Old 05-19-2016, 03:58 PM   #15
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
What are the dimensions of your intake and exhaust tubes (just radius will do). I'm thinking your intake may be too big or the correlation between the intake and exhaust is off (really hard to tell without actually seeing it in it's functions.
If both exhaust and intake are about the same size, try reducing the intake size and if that doesn't help try enlarging the exhaust (your goal is to create a type of vaccum) think car windows (when you have one opened wide and the other cracked) that should ideally be how the air travels in there. The heat should push itself out the exhaust(top).
fumanchu1 is offline   Reply With Quote
Old 05-19-2016, 04:02 PM   #16
Ashikabi
Ashikabi's Avatar
Intake is 2.5x2.5x4 divided in half for twigs and air. Burn chamber/exhaust is 3.5x3.5x7. These are outside dimensions
Old 05-19-2016, 04:06 PM   #17
fumanchu1
can you easily make your twig chamber a bit bigger and the intake a bit smaller? (without much work? if so try that and if that doesn't work try the opposite. Even if it sounds counter productive to try the opposite it would work if your issue is intake size vs exhaust size).
Physics wise, the gasses shouldn't have much issue escaping it's getting them to the chamber that seems to be the issue at this time.
Old 05-19-2016, 04:07 PM   #18
fumanchu1
You could always just make yourself or purchase a barrel smoker
Old 05-19-2016, 04:11 PM   #19
Need more chimney height and get the twigs up off the base so the air can go around them. The chimney height is not long enough to get the heated air moving at the velocity it needs to draw enough air into the intake. Another 4 or 5 inches should make all the difference. If you want to back pack it you could just make an extension that slips over the top and save some size.
Or...
Old 05-19-2016, 04:18 PM   #20
Ashikabi
Ashikabi's Avatar
Or...
Picture not loading. Chimney can't get taller cuz it needs to fit in a paint can. I'll see if I can't find another piece of tube to experiment with a longer chimney to prove or disprove you though. I read it should be 3 times taller than the inlet tube diameter, which it's pretty close to. I only tacked in the twig shelf so it should be able to move
Old 05-19-2016, 04:27 PM   #21
Picture not loading. Chimney can't get taller cuz it needs to fit in a paint can. I'll see if I can't find another piece of tube to experiment with a longer chimney to price or disprove you though. I read it should be 3 times taller than the inlet tube diameter, which it's pretty close to. I only tacked in the twig shelf so it should be able to move
Pic is a turbo.
The chimney should be three times taller than the diameter of the intake as measure from the top of the intake. Based on your drawing that leaves about 5 inches above the intake. That is about 3 inches short (that's what she said).
You can also install a flapper on the intake to control the draft.
Old 05-19-2016, 04:35 PM   #22
Ashikabi
Ashikabi's Avatar
Pic is a turbo.
That makes sense, they left that part out. I found another piece of tube so I'm going to cut it down to 4 inches and see what happens
Old 05-19-2016, 04:42 PM   #23
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Or...
Solution to everything right here. Turbo rocket stove hype
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
ZionsWrath (06-02-2016)
Old 05-19-2016, 04:50 PM   #24
Ashikabi
Ashikabi's Avatar
I actually have a little 120v 3cfm(ish?) Blower motor that looks like a turbo. My buddy got it for his forge then realized it was wildly under powered for what he needed
Old 05-19-2016, 04:51 PM   #25
I'd make the intake and exhaust the same diameter; just make the exhaust taller than the intake is long.
OR, just lay some shaved pieces of C-4 in the firebox of what you have and light it ......
Tcoat (05-19-2016)
Old 05-19-2016, 04:53 PM   #26
Ashikabi
Ashikabi's Avatar
I'd just make the intake and exhaust the same diameter; just make the exhaust taller than the intake.
OR, just lay some shaved pieces of C-4 in the firebox and light it ......
I've heard great things about c4. Really hot, no smoke, etc, etc. I'll cut a piece of 2.5x2.5 too and see if that one performs better(I have 2 prototypes, one with 3.5 chimney and one with 2.5)
The Following User Says Thank You to Ashikabi For This Useful Post:
humfrz (05-19-2016)
Old 05-19-2016, 04:58 PM   #27
C4 burns GREAT. Not that I could possibly know from experience or anything though.
humfrz (05-19-2016)
Old 05-19-2016, 05:30 PM   #28
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
C4?
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
NYC info frs10 NY / NJ / CT / PA 11 03-28-2014 11:11 PM
info koyv90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-20-2013 08:55 PM
Any info on this? jkonquer BRZ First-Gen (2012+) — General Topics 1 02-27-2013 04:38 AM
