| Software Tuning Discuss all software tuning topics. |
Drives: 15' FRS
Diasbled Loud Cold Start with OFT
Hello!
The moment I received the OFT tablet, I flashed the car with the stage 1 91 tune and loved the subtle but effective differences the tune gave the car. The first thing I wanted to was to make the cold starts less obnoxiously loud every morning. I just have a catback which happens to be on the loud side and I would rather stay friends with my neighbours. I followed one of the threads and ended up modifying tables as such using RomRaider. I read somewhere to change all 1400+ to 1400 but even that was loud so I opted for 1200. Is it safe? Or should I leave the Idle Control values as it is on the stock map? I am a complete noob on OFT related things and this is my first attempt on doing anything related to it. Please understand if changing that was completely idiotic! I would greatly appreciate it if you guys had a look at it. Thank you! |
#2 |
Drives: FT86
yes dropping max idle rpm to 1200 should be ok
you might want to leave a little more maf compensation in at very low temps also the post ignition timing try using -4 or -6 degrees you have a positive value in their, it will work but it tends to sound realy crap once you reduce the retard beyond about -4 (originally it was -15) just be carefull and make sure you get the decimal points and the minus signs in where they are supposed to be else weird stuff will happen |
#3 |
Drives: 15' FRS
Thank you so much!
I changed the MAF Correction after cold start for both Neutral and In Gear for 14F to 9 g/s. Not sure if 'very cold temps' were referring to that row only. Also why is it only necessary to change Idle Control Target A and E? Tried starting the car and idled at 1500 rpm. Thank you so much for your reply
#4 | |
He meant idle tables A-E (essentially all of them)
#5 |
Drives: FT86
correct you need to do all idle tables .
#6 |
Drives: 15' FRS
Everything works now thank you guys!
#7 |
Drives: 1991 Acura NSX
Question: I changed the idle to 1400 and the ignition timing to -4 (it goes to -3.83 when I do) but now my throttle feels like I need to hit it a bit harder to get the car moving to the point I even stalled once. Does anybody know why the throttle sensitivity would have changed?
#8 | |
Drives: FRS
#9 | |
| Loud misfires upon cold start | connorlug | Issues | Warranty | Recalls / TSB | 42 | 03-31-2016 04:43 PM |
| Cold Start, engine makes loud pop sound | BTXP.XD | Issues | Warranty | Recalls / TSB | 10 | 05-20-2015 10:32 PM |
| LOUD KNOCK during cold start | Flat_4_Life | Issues | Warranty | Recalls / TSB | 23 | 03-18-2015 05:30 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
