#57 |
Drives: 10 Series #974 6m/t
| The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post: | CxG (01-14-2017), Kaotic Lazagna (05-25-2016) |
#58 |
Drives: Asphalt FR-S MT
| The Following User Says Thank You to kcam86 For This Useful Post: | Pure Automotive (05-25-2016) |
#59 |
Drives: 2013 FRS
Do i spy cxracing motor mounts?
#60 |
#61 |
Drives: Subaru BRZ
#62 |
Drives: 2013 FRS Whiteout
The harness can be produced with the factory ECU plugs. There is a lot of other wiring in order to have dash function but you can utilize a stock ecu, I wouldn't recommend it, but you can.
| The Following User Says Thank You to Pure Automotive For This Useful Post: | Draco_PR23 (05-26-2016) |
#63 |
No. I can post the weight of mine later to show roughly how it looks, but if you're worried about weight balance engine swaps aren't for you. The boxer sits lower and further back than any other motor can ever do.
| The Following User Says Thank You to Pure Automotive For This Useful Post: | CxG (01-14-2017) |
#64 |
#65 |
#66 |
Drives: 2013 FRS
#67 |
Not sure yet, they are usually somewhere between questionable and good enough lol. I may try pieces here and there to find repeatability, but I'm not going to rely heavily on them. I have a perfect swap intake manifold for you if you're doing a swap. I have one that clears the booster and lowers the plenum down away from the hood. Email me if you're interested.
#68 |
Drives: FRS RS 2.0
Sub
Sent from my SM-G900V using Tapatalk |
#69 | |
Now w/ over 400 womprats!
Drives: BRZ LZR
http://www.mazworx.com/store/p/208-M...num-Block.aspx
- The Ancient BRZ Sacrament by Zaku |
#70 | |
Site Moderator
Drives: ichi 86 Project
| Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-20-2015 11:50 PM |
| $2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 11:23 AM |
| There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
