Old 10-12-2015, 01:41 AM   #57
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Originally Posted by 86ish View Post
Did you have any rubbing issue with 255's? I was thinking of getting Eibach Sportlines and the same wheels and tire specs like yours. Could you post more pictures of your car?
There are pictures on the first page, I would rub on hard turns. I'm running 245s again since 255 is a little too much rubber for 200hp. You will be limited on front camber with stock struts with lowering springs since the tire is very close to touching the spring perch
BAMF86 is offline   Reply With Quote
Old 10-12-2015, 03:36 AM   #58
86ish
Drives: 2016 Scion FRS
I see. I might just consider getting coilovers then, but
86ish is offline   Reply With Quote
The Following User Says Thank You to 86ish For This Useful Post:
BAMF86 (10-12-2015)
Old 05-16-2016, 07:16 PM   #59
Jeremiahlee34
Drives: FRS innovate supercharged
Bought a set of 4 of 17x9 et38 with 245/40/17 tires
My local shop tells me with the stock shock they think it will rub, and wouldn't even mount them to the rims.
Do y'all think they are being too cautious? Or do you think it would rub. After reading I've the thread it looks like most are running similar set ups! So I was unsure.
Thanks in advance
Jeremiahlee34 is offline   Reply With Quote
Old 05-16-2016, 07:27 PM   #60
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
Thanks in advance
I'm gonna have to agree with them on this, I run 245/35 and I have about 5mm of clearance between the wheel/tire and the strut.
Legionsk88 is offline   Reply With Quote
The Following User Says Thank You to Legionsk88 For This Useful Post:
Jeremiahlee34 (05-16-2016)
Old 05-16-2016, 10:19 PM   #61
Jeremiahlee34
What offset do you have?
Thank you for the info! I think I will get a 5 mm spacer for my front tires
Old 05-16-2016, 10:33 PM   #62
Legionsk88
Legionsk88's Avatar
+40
Old 05-17-2016, 08:42 PM   #63
Jeremiahlee34
They fit!!
+40
I found a shop that mounted them and I was prepared to get some spacers but they put one on the car for the hell of it to see how bad it would rub and they actually fit perfectly! Can't even fit a finger between the rim and shock but it doesn't rub at all. And I put it through the paces today sliding sideways and over bumps, with no rubbing. Very surprised but thankful!
These are 17x9 et38 with 245/40/17 tires
Old 05-19-2016, 05:20 AM   #64
Calais
Calais's Avatar
Drives: 2012 BRZ, now track car and GRC dai
they look good but... dude i hate to break it to ya but those aren't 57xtreme's
For a pure sports car, it must be internal combustion-Mazda Motor Corporation’s sports car chief Nobuhiro Yamamoto
Calais is offline   Reply With Quote
Old 05-19-2016, 10:05 AM   #65
Jeremiahlee34
Ope, I have been in the wrong thread this whole time haha. I didn't even realize it
Old 05-20-2016, 06:16 AM   #66
Calais
Calais's Avatar
Lol no worries, I liked the colour combo of gold wheels on black, stoked for you the they cleared!
Old 05-20-2016, 08:29 AM   #67
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Looks MEGA!
Wonder how they'd look on my white one
I'd dig these in black/a dark grey for mine!
I like driving!
86 South Africa is offline   Reply With Quote
Old 08-19-2016, 06:48 PM   #68
pepe
Drives: gt86
Originally Posted by whiskerbox View Post
Here are some horrible pics to look at.
hello! what ist the name of your rear spoiler?
and dimensions wheels an tyres?
pepe is offline   Reply With Quote
Old 03-10-2017, 05:19 PM   #69
PlaidCat
Drives: 2016 Series.HyperBlue BRZ
Hey all, Just got mine in.
Like an idiot I didn't order Lugs.
I also have the weight at ~19.4.
I had to hold the wheel with a pinky so i'm sure the weight was affected a touch.
Thanks
PlaidCat is offline   Reply With Quote
The Following User Says Thank You to PlaidCat For This Useful Post:
Aaronimoe (04-23-2017)
Old 05-05-2017, 10:22 PM   #70
Genodude
Drives: 2016 Oceanic Blue MT Scion FRS
Picking these same wheels up 17x9 +40. Can any of the owners care to share what size hub centric rings are needed?
Genodude is offline   Reply With Quote
Wheel Directory: Gram Lights 57DR 17x9.0 +38 mr. slim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 12-07-2021 07:07 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Wheel Directory: Gram Lights 57Getter 19x8.5 +35 adprokid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 08-20-2015 11:44 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
