#2913 |
Drives: 2014 GT86
@Pat: I wouldn't say that camber plates make BIG difference over camber bolts if you dial in same amount of camber. They often do allow more camber to be dealed in and are much easier to adjust (at much higher price of plates themselves of course), but if you are not aiming for lot of camber and if you are not the one doing alignment, where is difference then?
#2914 |
Drives: '23 BRZ Limited
Whiteline, RS*R, Velox are the ones I can think of.
| The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | Racecomp Engineering (05-12-2016), strat61caster (05-12-2016) |
#2915 | |
Drives: '13 FRS - STX
SPC w/ a replacement bushing for the spherical bearing Whiteline appears legal in it's current config with the pressed in bushing Racer-X RS*R, honestly forgot about this one until Okie mentioned it Velox, most expensive, lightest I've got the Racer-X, pretty happy with it, I like how accessible the adjuster is, the rest are tucked into the subframe and you have to locate each threaded end asymetrically it looks like. Whichever you choose make sure it's got a polyurethane bushing, not metal per STX rules. Local events nobody should care, but if you start competing at a national level it's an easy disqualification. Threaded adjustment on the RacerX, rsr, velox are convenient and makes things nice and repeatable if you're doing your own alignment, the cam adjustment on SPC/Whiteline will be a little less precise but no less effective, if you don't plan on doing your own alignment I'd pick the SPC/Whiteline. |
#2916 |
Drives: FRS
this is a brake question, but do you guys know the reasoning/logic for some manufacturers placing the brake caliper on the "front" of the rotor (towards front of car), while some place the caliper on the "rear" of the caliper (towards rear of car)?
#2917 |
Drives: GT86-ACE-JRZ-RPF1-Essex
One solution is cheap, the other one is good for weight distribution.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
| The Following User Says Thank You to MaximeT For This Useful Post: | 8R6 (05-12-2016) |
#2918 |
Drives: FRS
so it's not related to the braking performance itself? thats what i couldnt figure out. like if it mattered where on the rotors the pads clamped down on the rotor and was just wondering if there was some fancy physics thing that i just have no idea about lol
#2919 | |
Maybe easyer to do with double wishbones.
| The Following User Says Thank You to MaximeT For This Useful Post: | strat61caster (05-12-2016) |
#2920 |
Don't forget cooling.
| The Following User Says Thank You to strat61caster For This Useful Post: | 8R6 (05-12-2016) |
#2921 | |
Drives: Scion FR-S | 6MT | Ultramarine
#2922 |
If you could find a way to replace the rod end on the SPL arm with a bushing, that would hands down be the best solution to me.
Based on the reputation, and the ability to tune shock/sway ratios, and also get some lowering while maintaining travel with the lower shock mounting holes. |
#2923 | ||
#2924 |
Good point. I quit paying attention to SCCA Auto-X rules a few years ago.
However, in reality, if you aren't looking to trophy at Nationals I doubt anyone would care. |
#2925 |
Drives: BRZ WRB
I did an alignment on my car like a month ago, the front is perfect but the back is a bit too low. Id like to raise it a bit (1 finger). Will this affect the toe at the back? I dont remember seeing a place to adjust the toe at the back. (stock btw, only coilovers)
#2926 | |
Drives: 2017 BRZ
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
