#15 | |
Drives: 2017 BRZ
| The Following User Says Thank You to cjd For This Useful Post: | dp1 (05-14-2016) |
#16 | |
driving smoother faster
Drives: Sold
Great feedback, thank you. I book track events before the season starts and it's hard for me to make up lost time. Also I could lose as much as I pay for service or more if something goes wrong during the busy track season. I've been there ![]() All the best |
#17 |
@dp1
A quick question for you. I used the Ohlins R&T for a while with 350F/425R Eibach springs. With this setup, the rear of the car sat higher due to the increase in spring rate. When you go to 500lb front/600lb rear, what springs will you use? Are there shorter springs which fit? I'm currently running the TEIN SRC coilovers. But like you, it would be nice to have a second set of coilovers to switch out to. I'd also like to send in the Ohlins for a rebuild and revalve to handle a higher spring rate. |
#18 | |
Drives: Sold
Need feedback on JRZ RS Double vs JRZ RS1 vs Tein SRC
Hi, I'm using Eibach 375f/425r. Ohlins service tech ordered and installed them for me during last service. I would recommend reaching out to them. I'm at a racetrack now and I just realized that I've been a couple of clicks too soft before...big difference between-12 and -10. I wonder if 425f/500r or 500f/600r would be more optimal for Ohlins track use...if somebody can chime in, please... Pics show current gap (resprung Ohlins) ![]()
| The Following User Says Thank You to dp1 For This Useful Post: | kster1 (05-15-2016) |
#19 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | kster1 (05-15-2016) |
#20 |
@ImperiousRex has experience with the JRZ RS(2) and Tein SRC on track...
| The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (05-15-2016) |
#21 | |
Drives: WRB JR BRZED
#23 |
I'm running JRZ RS Pro also. Great coilovers but I haven't tried anything else for the FRS. I had SRC on my s2000 but it's a different platform.
| The Following 2 Users Say Thank You to Apex-Apex For This Useful Post: | dp1 (05-17-2016), Racecomp Engineering (05-17-2016) |
#24 |
Here's our brief write up on the JRZ RS dampers we tested for them way back in 2012:
http://www.ft86club.com/forums/showthread.php?t=11759 Myles did a LOT more with them than what's in that thread. ![]() - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | dp1 (05-17-2016) |
#25 | |
Drives: Sold
Cool, and you're one step up with external canisters on the Pro. I talked to several people on the racetrack about JRZ and everyone raved about them though nobody has them on a twin. Not sure if the range of clicks is the same bw TWO and Pro lines - would like to exchange notes about cursory settings for street and track as I'm still learning about 2-way adjustability. Thanks |
#26 | |
| The Following User Says Thank You to Apex-Apex For This Useful Post: | dp1 (05-17-2016) |
#27 | |
To echo what Kristo said, I had the second set of MCS DA shocks made for our cars and they have been on my car for 3+ years now. They still feel the same now after 20K street miles, lots of autocrosses, and track days. I'm taking mine off tonight to get refreshed and revalved for stiffer springs in the future. Turnaround again should be maybe two weeks. They aren't cheap but neither are the other options mentioned. The J in JRZ is the one who started Moton/MCS btw. |
| The Following 3 Users Say Thank You to xwd For This Useful Post: |
#28 |
Drives: Sold
Of those of you who use(d) JRZ RC doubles, what springs/sways/damper settings do you use track vs street, out of 14 clicks for compression and 24 clicks for rebound?
For example, for front springs (~500lb/ft or 9kg/mm) + rear springs (~600 lb/ft or 11 kg/mm), JRZ recommends below settings as a starting point for street and track. First go full clockwise to full soft, then go counterclockwise to the first groove/click - the starting/0 point - then stiffen by going further counterclockwise for a specified number of clicks. In other words, C6 below means it refers to the compression knob and once you get to full clockwise/soft, go counterclockwise and stop at the 7th groove/click (fist click is 0 then 6 more from there). Street Front C6R8 Street Rear C4R5 Track Front C8R12 Track Rear C7R8 I understand that rough surface at Sebring will benefit from different settings than a brand new smooth surface at Watkins Glen. I have more to read up on, from resources shared by @CSG Mike and web pages like http://www.renntrack.com/forums/show...e-As-requested, https://rideapart.com/articles/suspe...ession-damping, http://www.hyperracing.com/pages/tec...y_no_more.aspx, etc. Please PM me if you prefer to keep your settings private, thank you. Last edited by dp1; 06-04-2016 at 01:46 PM. Reason: Updated to reflect how JRZ counts clicks (from all the way clockwise/full soft) |
| Double oil cooler | kcam86 | Tracking / Autocross / HPDE / Drifting | 16 | 05-20-2016 09:46 PM |
| ABS feedback?? | calidus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-17-2015 06:39 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
| sorry double post | LS13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-29-2012 02:42 PM |
| Double U T F...is this for real? | Hawk77FT | AUSTRALIA | 20 | 07-14-2012 05:21 PM |
