Old 05-12-2016, 05:55 PM   #1233
GT86Asia
Drives: 2016 BRZ
Originally Posted by Freeman View Post
Is your air filter resting on the header?
if it was the intake that Edelbrock provided, it would be resting and touching the headers, which means melting down.
This modified intake has about 3-4 inches of space betweent he top of the headers and the bottom side of the intake.
GT86Asia is offline   Reply With Quote
Old 05-12-2016, 05:57 PM   #1234
GT86Asia
Drives: 2016 BRZ
Originally Posted by ATL BRZ View Post
Dude...
You should really take some intake air temperature logs....
Tuner said he wasn't really worried about the temp, as the car would be going at speed, so the wind should be pushing the heat towards the back in anycase The only way heat will go up is if speed slows down like in traffic.
For now, we work with what we get. But in the near future I will consider either doing a custom heat shield, or, doing a massive coat on the header plus wrap.
Old 05-12-2016, 05:58 PM   #1235
GT86Asia
Drives: 2016 BRZ
Originally Posted by GSpeed View Post
...so can you make 300whp with the hood closed?
330hp, 300trq to the wheels, with the hood closed and fans on, on the dyno.
The Following User Says Thank You to GT86Asia For This Useful Post:
GSpeed (05-12-2016)
Old 05-12-2016, 06:11 PM   #1236
ryoma
ryoma's Avatar
have you thought of doing a vented hood, perhaps the DIY louvers? I think that would let the hot air escape easily without impacting your IAT's as much as a closed hood would. however, the W2A intercooler would be cooling the hot air coming from the cone filter anyways so I doubt it would matter that much
Old 05-12-2016, 06:27 PM   #1237
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I haven't dont any temp logs, but wrapping the header seems like less heat comes out of when I pop the hood. Also no more codes thrown from coil pack issues.
clayrush is offline   Reply With Quote
Old 05-12-2016, 06:35 PM   #1238
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by clayrush View Post
I haven't done any temp logs, but wrapping the header seems like less heat comes out of when I pop the hood. Also no more codes thrown from coil pack issues.
I just got P0351 coil pack A CEL on the track on Mon even with the stock headers w/ heat shield
Old 05-12-2016, 06:41 PM   #1239
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
They just go bad. lol...
I've had two cyl 1's go bad and one cyl 2...
Jaden
Jaden is offline   Reply With Quote
Old 05-12-2016, 06:46 PM   #1240
BigFatFlip
BigFatFlip's Avatar
Exactly, this one is my 2nd one (first one, I swapped #1 & #3). Will be replacing both. I guess the point I was making was that even with the stock heat shield, you can still fry your coil packs... but back on topic
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
clayrush (05-13-2016), funwheeldrive (05-13-2016)
Old 05-12-2016, 09:10 PM   #1241
taiguy
Drives: 2013 Black BRZ Limited
Hey guys, I've finished installing the e-force system into my BRZ but I'm struggling with the EcuTek part.
When I try to open one of the matching RaceROM (.ERP) file I get an error that says "Unable to Identify Rom Class Array".
The only thing that successfully loads and flashes are the stock BIN files outside of the RaceROM directory.
taiguy is offline   Reply With Quote
Old 05-12-2016, 11:00 PM   #1242
CSG Mike
CSG Mike's Avatar
You should be selecting the Edelbrock supplied rom file, wherever you saved it to.
Old 05-13-2016, 01:06 AM   #1243
taiguy
That's just it. I didn't find anything in the box. The instructions mention a flash drive with the file. The only flash drive I found was the DSE key. I managed to get a hold of someone at edelbrock right around closing time and they stated that no BRZs were being read correctly out of the box and I would have to send them a dump file in order to get a custom configuration.
I picked a .BIN file like it shows in the printed instructions but I'm guessing that's not it. What are all these misc .ERP files that got automatically downloaded? Also it wants to download mazda miata files as well?
Old 05-13-2016, 01:21 AM   #1244
BigFatFlip
BigFatFlip's Avatar
Did you send them the info needed? ie dongle ID and registration code? You need to send them your info then they will send you the appropriate file to flash to.
The files that Ecutek wants to download are the "stock" tunes for when you want to flash back to stock. No need to download the mazda files, just need the BRZs.
Old 05-13-2016, 01:46 AM   #1245
taiguy
Doing that now. It's not listed in the instructions. It says to make a note of the dongle ID and registration code, then it moves on.
I think the mechanical instructions were top notch. These Ecutek instructions need to be sent back to the technical writing team.
Old 05-13-2016, 05:45 AM   #1246
clayrush
I am sure they will pop codes again.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
