Old 05-13-2016, 08:19 PM   #1
euthqt
Drives: 2013 Scion FRS 10 Series AT
Brake Sound
I've finally found a video that replicates what my brakes sound like. When I release them I hear a clunk. Anyone have this issue?
[ame="https://www.youtube.com/watch?v=IPk2Usz1sxs"]FRS Brake Noise - YouTube[/ame]
And yes, it happens when it's not raining and the brakes are not moist.
Thanks guys!
euthqt is offline   Reply With Quote
Old 05-13-2016, 08:27 PM   #2
No, I haven't noticed my car doing that except maybe once, after the emergency brake has been released.
But if it did, I would suspect that my car had a brake caliper sticking. I'd pull off the wheels and check them out.
Or, more likely in my case, run the car up to the local brake repair place and have them check them out ......
Old 05-13-2016, 10:06 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like worn brake shoes to me. Or some gunk up on the springs on the shoes.
Like humfrs said drop by any brake shop and have them take a look. Or if you are mechanically inclined, do it your self.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (05-13-2016)
Old 05-13-2016, 11:37 PM   #4
stevesnj
stevesnj's Avatar
Does the sound happen only when it's damp or wet out?
My 2016 Build thread
Old 05-14-2016, 12:02 AM   #5
He says (under the picture)
"And yes, it happens when it's not raining and the brakes are not moist".
Old 05-17-2016, 01:58 PM   #6
Razzamatazz
Drives: 2015 BRZ Limited
My '15 brz makes the same noises.. not too sure whats up with that, i notice it mainly when I'm in a parking or at a light. No moisture/rain, im in SoCal but not super close to the beach, either, so salt water shouldn't be it. I'll see about running to a brake shop as soon as i can to see what's up.
Razzamatazz is offline   Reply With Quote
Old 05-17-2016, 02:34 PM   #7
euthqt
Let me know if you find a solution.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 05-17-2016, 02:36 PM   #8
The solution is to take them and have them checked.
Old 05-17-2016, 02:40 PM   #9
euthqt
I understand that and I'm not able to get that done yet so being able to have someone that can before me let me know what they found would be nice.
Old 05-17-2016, 02:50 PM   #10
Brakes and steering are two things you wait to "get done" if you suspect there is something wrong. You bite the bullet and deal with them right away. Unless of course the car is parked and not being driven in which case you have all the time in the world to deal with it. His issue and yours may not be the same anyway.
nos145 (05-18-2016)
Old 05-17-2016, 03:00 PM   #11
euthqt
I know that. I'm unable to do anything with the vehicle right now.
The Following User Says Thank You to euthqt For This Useful Post:
Tcoat (05-17-2016)
Old 05-17-2016, 03:07 PM   #12
Well it is good to know you are not driving around for a couple of months with a potential braking issue.
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Air/hiss sound when depressing brake petal TM Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-10-2013 11:29 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Puget sound Tint option that won't break the brake light rice_classic Northwest 17 09-05-2012 08:22 PM
