#15 |
Night Owl
Drives: 2013 Subaru BRZ
Thanks Chase @GrimmSpeed for the informative post and to everyone else with constructive answers
#16 |
Drives: 2015 FRS RS 1.0
Bravo bravo! Awesome reply chase! That was exactly the input i was looking for in a boiled down version!!! And because u gave an explanation with dyno chart on the actual benefits versus the drop-in i have decided to purchase the GS. Thanks so much.
#17 | |
Drives: FT86
That's rearly weird that just a drop in filter could cause the engine to run lean especially 14:1 lean. and don't understand why that would happen as your not altering the position or the size of the maf sensor housing, unless it created large amounts of turbulence or something, then with drop in and elbow or dropin elbow and modded snorkel is much better. Or it was an oiled filter and its contaminated maf ? just not experienced or seen that issue with just a drop in filter |
#18 |
Drives: Toyota 86 GTS
There's no way a dry drop in filter will make you run lean, unless you do something ridiculously stupid like reset the ECU before putting it on the dyno like some vendors like to do.
| The Following User Says Thank You to Wayno For This Useful Post: | tomm.brz (07-06-2018) |
#19 | ||
![]() DIF and modded snorkel didn't make it much better, about a quarter point. And Silicone elbow, DIF, and modded snorkel wasn't much better than that either, still very lean. And yes, the K&N is an oiled filter. But no, this is not an example MAF contamination. These were some of the first pulls of the day, and if we had a contaminated MAF we would have seen the same poor results on all of the other intake combinations were did. I do agree that it is really weird for the reasons that you mentioned, but it also certainly is not the first time we or other people have seen this effect with drop in filters. Also that post is right here: http://www.ft86club.com/forums/showp...&postcount=200 It's a good one because it shows stuff that people usually never see like power gain from the silicone elbow, modified snorkel, and combinations of everything. Quote:
And I do agree with you, there are lots of vendors that do "stupid things" like reset the ecu before a dyno run. Usually before the dyno run that they want to look "bad." We reset the ECU before every single intake combination (so 23 times), but we were also using an OFT with stock tune, but that forced the IAM to 1.0 upon reset. This was done for consistency between all combinations, and to clear any sort of learned values. So while I've seen a ton of dyno charts from people from all sorts of intakes and drop in filters, but they almost never have AFRs. We did extensive testing, and provided tons of data including all kinds of dynos with AFRs for competitor's products. And even better, we don't have a dyno, so 100% of it is 3rd party testing. The only thing we did was change the intakes on the car. There is no reason to think that this data isn't accurate, especially with the extremely large data sample that we have, and how consistent the results are. Chase Engineering |
| The Following 4 Users Say Thank You to GrimmSpeed For This Useful Post: |
#20 |
I purchased the GS and am awaiting its arrival. Once installed and thrashed on for a while i will post a reply with my feelings on it.
| The Following User Says Thank You to 86_PWR For This Useful Post: | NLSP (05-13-2016) |
| GrimmSpeed Cold Air Intake - New Product Information - Proven 10whp Gain | GrimmSpeed | Engine, Exhaust, Transmission | 163 | 11-05-2018 09:24 AM |
| SOLD | Demandred7 | Canada Classifieds | 6 | 10-13-2016 08:43 PM |
| WTB: GrimmSpeed Air Intake | xFury | Want-To-Buy Requests | 0 | 11-16-2015 06:54 PM |
| Wtb grimmspeed intake | APEXIT53 | Want-To-Buy Requests | 0 | 02-01-2015 05:19 PM |
| WTB GrimmSpeed intake | VakaGT | Want-To-Buy Requests | 0 | 11-18-2014 12:19 PM |
