Old 04-29-2016, 02:25 PM   #505
CSG David
CSG David's Avatar
Originally Posted by GT86_PRAGUE View Post
Do these fit the Essex Sprint BBK? Thanks.
It is not recommended due to less than 3mm of clearance. We recommend using a small spacer for optimal clearance. Thanks!
The Following User Says Thank You to CSG David For This Useful Post:
GT86_PRAGUE (05-02-2016)
Old 05-01-2016, 02:20 AM   #506
MacOverSteer
MacOverSteer's Avatar
Drives: 2013 GT86
You can see the amount of tyre roll I'm getting here, nowhere near the sidewall and these re002's are known to have a soft wall. Having 225's on the 7" rim has the tyre sitting more taught and creating more sidewall strength IMO. A definite rounded (balloon) profile though, which has tyre movement characteristics that take some getting used to. Still mass amounts of over steer (I run 38 psi). I previously had the same tyre on the stock 16" rim but in a 205/55 and that would roll on to the sidewall when pushed hard. I recently put in a rear strut tower with great results, it honestly feels like I have wider tyres at the back (more grip in corners) highly recommended
MacOverSteer is offline   Reply With Quote
The Following 2 Users Say Thank You to MacOverSteer For This Useful Post:
funwheeldrive (05-13-2016), korhun (06-19-2019)
Old 05-19-2016, 01:27 PM   #507
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Originally Posted by blackstripe77 View Post
So I just found that the Potenza RE003 appears to have been introduced to the US as the Firestone Firehawk Indy 500 if anyone was looking for a new UHP tire.
The Firestone Firehawk Indy 500 seem to be a good tire and an improvement over the OE tires for more then half the price.
BWilky is offline   Reply With Quote
The Following User Says Thank You to BWilky For This Useful Post:
why? (04-25-2017)
Old 05-20-2016, 04:55 AM   #508
Trettiosjuan
Drives: GT86
Sorry to be critical and off topic, but highly sceptical there. Your suspension sits on a subframe that creates the link left-right with bushings to the body. The top of your suspension struts, if there is any flex, will do so mostly upwards as the do not transfer any sideloads to speak of, hinged as the are on the lower arms. But I haven't tried a rear tower strut so I could be mistaken
Trettiosjuan is offline   Reply With Quote
Old 05-21-2016, 03:27 AM   #509
MacOverSteer
Drives: 2013 GT86
That's what a strut tower works on, upward force from the the suspension. It try's to minimize this by linking the two strut heads. I was skeptical too because of the rear wishbone suspension, don't get me wrong it doesn't feel like I have 255's up back. I tend to get more of a grab/dig in mid slide, just gives me a little more confidence when pushing. I have a strut up front too and that's a must due to the macpherson setup, all of this means little to those who swapped out the oem suspension. So the real reason I got a rear strut was to maybe cancel out some of the squeaks n creaks and it may have done that a little.
The Following User Says Thank You to MacOverSteer For This Useful Post:
korhun (06-19-2019)
Old 05-23-2016, 01:47 AM   #510
makesdrivingfunagain
Hi all,
I wasn't sure if we should consider a starting a new thread for 16 inch wheel brake upgrades or big brake kits for track, street, autocross etc that will fit 16 inch only? ! It could include weight loss, cost etc.
Thanks!!
makesdrivingfunagain is offline   Reply With Quote
Old 07-27-2016, 01:27 AM   #511
iManage
iManage's Avatar
Drives: '14 Whiteout Pearl
I've looked all over this post - and maybe I'm not looking in the right place, but is there a wheel someone is using that is 7" x 16" with the positive offset listed, WITH the brand of the wheel?
thx
iManage is offline   Reply With Quote
Old 07-27-2016, 09:12 AM   #512
BWilky
BWilky's Avatar
[QUOTE=iManage;2714074]I've looked all over this post - and maybe I'm not looking in the right place, but is there a wheel someone is using that is 7" x 16" with the positive offset listed, WITH the brand of the wheel?
If you run 16" diameter wheels, on a 7 (or 8) inch width, can you post the exact sizes with positive offsets, WITH the tire size AND the exact brand? Pictures are great, but I can't read the offsets or the tire sizes.
Based on http://www.ft86club.com/forums/showthread.php?t=7535
16 x 7 will need a 25 offset for flush not lowered and 24 for flush and lowered an inch.
The Following 2 Users Say Thank You to BWilky For This Useful Post:
funwheeldrive (05-03-2017), iManage (08-14-2016)
Old 07-27-2016, 02:21 PM   #513
iManage
iManage's Avatar
Old 04-25-2017, 01:11 PM   #514
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Some GC Subaru goldies on my 2015 BRZ. Currently running 25mm spacers because I'm only running 205/50R16 rubber.
Sent from my HTC One M9 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following 3 Users Say Thank You to FLIPDADY For This Useful Post:
BlackieChanz (01-20-2018), RallySport (07-23-2017), why? (04-25-2017)
Old 04-25-2017, 10:35 PM   #515
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by makesdrivingfunagain View Post
Hi all,
Thanks!!
that is probably going to be very wheel dependent. None of the usual so called big break options would fit, so you'd probably have to make your own kit. I doubt there is any need for its own thread.
why? is offline   Reply With Quote
Old 04-25-2017, 11:59 PM   #516
churchx
churchx's Avatar
Drives: 2014 GT86
I wouldn't be so sure that no BBK will fit. Imho there should be several 16" that can work with something like eg. Sprint kit.
Old 04-27-2017, 04:53 PM   #517
kuno
Hi all,
Got a cg8 sti wheel 16x7 +53 offset, With 225/50/16 tyres. When I put them on it gets too close to the shock/spring. Do you guys think 3mm spacer should be enough to clear it?
kuno is offline   Reply With Quote
Old 05-02-2017, 03:35 PM   #518
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Done a fair bit of searching on the threads, but haven't found much info.
Is, or has, anyone run a 16x6 wheel on their car? I'm looking at picking up a set of wheels from a 2001 Pontiac Sunfire GT, for a funky new winter setup, but was curious to see if anyone had test fitted anything around this size yet. It's tough to find concise data on them, but from what I've gathered it sounds like the offset is +47.
I've run 16x6.5 for winter before, and am guessing it would be fine, but wanted to find out if anyone had test fit similar wheels already.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 05:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 07:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-28-2012 12:20 AM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 09:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
