Old 05-04-2016, 05:13 PM   #407
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Originally Posted by infinity21 View Post
The bp20 pads have low initial bite but I didn't feel any fade with the stage 2 kit on track. If you're comparing to stock braking system, it will handle heat a lot better.
The best thing we've found with these brakes is that you can abuse them all day long (or in our case 12 hours straight) and not need to worry about heat.
Gear_One_Performance is offline
Old 05-06-2016, 06:57 PM   #408
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I had a proper track day yesterday at Shannonville Motorsports Park with a low turn out so I got plenty of hot lapping with my braking setup so I thought I'd talk about my experience a bit.
My car has HKS Hipermax 4 GT coilovers, 245/40r17 original BFG Rivals and the RR Racing sport performance fronts with BP10s and OEM rears with EBC Yellowstuff. I installed my stainless steel rear brake lines and did a full re-bleed and that helped tighten the pedal up a lot. It's still very easy to modulate but the spongy feeling is gone.
The track is medium on brakes and at no point did I experience any fade despite half hour hard lapping sessions. The ambient temperature was ~15c so being nice and cool may have played a part. Yay Canada! In fact, the brakes really preferred to be hot. I learned quickly to take it easy on the first half lap so the brakes can get some heat so they would give full bite. After that, they would tighten up and I got eye popping brake torque. Despite well over 2 hours of hard on track driving, the BP10 pads aren't showing too much wear.
I had a very fast friend of mine that I trust drive my car for several laps and he loved the brakes. He said it was easily the best upgrade I made for this car. Not that the stock brakes aren't capable but these are just on a different level in terms of feel, bite and control.
Lynxis is offline
Old 05-06-2016, 11:34 PM   #409
8R6
8R6's Avatar
Drives: FRS
Damn I should install my rear ss lines too. Thanks for sharing your feedback!!
8R6 is offline
Old 05-08-2016, 08:20 PM   #410
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I upgraded a few weeks ago to the sport rear kit to compliment the Stg2 fronts that I got last year.
I installed some porterfield R4 brake pads (God these are noisy) and got to spend the day at PittRace today.
The brakes did fantastic. I was a bit skeptical at first because the street pads didn't feel anything special with the new rears.
They did great overall. The car saw 4 sessions with many laps back to back of uninterrupted runs. The car is pretty quick with the blower and E85 so they should be enough brake for most guys considering an upgrade.
cruizin01 is offline
Old 05-10-2016, 06:42 AM   #411
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
How did you get the stg2 to fit under RPF1? You are running 17X9, correct? Which offset are you running and did you have to use a spacer?
Rookie84 is offline
Old 05-10-2016, 08:15 AM   #412
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Yes, yes & 5mm. Wasnt ideal but it works.
Sent from my SM-G930V using Tapatalk
Old 05-10-2016, 03:22 PM   #413
Rookie84
Thanks! Are you running +35 offset wheels?
Rookie84 is offline
Old 05-10-2016, 03:25 PM   #414
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Yes
Old 05-14-2016, 08:18 AM   #415
DarkSunrise
DarkSunrise's Avatar
Picture of the stage 2 kit installed on my FR-S. Wheels are 17x8 +42 WedsSport TC105N.
Also did a test fit on 17x9 +42 Apex ARC-8 wheels.
As mentioned by others, no problems fitting these brakes with either wheels. Good clearance all around.
I've only done street driving so far, but the brakes feel great. Very stiff pedal within the first ~0.5-1" of travel. If anyone is experiencing a soft/mushy pedal with these, try bleeding the brakes again. That solved the issue for me. Cold bite on the street is fine. I'm on the BP-20 pads and they squeal less than my previous Carbotech XP10's.
Track day coming up tomorrow - I think these are going to be very good.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
Old 05-16-2016, 09:34 AM   #416
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
@DarkSunrise I saw your car at the track and on track, but never saw you to talk to, haha. Looked quick out there!
DocWalt is offline
Old 05-16-2016, 10:20 AM   #417
DarkSunrise
Update from my last track day. The stage 2 kit and BP-20 pads worked great. Didn't have any issues with fade, although I got strong brake pad smell midway through each session. No noticeable impact on performance.
In terms of heat tolerance, these were a step up from my old stock brake/Carbotech XP10 setup. Gave me the confidence to brake 10-15 feet deeper than normal and trail-brake into corners (which would cause fade on my older setup), and I closed the gap on a lot of cars in my group this way. Some Cayman owners came over and asked how I was passing them lol. Mostly at corner entry. Once the brakes and tires (BFG Rivals) warmed up, there was plenty of stopping power and grip to play with.
In terms of negatives, you have to be more careful with pedal modulation as the front tires locked up easier than before. Not a huge deal, but there is a clear point in pedal travel where more pressure locks up the fronts. After a lap or two of getting used to it, I adjusted and didn't think about it anymore. I also felt slight inconsistency in pedal feel every once in a while, but it not 100% sure. Probably just need another bleed.
So far I'm happy with this BBK. Will probably stick with BP20 pads since they're cheap ($80) and effective. I may try to find a stronger rear pad though to shift some brake bias rearward.
2022 BRZ Build
2013 FR-S Build
Old 05-16-2016, 10:23 AM   #418
DarkSunrise
I missed you again!? Damn I didn't realize you were out there. There was a blue BRZ in my run group but was female driven I think. Were you running in blue? Black?
2022 BRZ Build
2013 FR-S Build
Old 05-16-2016, 10:36 AM   #419
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Glad to hear about the improvement in braking. Mine struggled mightily all weekend (pretty sure I smeared XP12s on stock brakes and they were certainly on the edge of fading a few times as I had to mash a lot harder occasionally)
I was in blue group. I'm curious, what sort of lap times are you running around there? I have no real comparison as there were no 86s in my group and I wasn't passed once all weekend though I had a lot of fun gradually pulling ground on certain people.
DocWalt is offline
Old 05-16-2016, 10:45 AM   #420
DarkSunrise
This past weekend my lap timer (track addict) couldn't acquire a GPS signal so I couldn't record times, but last year on my previous setup (Nitto NT05, stock brakes + XP10 pads) I did a 1:48 without traffic. With the new brakes and tires, it feels faster but I can only guess
2022 BRZ Build
2013 FR-S Build
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
