Old 05-25-2016, 02:06 PM   #57
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by Norville Rogers View Post
Cheers for the update.
I'm new to this jdm stuff, what is special about the engine?
Dude a little over 10k in overnight parts from Japan and this will decimate anything at Race War.
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
CxG (01-14-2017), Kaotic Lazagna (05-25-2016)
Old 05-25-2016, 04:46 PM   #58
kcam86
Drives: Asphalt FR-S MT
[ame="https://www.youtube.com/watch?v=0jD1Ome8jyA"]"You know what" - The Fast and the Furious - YouTube[/ame]
lolllll I knew that sounded familiar!
kcam86 is offline   Reply With Quote
The Following User Says Thank You to kcam86 For This Useful Post:
Pure Automotive (05-25-2016)
Old 05-25-2016, 04:50 PM   #59
ft86xtc
Drives: 2013 FRS
Do i spy cxracing motor mounts?
ft86xtc is offline   Reply With Quote
Old 05-25-2016, 04:56 PM   #60
kcam86
Ya more than likely as they have them on their shop car. I could be wrong though.
Old 05-25-2016, 05:09 PM   #61
Norville Rogers
Drives: Subaru BRZ
Race war?
Norville Rogers is offline   Reply With Quote
Old 05-25-2016, 05:49 PM   #62
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by nickmerronesucks View Post
Main issue, As I don't mind doing any of the other crap. Are you guys working on being able to supply a plug and play harness? with stock ECU? I would like to just do a simple swap down the road. 1jz vvti with a power fc and exhaust.
The harness can be produced with the factory ECU plugs. There is a lot of other wiring in order to have dash function but you can utilize a stock ecu, I wouldn't recommend it, but you can.
Pure Automotive is offline   Reply With Quote
The Following User Says Thank You to Pure Automotive For This Useful Post:
Draco_PR23 (05-26-2016)
Old 05-25-2016, 05:51 PM   #63
Pure Automotive
Originally Posted by nickg View Post
Will you be doing anything to help correct the weight distribution? I'm planning on a similar swap way down the road when it's more documented and supported, but I wouldn't want to destroy the handling.
Sent from my XT1575 using Tapatalk
No. I can post the weight of mine later to show roughly how it looks, but if you're worried about weight balance engine swaps aren't for you. The boxer sits lower and further back than any other motor can ever do.
CxG (01-14-2017)
Old 05-25-2016, 05:53 PM   #64
Pure Automotive
Yea they are, I haven't messed with them too much since we still have some moving around to do but so far I'm not in love with them.
Old 05-25-2016, 05:54 PM   #65
Pure Automotive
We have Xcessive mounts in my car, they sit up a little higher than the CX and they are very different construction.
Old 05-25-2016, 09:35 PM   #66
ft86xtc
Drives: 2013 FRS
Yeah i got the Xcessive mounts, will you guy be running any other CX swap parts?
Old 05-25-2016, 10:05 PM   #67
Pure Automotive
Not sure yet, they are usually somewhere between questionable and good enough lol. I may try pieces here and there to find repeatability, but I'm not going to rely heavily on them. I have a perfect swap intake manifold for you if you're doing a swap. I have one that clears the booster and lowers the plenum down away from the hood. Email me if you're interested.
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
bakerr6 (06-01-2016), Guff (05-26-2016)
Old 05-26-2016, 01:09 PM   #68
gypsy_seven
Drives: FRS RS 2.0
Sub
Sent from my SM-G900V using Tapatalk
gypsy_seven is offline   Reply With Quote
Old 05-26-2016, 01:16 PM   #69
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
You could always try this:
http://www.mazworx.com/store/p/208-M...num-Block.aspx
- The Ancient BRZ Sacrament
by Zaku
The Following 2 Users Say Thank You to Guff For This Useful Post:
CxG (01-14-2017), flippy (07-25-2016)
Old 05-26-2016, 01:50 PM   #70
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
WTF?!?!?! That thing only weight 86lbs?!?!?! ...but it comes w the price too. Ouch!
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
Decay107 (05-26-2016), flippy (07-25-2016), Guff (05-26-2016)
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 08:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
