Old 05-12-2016, 10:48 AM   #1
dp1
driving smoother faster
Drives: Sold
Need feedback on JRZ RS Double vs JRZ RS1 vs Tein SRC
Interested in your impressions if you are an advanced driver, if you use(d) either of them on track and if you have a preference.
Please PM me if you've had any issues or concerns about either of these, including if something about them turned you against them in your research.
Currently running Ohlins R&T with custom springs and valving and like them very much for HPDE. Looking for potential upgrade.
Thanks
dp1 is offline   Reply With Quote
Old 05-12-2016, 11:18 AM   #2
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I ask that anyone who answers this please post in here instead of PM-ing. I am 99.9999% set on the Tein SRC's, when I get finally get off my wallet, but would love to hear more real-world experiences. There is an absurd amount of information on how to slam your car but not enough info out there on proper competition coilovers.
BatStig is offline   Reply With Quote
Old 05-12-2016, 11:54 AM   #3
Icecreamtruk
Drives: Track preped NA FRS
Interested in seeing the responses here as well. Suspension is my next area to mod.
Icecreamtruk is offline   Reply With Quote
Old 05-12-2016, 12:45 PM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
@CSG Mike
Old 05-12-2016, 01:07 PM   #5
Racecomp Engineering
We've run JRZ quite a bit and helped with the initial specs. We did a brief write up on the RS1 way back. No experience with the Teins though. I'll see if I can get Myles in here to comment.
What's the rest of your set-up like? Tire choice? Cage? Shock tuning experience?
- Andrew
Old 05-12-2016, 01:17 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What's wrong with the Ohlins?
I think I'd take the dampers with dynos and known quantities and improve on that before jumping on a totally unknown train and likely ending up having to go through the same effort and expense to dial in the Tein's, JRZ's, or something else.
More money doesn't always equal better performance or quality. Nobody is cheating physics, not even when you shell out >$7k for Penske's, it's still a piston moving through fluid.
ineedyourdiddly
Old 05-12-2016, 01:20 PM   #7
dp1
Drives: Sold
- Andrew
HPDE only, 35+ track/ax days over 5 years, intermediate-advanced (HPDE3 in NASA) group, 235/40-17 Toyo RR on RPF1, Whiteline suspension reinforcements, -3.5f/-2.5r camber, no cage, no shock tuning experience or desire to spend too much time on it. Like simplicity of single adjustables but wouldn't mind double adjustable since it appears to be worth it with quality dampers, for as long as I was given good starting values for double adjustables and direction for adjustments.
Regardless of what I get, I will keep Ohlins as spares and will have them resprung to 500lb front/600lb rear and revalved the next time they get serviced. It takes around $1k to service Ohlins shocks and probably around 30+ hours of tracking before they need service. Would appreciate some info about serviceability of the three dampers in the title.
Thanks
Old 05-12-2016, 01:24 PM   #8
dp1
Drives: Sold
Nothing wrong with Ohlins, evaluating upgrade options and want two track sets so I have a spare.
Old 05-12-2016, 03:22 PM   #9
OkieSnuffBox
Thanks
30 hours for a refresh? That seems abnormally low. That's like ~12-15 track weekends depending on who you run with.
Old 05-12-2016, 03:23 PM   #10
Thanks
Gotcha.
The JRZ RS1 are a great single and IMO have a sizable edge over Ohlins on track. We just found them to have superior valving...especially on the compression side. More low speed, more digressive.
But I'd say a 2 way such as the JRZ RS2 or RS Pro would make more sense for you though. If you're set on keeping the Ohlins as a back up, getting something with a little more flexibility (i.e. something with more potential) as your primary set of dampers would be much more worthwhile in the long run. The 2 way JRZs (espically RS Pro) are a fairly serious set of dampers but are still relatively easily approachable/tunable and definitely streetable. You can do a lot with them...HPDE to time trials to wheel2wheel racing. And support stateside is awesome.
We've had mixed results with revalved Ohlins depending on who's doing the revalve, but either way they still have limitations. JRZ's valving philosophy just works really well. Good digressive compression valving to control unsprung weight, "platform", and not too excessive rebound. Keeps the car stable, flat, compliant, and easy to drive fast.
Hope that helps. Send me a message if you'd like to chat or give us a call to talk to Myles.
- Andrew
Old 05-12-2016, 03:34 PM   #11
CSG Mike
CSG Mike's Avatar
@dp1 Danko, give me a call when you'er out of your meeting.
Old 05-12-2016, 05:07 PM   #12
dp1
Drives: Sold
It is what it is, probably around 30-50 track hours, depending on few variables. To me it translates to once per year.
Old 05-12-2016, 06:11 PM   #13
toeout
As a data point, I sent my MCS 2-way remotes in for rebuild this winter after 30K miles on the street plus auto-x runs. They didn't feel any different than when they were new, but I just wanted to have the internals checked. MCS said that the shocks looked great inside and didn't need to be rebuilt. Since they had them apart already, I had MCS refresh all of them anyway.
Next time I go to at least 60K or when something feels off. Also the turnaround between shipping the shocks out and getting them back was one week.
toeout is offline   Reply With Quote
Old 05-13-2016, 09:48 PM   #14
dp1
Drives: Sold
Ordered JRZ RS TWO from CSG after lengthy discussion with @CSG Mike. Much appreciate all replies though it appears that few run these...unless they missed this post. Will get Ohlins rebuilt/resprung to 500lb/600lb and revalved, then swap at the end of each season when the used set gets serviced.
Double oil cooler kcam86 Tracking / Autocross / HPDE / Drifting 16 05-20-2016 09:46 PM
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
sorry double post LS13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-29-2012 02:42 PM
Double U T F...is this for real? Hawk77FT AUSTRALIA 20 07-14-2012 05:21 PM
