Old 05-15-2016, 01:04 AM   #15
Originally Posted by deuncos View Post
Appreciate the input guys, I'm renting out a lift this Wednesday so I shall report back ��. Also what's yalls thoughts on putting back the stock over pipe?
I don't believe that it will make any significant difference in drone between either of the over pipes. They are both just pipes.
deuncos (05-15-2016)
Old 05-15-2016, 03:00 AM   #16
steve99
Drives: FT86
Try putting the stock catback back on its only 30 minutes work. Their will be very little power loss over the perrin, just get some nice tips for it
humfrz (05-15-2016)
Old 05-15-2016, 12:26 PM   #17
deuncos
Drives: AT Hot lava FRS
Would that make more of a difference then just switching back to the stock front pipe?
deuncos is offline   Reply With Quote
Old 05-15-2016, 05:32 PM   #18
I would guess "yes" ....... because then, you would have a "muffler" ......
Old 05-15-2016, 05:43 PM   #19
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
So I recently installed a JDL catted uel header, JDL 2.5in over pipe, a custom fabricated JDL dual resonated front pipe 2.5in, and all of that is mated to a Perrin 2.5in resonated cat back. I mostly drive around the city and back streets, on the highway I experience little to no drone, but when I'm cruising on the streets since I have an automatic my rpms sit at 1500 when I'm light on the throttle and this is where I'm experiencing a lot of drone, is this drone due to the exhaust still being new? I know once it gets coated with soot and carbon it should quite down a bit, but is that the case with drone? Will putting on the stock front pipe alleviate this issue, should I put back on the stock overpipe as well?
I agree. I am thinking it definitely would make more of a difference. I also have auto trans, and get a SHIT LOAD of drone between 1500-2000RPM with UEL header, stock OP/FP/MP and muffler delete. I knew I would have some drone though, and I don't really mind it. I drive around it most of the time because I am in manual mode 99% of the time.
With that being said, I would imagine that the OEM catback's larger muffler will help keep away drone better than the Perrin catback you are currently using.
-J.B.
golfyankee2121 is offline   Reply With Quote
The Following User Says Thank You to golfyankee2121 For This Useful Post:
Old 05-15-2016, 05:45 PM   #20
deuncos
Originally Posted by golfyankee2121 View Post
I agree. I am thinking it definitely would make more of a difference. I also have auto trans, and get a SHIT LOAD of drone between 1500-2000RPM with UEL header, stock OP/FP/MP and muffler delete. I don't really mind it, and I drive around it because I am 99% of the time in manual mode.
-J.B.
Do you still get the uel rumble? That's my only concern switching back to stock. I don't mind the noise, just can't stand the drone.
Old 05-15-2016, 05:52 PM   #21
golfyankee2121
I don't have the OEM muffler on my car. I have a UEL, stock OP/FP/MP and muffler delete and it's pretty loud. Lot's of rumble.
I would imagine with the OEM muffler you will still get that UEL rumble.
EDIT: check out this video (NOT MINE). Skip thru til 00:35 and you can see what just a UEL and stock exhaust sounds like
[ame="https://www.youtube.com/watch?v=W4pExkk_YrQ"]Rev Works UEL Header on Stock Exhaust BRZ - YouTube[/ame]
So you definitely still have the rumble, just not quite as loud as I'm sure it is with your current setup.
-J.B.
deuncos (05-16-2016)
Old 05-15-2016, 06:42 PM   #22
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
If you throw the OEM muffler back on you will lose your rumble in the cabin for sure.
I've run with both of these setups:
Uncatted UEL (louder than a catted one for sure) -- stock OP -- Stock FP -- Stock MP -- Stock muffler = No rumble in cabin, small bump in noise overall but still need sound-tube in cabin to hear engine well.
Uncatted UEL -- Stock OP/FP/MP -- TopSpeed PRO1 axleback = lots of rumble, no drone, but enough volume that highway trips were annoying at 3k+ rpm (70mph)
Can't hurt to try the stock muffler, but in my experience you will lose your rumble.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
Old 05-16-2016, 02:39 AM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Which part of the exhaust do you recommend I start with? I'm thinking of switching the stock front pipe back first. What's your opinion on the over pipe in regards to noise and drone?
Overpipe makes no difference in sound.
Your best place to find sound suppression is the front pipe. Keep in mind that a catalytic converter is not a reliable indicator of sufficient sound suppression, because many high-flow cats are often too small to make a difference in sound.
-alex
Old 05-16-2016, 02:51 AM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
My entire cars exhaust is stock apart from the UEL right now, and I get plenty of the rumble its subtle but noticeable, especially if someone else is driving I can hear it from outside, it's an almost OEM sound. Unlike the setup you have which is much more "brash"
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 05-16-2016, 04:41 AM   #25
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
damn you get drone at 1500 rpm? i have an Auto too and my drone doesnt come in until 3500rpm
thecarfilmer is offline   Reply With Quote
Old 05-16-2016, 06:48 PM   #26
FRSBRZGT86FAN
When I had the Berk muffler delete drone would start at 1500 and go to 3500
Old 05-17-2016, 09:27 PM   #27
zberz
Drives: 2015 Lightning Red BRZ
sent from my phone using black magic
zberz is offline   Reply With Quote
The Following User Says Thank You to zberz For This Useful Post:
Tcoat (05-17-2016)
Old 05-18-2016, 02:22 AM   #28
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
I am in a similar situation, went with full JDL 3" and it is too loud. Sounds great, but too loud. Should I switch the exhaust back to stock exhaust and leave the headers or is there something else I can do? Startup is unbearably loud, but I read you can tune to remove the startup/warmup high rpm.
UEL uncatted header
overpipe frontpipe with cat and resonator
catback with Magnaflow resonators
I used to have a smile every time I drove my car, but now all I have is headaches!
Chad86 is offline   Reply With Quote
SRT full header back exhaust + header? KenTK808 Engine, Exhaust, Transmission 21 11-29-2017 06:07 PM
FS: Sprintex 335 kit w/ full header back exhaust. TSW Interlogo's 20firestorm13 Engine, Exhaust, Bolt-Ons 12 01-24-2016 05:06 PM
UEL Header + Invidia N1 drone help! Captain Engine, Exhaust, Transmission 4 10-31-2015 09:49 AM
DRONE!!! full exhaust Victor Draken Engine, Exhaust, Transmission 23 06-02-2014 07:52 PM
FS: Header back full exhaust system. Borla/Greddy 20firestorm13 Engine, Exhaust, Bolt-Ons 8 06-10-2013 01:40 PM
