07:58 PM   #752
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Look at the 2nd post on this thread
Old 07-30-2016, 09:16 PM   #753
BR-ZED
BR-ZED's Avatar
See my post above yours! This is what I was referring to about the confusion about the oil temp! Oil temp should work by simply adding it in torque to your dashboard!
Old 07-30-2016, 09:59 PM   #754
Teseo
Drives: frs
Expected more info
Old 07-30-2016, 10:44 PM   #755
Skyllz
Drives: Something fun.
I'm BRZ shopping right now, I need to scratch that itch, should not have sold mine 2 years ago...
I tried using Torque on my Crosstrek to check the Calibration ID and only ended up with the first 3 digits(EP5 in my case). Does torque provide the full calibration ID to make sure the recalls have been done on a 86? Not just ZA1 for example.
Skyllz is offline   Reply With Quote
Old 08-02-2016, 08:01 PM   #756
Skyllz
I tried using Torque on my Crosstrek to check the Calibration ID and only ended up with the first 3 digits(EP5 in my case). Does torque provide the full calibration ID(ZA1JA01G) to make sure the recalls have been done on a 86? Not just ZA1 for example.
I'm going to look at one tomorrow, anyone knows?
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
