Old 04-20-2016, 01:27 AM   #15
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Originally Posted by LaertesSon View Post
Found a fix, not sure if anyone else here has tried it:
1. Unscrew shift knob
2. Inside the shift knob threads there is an Allen screw
3. Unscrew this, push the reverse lockout up, and a spring will pop out.
4. Fill the hole with lubricant, and cover the spring.
5. Replace all parts.
Just did this today, the grease will leak from the lockout when using it, but it seems to have helped. If anyone wants pictures let me know.
did this last week with white lithium spray on the spring, no help for me
malubawla is offline   Reply With Quote
Old 04-20-2016, 11:01 AM   #16
LaertesSon
LaertesSon's Avatar
Drives: Asphalt 2013 FR-S 6MT
Originally Posted by malubawla View Post
did this last week with silicone spray on the spring, no help for me
I'm not sure if sprays will work. I used the grease included with the actual shifter (the permagrease in a syringe) and it seems to do a little more. I don't think a spray lubricant will hold the spring while the shifter is vibrating so much.
Try using a thicker grease, maybe white lithium?
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs
TSW Nurburgring, FIVE:AD aero kit, smoked Valenti
LaertesSon is offline   Reply With Quote
Old 05-11-2016, 10:37 AM   #17
LaertesSon
LaertesSon's Avatar
I contacted Tom at Kartboy and he sent new bushings and O-rings to put where the short shifter connects to the linkage. I used lots of grease and the rattle is pretty much gone. I'd recommend you guys contact Kartboy, they have excellent customer service.
Old 05-11-2016, 12:56 PM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Do you have his contact info?
Old 05-11-2016, 02:30 PM   #19
LaertesSon
LaertesSon's Avatar
I went through this:
http://www.kartboy.com/x4/help.php?s...us&mode=update
He responds quickly and is very professional, he also said that the original bushings were too tight of a fit, and apparently these new ones will help. So far for me they have helped a lot.
[FS]RCE Yellows, Kartboy UDP, Kartboy shifter stay bushing Calum Brakes, Suspension, Chassis 11 11-03-2015 07:19 PM
Kartboy rattle? Venator Engine, Exhaust, Transmission 37 09-14-2014 06:53 PM
DIY - Kill Kartboy rattle Trap63 DIY (Do-It-Yourself) Guides 20 08-25-2014 03:49 AM
>> Kartboy Sale - 10% off all Kartboy Items at RallySportDirect.com!! << RallySport Direct Transmission and Driveline 1 07-19-2013 06:56 PM
>> Kartboy Sale - 10% off all Kartboy Items at RallySportDirect.com!! << RallySport Direct Announcements, Contests, Giveaways 1 07-17-2013 09:28 PM
