Old 03-10-2016, 09:31 AM   #351
churchx
churchx's Avatar
Drives: 2014 GT86
Harder? For those steeling professionally? No. A bit more hassle/time, a bit upping your chances. If your wheels costs $3K, thieves can work around few extra inconveniences to buy most common locking lug nut tools covering 90% of them used. Or damage car/wheels in spite. Certainly not something i would rely on as something definite. Can also be extra headache on track days, where you may switch wheels often and without lug nuts you could have used any borrowed simplest wrench.
shaynek (03-11-2016)
Old 03-11-2016, 02:35 PM   #352
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
joined the club
Here is how they look on the car. the winning blue has grown a bit on me but i wish i had gone with a staggered set up rather than square. 18x8.5 +33 all around. If anyone knows someone who has the same color wheels but with 9.5s i will be willing to trade two of the wheels with them.
shaynek is offline   Reply With Quote
Old 03-14-2016, 06:28 AM   #353
ZZT86
ZZT86's Avatar
Drives: BR86
57Xtreme 18x8.5+42 Face 2 - Squared
57Xtreme 18x8.5+42 Face 2 (Squared) on 225/40/18 tyres
Eibach camber bolts up front set to -1.5deg camber, rear is about -1deg camber & -1.5mm toe in using SPC LCA. Eibach ProKit on an otherwise stock strut.
Inner wheel/tyre clearance is 4mm up front - wheel no chance of touching, tyre is 4mm away but after a few thousand k's driving there's no rubbing anywhere.
I love these wheels
Edit: Forgot to mention weight:
OEM 17x7 wheel/Primacy tyre = 18.7kg (virtually new tyre)
RAYS wheel/ContiSport5 new tyre = 18.8kg
Edit: corrected rear camber with SPC LCA
ZZT86 is offline   Reply With Quote
Old 03-14-2016, 10:05 PM   #354
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
I just bought these wheels and was wondering if the hub centric rings were necessary for the brz? I can't really seem to find a straight answer to this
Legionsk88 is offline   Reply With Quote
Old 03-15-2016, 05:39 AM   #355
ZZT86
ZZT86's Avatar
Drives: BR86
You will if it's not the same 18x8.5+42 size (as above) which is made for the 86 with the perfect hub bore of 56mm. All the other sizes appear to be 65mm.
https://www.rayswheels.co.jp/product...wheel=57EX_STD
Old 03-28-2016, 01:24 PM   #356
Daver
Hello Gents
If I want to run 18x8.5 +33 up Front and 18x9.5 + 40 in the rear, can I do this on the Stock suspension?
Need I purchase any other components? Hub Centric rings?
Would Both flat front and face2 fit on the front, (stock suspension)
What tire size would be ideal for the above set?
I will drop later slightly but Do not want to be on the hook for coilovers and wheels all at the same time.
Sorry I have been reading threads left and right, and getting some conflicting info. Thanks Guys!
Daver is offline   Reply With Quote
Old 04-25-2016, 07:14 AM   #357
ZZT86
ZZT86's Avatar
Drives: BR86
^^ sure the above specs will fit although hubrings will be required. Tyre choice will depend if you care for rolling diameter or not - personally I wouldn't stagger but I would fit 225/40 @F & 255/35 @R on those rims.
BTW - anyone here got any tips for cleaning these Rays 57Xtr wheels ?
Old 05-19-2016, 12:50 PM   #358
whip
Drives: 2014 FRS MT
anyone know how wide your tires need to be to cover the gigantic lip on these wheels?
whip is offline   Reply With Quote
Old 06-17-2016, 02:39 PM   #359
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
What kinds of tires are most people running?
Im currently on 245/35 front and 255/35 rear MPSS and the tires are seeing close to the end of their life. Looking for something a bit grippier than them but cant find many tires that offer both those sizes.
Instagram: trevor.parque
Old 06-17-2016, 03:46 PM   #360
Legionsk88
Legionsk88's Avatar
265 is enough
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 07-11-2016, 01:29 AM   #361
pimpfighterroq
Drives: Raven 86
Eibach camber bolts up front set to -1.5deg camber, rear has similar atm which will be adjusted soon. Eibach ProKit on an otherwise stock strut.
I love these wheels
Where did you buy these wheels? Evasive? I'm on stock suspension. Do you think I'll have rubbing issues if i buy these with MPSS 225/40 tires?
pimpfighterroq is offline   Reply With Quote
Old 07-11-2016, 09:07 PM   #362
ZZT86
ZZT86's Avatar
Drives: BR86
Those tyres same size as what I got & sorry I don't live in the good ol US clearance will be fine unless you go more neg camber up front .
Old 07-13-2016, 11:48 PM   #363
Brayden_23
Drives: Asphalt 2015 FRS
Just got mine put on yesterday! 18x8.5 +42 squared with 235/40 MPSS (stock suspension)
If anyone is looking for more pictures of the fitment, I have them here: http://www.ft86club.com/forums/showp...3&postcount=12
Brayden_23 is offline   Reply With Quote
Old 10-24-2016, 01:18 PM   #364
novice
novice's Avatar
Drives: Fr-S 2.0 Release
I love these wheels
Nice I am looking at these wheels. Would this work on stock springs?
novice is offline   Reply With Quote
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
