Old 05-09-2016, 02:00 AM   #169
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Wayno View Post
In my experience nothing is inexplicable. Better solving the actual issue which causes IAM drop in the first place than working around it and creating more complexity.
To be honest, that's just my excuse to change that table to see if it will cause the IAM to recover more quickly when it does drop. I do agree with that there must be an explanation for it, though each time I've seen that happen I've tried to replicate it in a log to no avail. When I try to capture the IAM dropping, trying to replicate the conditions in a log it simply doesn't happen. It happens very infrequently, and when it does happen it's typically during a long distance drive on the freeway with extended period of having the throttle held in a particular position. Have you experienced it before?
Intent > Content
Old 05-09-2016, 02:56 AM   #170
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No, why would i care about iam or power or logging for that matter on the highway? My timing map is so smooth that any iam drop is due to cl fuelling or insufficient learning time or avcs or whatever, not timing. Also we rarely have flat highways for miles here like you do.
Old 05-09-2016, 03:23 PM   #171
solidONE
solidONE's Avatar
I don't know about you, but I'd be concerned about how my engines is performing under all conditions. Maybe that's just me. But I get your point. It's not likely that something funky would happen under low stress situation especially after you've done your homework on your calibration. meh... To each his own, I guess.
Intent > Content
Old 05-09-2016, 07:16 PM   #172
Wayno
Wayno's Avatar
You're assuming that your engine is under performing 0.3 deg of ign adv less under low load ? I think most tuners would laugh at that.
Old 05-09-2016, 07:34 PM   #173
solidONE
solidONE's Avatar
No. You're assuming that is what I meant? lol this guy...
Intent > Content
Old 05-11-2016, 10:21 AM   #174
solidONE
solidONE's Avatar
I tried "stressing" the engine a little to see what happens in terms of the flkc and if the IAM will budge so that I might see the effect of the changes I made to the fine correction tables.
This is on a .5 mile stretch of road that I time myself on that starts on a steep downhill grade through some tight turns then a steep uphill to the end. http://datazap.me/u/solidone/kc1-par...zoom=4988-5585
This didn't even tickle it's belly even though oil temps climbed to 230f* (which is actually not too high). FLKC is completely flatline here. I guess I'd have to take it to the canyons or track to really see the effects on this particular tune I'm running. Otherwise the only other way is to load 2 calibration starting the IAM at .5 or so then see how the IAM get built back up to 1 with the changes then once again without the changes to the fine correction tables.
Intent > Content
Old 05-11-2016, 08:03 PM   #175
solidONE
solidONE's Avatar
To test the changes I made to some of the fine correction tables I went ahead and changed my original "Z6" tune to start at .5 IAM with no other changes (left side of the image above), reflashed then took a log to see how quickly IAM builds up to 1. Then I flashed basically the same tune with the changes to the 3 tables I did in an earlier post. I'll call it "Z6 KC1" test tune.
Z6 test tune log: http://datazap.me/u/solidone/z6-iam-...1&zoom=30-1107
Z6 KC1 test log: http://datazap.me/u/solidone/z6-iam-...&zoom=405-1273
I'm not sure if you can tell by looking at the log, but the changes I made work as expected. While the Z6 tune did not take very long to recover IAM back to 1 the Z6 KC1 tune did so quicker.
Another thing I've observed is that the FLKC never went above +1 in either of the logs. As the IAM increased the +FLKC values became progressively lower. I'm not quite sure whether changing the Fine Correction Stored Value Limit from 3.5 to 4 contributed to a faster rate of recovery. @Kodename47 I think maybe you have a better idea of what this particular table is doing than I do. Though, from the looks of it, I think increasing this value is pretty irrelevant to what I'm trying to accomplish, yes?
For shits 'n giggles, another run at the .5 mile road. FLKC still flatline. http://datazap.me/u/solidone/z6-iam-...zoom=1502-2261
Intent > Content
Old 05-12-2016, 02:50 AM   #176
Kodename47
Kodename47's Avatar
Drives: UK GT86
From memory, the FLKC table should be cleared upon every IAM change. FLKC values, both positive and negative, are dependent on the Advance table. I doubt you'd hit that 3.5/4 value and while I would suggest that a lower value might make it restore quicker, it's not something I'd go changing.
.: Stealth 86 :.
Kodename 47 DJ:
solidONE (05-12-2016)
Old 05-21-2016, 06:52 PM   #177
solidONE
solidONE's Avatar
I decided to add some more ignition advance to the existing calibration I've been running as it seems the fuel quality has gotten a bit better recently. Also out of boredom...
I added about 1 degree right in the middle of the power band from around 4~6k to see if it will make a little more power. From the looks of the initial logs it doesn't seems to be doing much if anything. I'm sure the IAT's likely has something to say about it. @Wayno do you have any logs of your setup on 98ron petrol that you can share?
Updated with 1 degree more advance: http://datazap.me/u/solidone/z6-kc1b...1998-2027-2037
Previous: http://datazap.me/u/solidone/z6-kc1-...81-290-300-311
edit:
Digging through my old logs I found earlier versions with more conservative ignition advance maps, same cam tables:
MAF voltages higher than my current peaking at 4.13v (current peaking at 4.05v with about +10*f IATs and likely a few less WHPs) : http://datazap.me/u/solidone/cw1z2-1...4951-4943-4935
Intent > Content
Old 10-19-2016, 10:30 AM   #178
g0lds
Drives: 14 BRZ Limited
I set my fan values to the ones you listed and my fans do not run when I'm stopped.
g0lds is offline   Reply With Quote
Old 10-19-2016, 07:00 PM   #179
Wayno
Wayno's Avatar
You put the values in the wrong system of measurement.
Old 10-27-2016, 12:06 AM   #180
Nah
Drives: 2013 Scion Frs 6mt
does anyone have a completely stock rom of the ft86? A01C please... nothing OTS just straight up stock from the factory.
Please and Thank You!
Nah is offline   Reply With Quote
Old 10-27-2016, 12:23 AM   #181
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Here ya go...just change the extension to .bin, file is the same ('save as...' or your browser will probably try to display it):
https://dl.dropboxusercontent.com/u/...8/ZA1JA01C.ori
BRZyJ is offline   Reply With Quote
Old 10-27-2016, 01:27 AM   #182
Nah
Could you send over the def files too please.. Thanks for the help
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 11:40 AM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 08:45 PM
PA: Rays Gram Light 57 Maximum 5x100, 17x8, +43 (Price Reduced!) Needs more cowbell Wheels and Tires 20 02-22-2013 10:03 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 11:49 AM
