Old 05-09-2016, 03:28 PM   #29
AJPG
Drives: 22RE, FA20, 4G63
450whp won't last forever, no matter how good your tune.
The only way the car will last for ever is not using it.
AJPG is offline   Reply With Quote
Old 05-09-2016, 03:31 PM   #30
Actually that will ruin it even faster!
Old 05-10-2016, 05:14 AM   #31
AJPG
Hahaha! Not exactly what I have in mind.
Old 05-10-2016, 05:21 AM   #32
AJPG
Originally Posted by wparsons View Post
Any CARB legal supercharger kits/tunes don't need lower C/R, and doing so will just cost you power.
Sir your statement is true but your didn't answer. It will continue to be carb until you adjust the tune.
Old 05-10-2016, 05:31 AM   #33
AJPG
Originally Posted by SPCorBUST View Post
I won't be running a CARB tune, I'll be running a custom tune. I am up for changing CR if it makes the engine more reliable so long as there are no adverse affects to emissions when ON a CARB tune, which would only be used during emissions testing.
Heat that's the enemy, you have to keep fluids in operating temps at all times if you really desire the car to last. But I can't help more due to tha lack of info about your car and goal... A good tune could help a lot, but is only part of the equation.
Old 05-10-2016, 12:45 PM   #34
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
You're in Cali...
Does anyone know how lower compression pistons affect emissions? I think I'd like to use lower compression pistons but I'm concerned that I'll no longer be able to pass a smog. California CARB is a PITA.
You should be more worried about what F/I solution you'll be using than what compression ratio you're running..
Also, I believe that our cars won't have a sniffer test when they start getting tested, so you would only need to pass the OBD-II test and the visual inspection.
If you plan on using a non CARBed turbo or other F/I solution, you'll have to remove it for inspection, which means you'll have to change the tune.
With lower compression, you'll just have a different tune that makes less power, but if the tune is right it should still pass.
Jaden
Jaden is offline   Reply With Quote
Old 05-10-2016, 01:15 PM   #35
wparsons
wparsons's Avatar
No. Modifying the engine internals (unless the new internals also have a CARB approval) will make it not CARB legal.
It'll also run way less than ideally on a lower c/r on the tune meant for stock c/r.
flickr
Old 05-10-2016, 09:21 PM   #36
AJPG
Nop.
Old 05-11-2016, 07:31 AM   #37
AJPG
Jaden
Agree, but to clarify.
The only thing that you should do different on tune with same everything except from cr, is timing, no need to touch fuel.
Old 05-11-2016, 09:40 AM   #38
wparsons
wparsons's Avatar
You'll never tune my car, that's for sure
If you think the only thing you'd need to change after dropping the C/R like 3 full points is timing, you're in for a world of pain.
That much of a change is going to drastically alter the volumetric efficiency of the engine, and would require a full re-tune.
flickr
Old 05-13-2016, 07:59 AM   #39
AJPG
Sir today is your lucky day!
I am not a tuner (not professional and the ones I have done were finish by real professional tuner).
But what is volumetric efficiency? How can it be changed or altered?
Volumetric efficiency, is the amount air (CFM) that gets to the "air chamber" to be used to produce the controlled explosion...
So it could be altered with modifications to the intake, heads (port, valves # and size) cams (duration and lift) exhaust, also and more dramatic with FI but no with cr. Sorry.
Suggestions on built short block and compression ratio? SoCal80six Forced Induction 24 11-18-2015 05:59 PM
Porsche Patents a Variable Compression Ratio Captain Snooze Other Vehicles & General Automotive Discussions 7 04-30-2015 11:21 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
