| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#505 |
| The Following User Says Thank You to CSG David For This Useful Post: | GT86_PRAGUE (05-02-2016) |
#506 |
Drives: 2013 GT86
You can see the amount of tyre roll I'm getting here, nowhere near the sidewall and these re002's are known to have a soft wall. Having 225's on the 7" rim has the tyre sitting more taught and creating more sidewall strength IMO. A definite rounded (balloon) profile though, which has tyre movement characteristics that take some getting used to. Still mass amounts of over steer (I run 38 psi). I previously had the same tyre on the stock 16" rim but in a 205/55 and that would roll on to the sidewall when pushed hard. I recently put in a rear strut tower with great results, it honestly feels like I have wider tyres at the back (more grip in corners) highly recommended
![]() Last edited by MacOverSteer; 05-01-2016 at 01:56 AM. |
| The Following 2 Users Say Thank You to MacOverSteer For This Useful Post: | funwheeldrive (05-13-2016), korhun (06-19-2019) |
#507 |
Drives: 2016 Subaru BRZ WRB
The Firestone Firehawk Indy 500 seem to be a good tire and an improvement over the OE tires for more then half the price.
| The Following User Says Thank You to BWilky For This Useful Post: | why? (04-25-2017) |
#508 | |
Drives: GT86
#509 | |
Drives: 2013 GT86
| The Following User Says Thank You to MacOverSteer For This Useful Post: | korhun (06-19-2019) |
#510 |
Hi all,
I wasn't sure if we should consider a starting a new thread for 16 inch wheel brake upgrades or big brake kits for track, street, autocross etc that will fit 16 inch only? ! It could include weight loss, cost etc. Thanks!! |
#511 |
Drives: '14 Whiteout Pearl
I've looked all over this post - and maybe I'm not looking in the right place, but is there a wheel someone is using that is 7" x 16" with the positive offset listed, WITH the brand of the wheel?
thx Last edited by iManage; 08-17-2016 at 12:02 PM. |
#512 |
[QUOTE=iManage;2714074]I've looked all over this post - and maybe I'm not looking in the right place, but is there a wheel someone is using that is 7" x 16" with the positive offset listed, WITH the brand of the wheel?
If you run 16" diameter wheels, on a 7 (or 8) inch width, can you post the exact sizes with positive offsets, WITH the tire size AND the exact brand? Pictures are great, but I can't read the offsets or the tire sizes. [QUOTE=iManage;2714074] Based on http://www.ft86club.com/forums/showthread.php?t=7535 16 x 7 will need a 25 offset for flush not lowered and 24 for flush and lowered an inch.
| The Following 2 Users Say Thank You to BWilky For This Useful Post: | funwheeldrive (05-03-2017), iManage (08-14-2016) |
#513 |
#514 |
Drives: 2015 Subaru BRZ Sport Tech
Some GC Subaru goldies on my 2015 BRZ. Currently running 25mm spacers because I'm only running 205/50R16 rubber.
![]() Sent from my HTC One M9 using Tapatalk |
| The Following 3 Users Say Thank You to FLIPDADY For This Useful Post: |
#515 |
Only happy when it rains.
Drives: series.blue
that is probably going to be very wheel dependent. None of the usual so called big break options would fit, so you'd probably have to make your own kit. I doubt there is any need for its own thread.
#516 |
Drives: 2014 GT86
I wouldn't be so sure that no BBK will fit. Imho there should be several 16" that can work with something like eg. Sprint kit.
#517 |
Hi all,
Got a cg8 sti wheel 16x7 +53 offset, With 225/50/16 tyres. When I put them on it gets too close to the shock/spring. Do you guys think 3mm spacer should be enough to clear it? |
#518 |
Drives: 2013 Firestorm FR-S
Done a fair bit of searching on the threads, but haven't found much info.
Is, or has, anyone run a 16x6 wheel on their car? I'm looking at picking up a set of wheels from a 2001 Pontiac Sunfire GT, for a funky new winter setup, but was curious to see if anyone had test fitted anything around this size yet. It's tough to find concise data on them, but from what I've gathered it sounds like the offset is +47. I've run 16x6.5 for winter before, and am guessing it would be fine, but wanted to find out if anyone had test fit similar wheels already.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 04:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 06:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-27-2012 11:20 PM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 08:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 11:17 AM |
